sanitizing water tank - Fiberglass RV
Old 06-19-2011, 12:11 PM   #1
Trailer: 73 Boler 13 ft
Do folks generally bleach out the water tank once in a while? We have been hauling along a Coleman jug with drinking water, but if we could feel comfortable drinking the water from the tank, that would simplify things. Isn't that what we are all about? Thanks!
Peggy is offline   Reply With Quote
Old 06-19-2011, 01:01 PM   #2
There's a pretty good process for sanitizing your water tank. I partially fill the tank then put about a cup of bleach in the tank fill the rest of the way. (12 gallon tank). Then pump the water through the system to the sink. Let it sit for at least 1/2 hour, but no more than about 2 hours. Drain and flush with at least 2 fillings to rinse out the bleach. Don't forget to pump enough fresh water through to plumbing until the bleach smell is gone.
I filter the fresh water through an RV ceramic/charcoal filter as it enters the tank to keep anything that might be in the fresh water out. I always carry the filter and use it while traveling also.
Old 06-19-2011, 01:29 PM   #3
Trailer: 13 ft Scamp
Hi Peggy,
I sanitize our water tank similarily to Byron, but use vinegar -- it's less toxic, kills nasties just as well, and doesn't require as much rinsing. I also towed the camper around a bit so the water would slosh in the tank. So far have only done this when we purchased our current Scamp as we fill it with our excellent well water only and drain it all when we return from camping. I'd probably only sanitize again if we had to fill elsewhere, or I otherwise suspected something was wrong, and your location could allow you to do this as well. I'm thinking warmer, more humid locations are more conducive to growing nasties.
Darnelle is offline   Reply With Quote
Old 06-19-2011, 01:47 PM   #4
My trailer is 23 years old... and so is the water tank. I've tried all manner of cleaning stuff and the water still smells like old plastic if it sits for more than a day or so. I don't mind using it for washing dishes, etc. but washing my face, brushing my teeth, cooking and making coffee... I prefer fresh bottled water. YMMV
Old 06-19-2011, 01:56 PM   #5
Donna makes a great point. Our tank water tastes good, but with the debate on BPA I wonder how safe it is?
Old 06-19-2011, 03:07 PM   #6
Barrie Bochoff's Avatar
Trailer: 13 ft Trillium (sold 1/1/12)
New Brunswick
My Trillium came with a 5 gal. tank connected by a plastic hose to a tap/pump at the sink. I disconnected it and removed the tank. I have a portable 5 gal. container, with tap, that I clean and fill before each adventure. I also have a 1 gal. insulated container that I use for regular use. When the 1 gal. container gets low I top it up from the 5 gal. I just didn't feel comfortable having water sitting in a tank nor in the lines. I don't find this arrangement inconvenient in the least.
Barrie
Barrie Bochoff is offline   Reply With Quote
Old 06-19-2011, 04:40 PM   #7
If you're concerned about plastic causing problems, hmmm, there's an a lot of food including milk and bottled water in plastic. Then of course there's plastic water pipe. Oh well...
Then there's worrying about water sitting in tanks or other vessels, wonder how much water there is sitting in water mains and how long it sits there before use.
Old 06-19-2011, 04:48 PM   #8
New Brunswick
Thank goodness I have a well, filter with water softener and reverse osmosis water purifier. Ahhh... just like bottled water.
Barrie
Old 06-19-2011, 05:40 PM   #9
Barrie
how long does water sit in the pressure tank before use? Do you run enough water to empty all the containers before use including that in the pipes?
Oh ya, Bottled water is NOT in plastic bottles, right?
Old 06-19-2011, 05:47 PM   #10
For me, it's not whether it's in plastic, but rather OLD plastic. I don't drink water from plastic water bottles that have been opened and sitting around for weeks either. IF I open a beverage that's in plastic, it gets put in the frig. Can't do that with a flippin' water tank. Perhaps, for my Scamp, it doesn't have water run through the system often enough. There are those who use their trailers a lot. So funky tanks and pipes aren't a problem for them, but it is for me.
Old 06-19-2011, 06:16 PM   #11
New Brunswick
Sometime, maybe just one time... you'll agree with someone. Nah... I guess not LOL
I don't drink bottled water. I don't have to. I purify my own. Ever heard of reverse osmosis? The water goes through the reverse osmosis system at the tap.... after the pressure tank. See... you learned something tonight. The bottled water I referred to was the contents of the bottle.... not the bottle. But then, I'm sure you understand.
Enjoy!!
Barrie
Old 06-19-2011, 09:51 PM   #12
Enjoy!!
Barrie
I don't think I disagreed with anybody. I was simply pointing out that water in your house, your trailer, and in public parks often sits in metal, wood, or plastic containers. So the fuss about fresh water tanks in trailers, in my opinion, is silly. We live in a paranoid world as it is and paranoia breeds like rabbits. Therefore my goal is to attempt to enlighten those that haven't yet to catch the paranoia, hopefully before they do.
Donna,
FYI,. new plastic out gasses much more than old plastic. So it would appear that you're more likely to get undesirable stuff from new than old plastic.
Old 06-20-2011, 04:56 AM   #13
Donna,
Perhaps Bryon, I haven't read any facts about that. For me it's about taste and smell. Old plastic in my Scamp does taste and smell funky. I thought for a long time it was because a previous owner had perhaps winterized using regular ole antifreeze, rather than RV antifreeze. After many attempts with bleach water and commercial preparations, I've come to the conclusion it's just aged (like me). Works for red wine, not so good for plastic.
When your trailer is 23 years old, and not less than 5... maybe you'll find the same thing...
Old 06-20-2011, 10:36 AM   #14
In this world I can't eliminate my family's use of plastic, but we do minimize it -- reasonable precautions without going crazy.
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 6 05-20-2011 08:19 AM
Sanitizing the Fresh Water Tank Jane P. Care and Feeding of Molded Fiberglass Trailers 3 02-16-2010 09:56 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
