Old 06-29-2012, 10:57 PM   #1
Trailer: 99 Scamp 16
Idaho
Scamp dinette/bed
What modifications have people done to their rear dinette/bed to make it more comfortable for sleeping? How much weight does the bed hold? Thanks!
John
camper1887 is offline   Reply With Quote
Old 06-30-2012, 05:49 AM   #2
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
My son is co-owner of my 1971 Boler and he took a piece of 3/4" OSB cut it to the full lenght to fit as a bed between the 2 seat bunks and then cut it so the table part is 3/4 the lenght of the original table and placed the 1/4 part against the wall and then when the table is set up you can get into the seats alot easier. He then mitered the edges and coated the OSB with thick polyurathayne and painted the edges black.
Rick Mooyman is offline   Reply With Quote
Old 06-30-2012, 06:54 AM   #3
Trailer: scamp 13
we find that a couple comforters is all it takes to be fine for sleeping,,but everyone has their own needs
Old 06-30-2012, 07:12 AM   #4
Trailer: scamp
scamp bed
My wife bought a piece of foam at walmart 30 and i cut a board from the piece I made the table out of that gives support to the edge.
koolperson2 is offline   Reply With Quote
Old 06-30-2012, 10:54 AM   #5
Added 3" of memory foam on top of mine and it made an amazing difference as far as comfort level.
Old 06-30-2012, 11:21 AM   #6
dylanear's Avatar
Trailer: 2001 Scamp 13'
I got a 2" topper of high quality natural latex foam and the back issues I was having when using a cheap polyurethane foam topper went away almost immediately. The poly foam started crushing down thinner in the middle the first night and had much less support where I needed it (like almost none) after a mere few weeks. Some polyurethane foams will last much longer, but latex is the stuff to get if you don't mind the cost. Poor quality poly foam is a complete waste of money. Not sure how to know which polys are better. Latex can last 20+ years I'm told.
And I stuffed various thin flat items under the table area (on the table top, under all the cushions) since it seems to sit a cm or so below the seats on either side.
Actually, the stock cushions were not that bad alone, just felt those gaps a bit. But bare stock cushions is better than with a foam topper with no support anymore.
I sleep like a baby in my Scamp since the latex topper!
dylanear is offline   Reply With Quote
Old 06-30-2012, 06:14 PM   #7
Ruthies Radiola's Avatar
Arkansas
After 5 years of too thin cushions and wandering foam toppers we bought 8 inch thick foam mattresses and replaced the cushions and sofa/ bunks for wonderful comfortable sleeping and when its raining we would rather lounge in bed with a good book or the computer, then sit at the table. Right now like most of the mid-south and west rain would be a welcome break from the heat and threat of fires.
Ruthies Radiola is offline   Reply With Quote
Old 06-30-2012, 08:07 PM   #8
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: 1990 13ft. Scamp Custom (L-Shaped kitchen counter top).
scamp dinette/bed
We use "Alps Mountaineering" self inflating air mattresses (the smallest ones) that back packers use. We leave them inflated under the cushions while in the dinette position, and then place them sideways (thats why we use the Smallest size) under the cushions while in the sleeping position. We had ordered them on-line. If you choose to store them, they roll up to approximately 6 inches and are placed in a stuff sack.
Happy Trails
Dave & Paula
Old 07-01-2012, 05:57 AM   #9
P. Raz's Avatar
Vermont
I removed the rear dinette and covered the space with a piece of 1/2" AC plywood. Added cleats on the bottom to keep it from moving and a stiffener on one end. Original cushions and a 2" memory foam topper make for a comfortable bed. It also makes it easy to get to the storage bins below. Raz
P. Raz is offline   Reply With Quote
Old 07-02-2012, 10:16 PM   #10
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
My wife and I now sleep head to feet and it's made a world of difference. That bed just isn't big enough for two adult shoulders to be right next to each other.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 07-10-2012, 04:32 PM   #11
Trailer: Scamp 16' side dinette
The head to feet is working for us pretty well too. I replaced all the factory cushions with new medium density foam in 4" thick like the stock ones. It is comfortable, but I wish we would have used 5" to be even better, since we had new covers made anyway.
Russ
ruscal is online now   Reply With Quote
Old 07-10-2012, 05:08 PM   #12
Trailer: 2006 Scamp 13'
Head to feet and sleeping bags works good for us. However, when we bought the Scamp we were pretty used to sleeping on the ground with about an 1" think Thermorest pad.
Byron Kinnaman is online now   Reply With Quote
Old 07-10-2012, 08:33 PM   #13
Mike T's Avatar
Trailer: Newby CT-13, 84' U-Haul Owner
Wisconsin
Ok, here's an idea....try finding a container or two that are the same height as your bed (take a tape measure to the store) and fit them in between the sink and closet. Then put cushions over them the same height as your existing bedding (no doubt you have enough from your camper or else buy some). Now you can sleep with your heads at the back of your camper and your feet pointed toward the front of the camper in between the sink and closet. Your feet really don't need much room but your shoulders have plenty! My wife and I love it! Also, go to Target or Walmart and buy a 1" or 2" piece of memory foam and cut it so that it lays over your entire bed. Now you won't feel any cracks in between your cushions and it will feel like your comfy bed at home! And when you're done sleeping you can put the memory foam in your new containers for storage and when you're camping you can put dirty clothes in the containers for storage till you have time to wash them at home. Voila! Tons of new storage!! And more roomy and comfy sleeping quarters!
Mike T is offline   Reply With Quote
Old 07-10-2012, 08:35 PM   #14
Administrator
Mary F's Avatar
Great ideas, Mike!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
bunk bed over rear dinette harms Modifications, Alterations and Updates 24 01-28-2011 03:45 PM
Bigfoot B19 Dinette Bed Modification Val & Kayla Problem Solving -- Owners Helping Owners 1 04-16-2010 01:27 PM
Easy bed/dinette mod: Trailswest Campster Bobbie Mayer Modifications, Alterations and Updates 4 09-17-2007 11:28 AM
Bunk bed over rear dinette Steph taylor Modifications, Alterations and Updates 15 08-16-2006 08:28 PM
Little more wiggle room for dinette bed Cindy and Kent G. Problem Solving -- Owners Helping Owners 8 08-14-2006 07:29 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
