SCAMP Bifold door
Just took mine off to do some flooring. Mine had the top track. At each end in the track is a door stop controlling the limit of the travel on the opening side and one to anchor the door at the pivot side.
The Phillips head screw holds the stop in the track. The one on the opening side is fairly easy to remove. The one on the pivot side is a bit more of a challenge. I connected several drill driver extensions to get some length and a bit of an offset and it came out fine. Then, just tip the door to remove it from the track. Remember, there is a pivot pin in the threshold. Good luck.
