Only needed if you have a trailer with an aluminum frame. They are used to prevent galvanic corrosion of the aluminum, which is a "noble metal" and will tend to corrode away before many other dissimilar metals. With a steel frame, it isn't necessary, unless you have a boat trailer which gets dipped into salt water a lot.
