Safely camping in a 13' Burro (heaters, AC etc.) - Page 3 - Fiberglass RV
Old 11-13-2009, 07:24 AM   #29
Trailer: U-Haul CT13 ('Pearl')
SW Ohio
Craig,
You could put some of that thin foil bubble insulation between the shells. I just did mine and it was simple. I couldn't get between all of the panels, but it does make a huge difference. The condensation problem is much more evident now on the uninsulated areas.
Pat B Ohio is offline   Reply With Quote
Old 11-13-2009, 09:24 AM   #30
SW Ohio
OOH Don't forget to install a smoke alarm!
Old 11-13-2009, 01:40 PM   #31
Roger C H's Avatar
Talking
Craig,
Maybe you could drill a small hole in the uninsulated areas and spray in some of this:
http://www.acehardware.com/product/index.j...hId=42641045853
I don't have personal experience with this but I am sure some of our readers have.
Old 11-13-2009, 02:48 PM   #32
Ed Harris's Avatar
Good idea in concept but......
You have to be very careful in this application to get a foam with almost no expansion capability.
I have seen entire houses lifted from the foundation by overzealous application of expanding foam in every crack. It is not hard to imagine what could happen to a Burro if too much was applied between the shells,it may end up like the Flintstone rig in the thread?
I have used the Hilti foam they sell at Home Depot and it comes in different expansion grades.
It seems to a higher grade product than the Great Stuff too and easier to control out of the straw.
For sure you want to try some in the thickness you are trying for on a test surface before going at the Burro.
It is fun to use though!
burro
We're back safely and hope you are too Teresa J Oregon Gatherings 13 07-22-2010 04:45 PM
The new (to me) Burro, home Safely, Yeah! Jake General Chat 12 04-19-2010 11:46 AM
Alternator charging house battery safely Ami P Problem Solving | Owners Helping Owners 7 12-14-2008 11:59 AM
Towing the Bigfoot safely Lainey Towing, Hitching, Axles and Running Gear 8 08-13-2007 03:30 PM
PLEASE READ: Referral Ads - Buying Safely Gina D. Referrals: Molded Fiberglass Trailers 13 01-21-2007 05:25 PM
