Scamp Door Seal Glue Removal?? - Fiberglass RV
Old 12-28-2014, 10:30 AM   #1
TomK's Avatar
I'm about to change the open cell foam door seal on our Scamp to the new rib door seal. The original is falling off, but the two-sided tape or adhesive that held it on, sticks to the door frame. I'm wondering if anyone can recommend an effective solvent or remover to clean it off? I thought acetone might work, but was informed it can dissolve gelcoat Anyone use naphtha a.k.a. lighter fluid? Turpentine?
Our trailer is in storage so I can't try anything out very easily. I'll probably tackle the job at Scamp Camp in Sebring, FL in February. I know at least 3 others who may be doing the same thing.
Thanks in advance for any suggestions!
Tom
Old 12-28-2014, 11:24 AM   #2
David B.'s Avatar
WD 40 or Goof off work well in conjunction with a plastic scraper.
Dave & Paula
Old 12-28-2014, 04:20 PM   #3
honda03842's Avatar
Name: Norm and Ginny
Wd-40
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 12-28-2014, 04:23 PM   #4
TomK's Avatar
I have a small can of that in the camper tool box. Another use for a fantastic product. Thanks!
Tom
Old 12-28-2014, 08:16 PM   #5
Trailer: Scamp 2017 16-ft SD / FB
glue removal
I use a product call Goof-Off. Its great but be careful. Read instructions
Henry
Gattopuin64 is offline   Reply With Quote
Old 12-28-2014, 08:35 PM   #6
Just stay away from metal scraping tools! Metal can score the gelcoat. I've lost a couple of thumbnails scrapping my Scamp... fortunately they grew back.
Best of luck!
Old 12-28-2014, 09:21 PM   #7
I used Goo Gone! You need to make sure you get the plastic strip off first and then let the foo gone soak in for awhile. I recently discovered that vinegar works really well at taking of sticky tags so it may be worth a try as well.
Old 12-29-2014, 10:02 AM   #8
TomK's Avatar
Thanks. I'll pick up some Goo Gone or Goof Off as well. On Amazon the reviews are very similar, and they're both highly rated. I've been using lighter fluid all my life to remove sticker residue, but I'd rather be safe than sorry with our Scamp.
This is the "D" shaped seal that Scamp provided just prior to the new "Rib Seal" on the right. Either one is better than the open cell foam seal they were using, but the latest Rib Seal looks especially promising. Tom
Old 12-29-2014, 10:54 AM   #9
Trailer: Escape 21
Tom
What site will you be in/on? I will come over and lend moral support. 😍 I want to change out our door seal on our Scamp 5er. We will be in/on site 2.
Michael
Sent from my LG-V410 using Fiberglass RV mobile app
lijMichael is offline   Reply With Quote
Old 12-29-2014, 11:24 AM   #10
GOOD stuff there TomK! Love the new design and wish it had been around when I changed mine out! I'm glad Scamp finally decided to change it and if I understand correctly, they're putting it on ALL new Scamps out the door now??
The most trouble I had installing my door seal was the aggravating plastic strip left behind after removing the sponge. Maybe you guys at the Sebring "Seal-a-thon" will come up with some magic way to remove it. I left part of the strip on mine but after nearly 5 yrs, it's still holding.
Thanks for posting the pics!
Old 12-29-2014, 11:30 AM   #11
TomK's Avatar
You're more than welcome Michael. We'll be in site 026. We are going to be there from the 8th to the 22nd of Feb. (2 weeks). Order a new seal, and I'll be happy to help you as well. I've never been in a 19. I'd like to check that out while we're at it.
Tom
Old 12-29-2014, 11:40 AM   #12
TomK's Avatar
Darral, I'm told they are installing their new proprietary rib seals on new trailers now. It has to be a BIG improvement. Thanks for the encouraging words!
Tom
Old 12-29-2014, 06:49 PM   #13
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Just FYI -
The Scamp16L6 that Art picked up just the week before Christmas had the gray open-cell
foam seal on the door. 😢
rdickens is offline   Reply With Quote
Old 12-29-2014, 08:42 PM   #14
TomK's Avatar
Originally Posted by rdickens View Post
Just FYI -
Hi Ray, Art's must have been built before the new seals came in, I'm sure a phone call would take care of that. I've really had good luck with Scamp on warranty issues.
Tom
Old 03-06-2016, 02:38 PM   #15
Radar1's Avatar
Tom,
I'm just about to tackle putting my new seal in. Did any of the products you tried work better than the others?
Sharpsburg, GA
radar1-scamping.blogspot.com
Old 03-06-2016, 03:01 PM   #16
Originally Posted by Radar1 View Post
Tom,
Use Brakleen on a rag, don't let it soak very long, then clean again with Isopropyl Alcohol.
The original gasket is attached with what is ostensibly double faced scotch tape. peel as much of that as possible before cleaning the surface.
Goo Gone might work well on the tape itself but it is likely to leave a mess which the Brakleen will make short work of.
Old 03-06-2016, 07:57 PM   #17
Radar1's Avatar
Thanks Floyd,
Got the old seal and tape off, letting it sit overnight since no rain forecast, then another wipe and dry with the alcohol before putting it on tomorrow.
Sharpsburg, GA
Old 03-12-2016, 06:00 PM   #18
Trailer: 16' Scamp
Wyoming
I used rubbing alcohol to remove foam tape adhesive, leaves no residue to affect new adhesive.
Wyowill is offline   Reply With Quote
Old 03-13-2016, 01:31 AM   #19
MEK is available at Home Depot and will remove about anything. It is a commercial paint prep liquid.
Frank F
frankcfx is offline   Reply With Quote
glue for rubber weather stripping inside Trillium door Gail H Problem Solving | Owners Helping Owners 10 01-25-2013 09:15 PM
Fridge door seal - removal Scouter Dave Care and Feeding of Molded Fiberglass Trailers 7 05-07-2012 02:29 PM
Scamp Door Seal Parker Buckley Problem Solving | Owners Helping Owners 16 10-11-2011 09:55 AM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Seam tape glue removal Steve Smith Problem Solving | Owners Helping Owners 4 06-27-2009 10:37 PM
