Scamp Suburban furnace servicing - Fiberglass RV
Old 08-08-2016, 09:11 AM   #1
Ramsey's Avatar
Trailer: 16' Scamp
Wisconsin
Scamp Suburban Furnace Servicing
With fall approaching I decided to try my furnace. As expected, upon turning the thermostat on and turning up the thermostat up the fan kicked in, however, the heat never kicked in. I tried cleanilng the gas lines procedure as noted in the Surburban manual. Still no heat. I replaced the regulator since this is an older scamp (’93) and that can be a problem. Still no go. It’s looking like it may need servicing. The question becomes whether to remove the furnace for servicing or take the trailer to a rv repair shop. Anyone have a similar experience? It looks like a few rivets are attached on the front flange with not much else securing it???? Anyone have any experience with older Scamp furnaces
Thanks for any feedback….Ramsey
Ramsey is online now   Reply With Quote
Old 08-08-2016, 10:17 AM   #2
Carl Pa's Avatar
Did you set the thermostat past the temperature in the camper. Carl
Carl Pa is offline   Reply With Quote
Old 08-08-2016, 10:37 AM   #3
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Did you open the valves on the LP tank(s)?
It takes a while for the furnace to light.
First, it has to purge (blow out) any old gasses, then ignite the LP.
If no LP is present at the gas burner, it shuts down.
Old 08-08-2016, 10:38 AM   #4
Trailer: 2010 Escape 17B
When ours was doing that our thermostat on the wall was broken, that may not be your issue though but it is an easy fix if it is with a new one.
kootenaigirl is offline   Reply With Quote
Old 08-08-2016, 01:35 PM   #5
Ramsey's Avatar
Trailer: 16' Scamp
Wisconsin
yes the gas was turned on....lit the cooktop burners as well.
Old 08-08-2016, 03:50 PM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
Have you checked the battery voltage? If insufficient, the sail switch won't open to allow gas to enter the furnace and burn, and all you'll get is fan. A battery in decent shape and with sufficient charge should read something like 12.5V-12.9V.
If that checks out, and you have made sure there are no spider webs or such in the orifice, I don't know what else to try. Most folks take the whole trailer in for service, not just the furnace.
How to prepare Tofu
Step 2: grill some meat
Old 08-08-2016, 03:58 PM   #7
Ramsey's Avatar
Trailer: 16' Scamp
Wisconsin
Voltage checked out at 12.7. Whats the best way to access the orifice for cleaning?
Old 08-10-2016, 03:55 PM   #8
M Scott's Avatar
Trailer: 13 ft 2005 Scamp Deluxe; 2002 Subaru V6 Outback
I had similar furnace problems with my 2005 Scamp surburban; replaced thermostat, and took Scamp to RV repair....3 times! Post repairs, make sure the RV repair guy turns furnace on while you are watching to make sure repairs were actually done correctly. I also bought a ceramic portable electric heater for times camping w. power. Actually, I like the heater better - more quiet.
M Scott is offline   Reply With Quote
Old 08-10-2016, 05:25 PM   #9
Dudley's Avatar
Trailer: 1998 Casita 17 SD
1 Light you stove first to make sure that the lines have gas not air.
2 try firing up the furnace, if it doesn't light after a few tries, then I would pull the unit and check the sail switch as the gas will not turn on if the sail switch for the fan does not activate properly.
3 If that doesn't work you may have a plugged jet.
4 pull the unit and check for dirt and bugs
They are a pretty easy unit to take apart but if you are concerned about servicing it then yes have a tech check it out.
I did make up a doc showing how to change out to newer style fans on the Casita forum and have included it. It shows what screws you take out to remove the unit. BTW the newer fans are much quieter that the metal ones.
Sorry the pdf is too big to post, PM me if you want a copy
Old 08-11-2016, 07:20 AM   #10
Trailer: 1999 Casita 17' SD
Ohio
Our Casita has a Suburban furnace.
Sounds to me like the "sail switch" is not being operated when the fan is running. If the sail switch is not operated the gas will never come on.
Normally when the switch is operated the control board will turn on the gas and you'll hear a click of the gas solenoid.
Several things can cause this.
If on battery power the voltage could be low.
Blower motor might need lubricated.
Blower motor bad
Switch is hung up on something
Switch is bad
As I remember you can see the "sail" operate with the front cover off.
Joe
Old 08-12-2016, 04:27 PM   #11
Trailer: Scamp 13'
Massachusetts
Heater Fan Switch
Had the same problem. Found that the 'sail' switch was rubbing on the cabinet and not allowing the gas to turn on. The sail micro switch sits in the fan air flow, has a big tab on it that catches the air and has to close before the gas can turn on. If you take the front off, the 'sail' switch is located near the back lower left corner and can be seen with a flashlight looking between the inner housing and the outer housing (hopefully I remember its location correctly, its been years since). Check if it is free to move without restriction with a long piece of something. If you can't reach it, you will have to remove the heater (not a bad job - just the gas fitting, a few wires and a few screws) and check it. I took mine out and disassembled half the heater before I knew it existed and found the rub.
Good luck. Hope it is that simple
BillF is offline   Reply With Quote
Old 08-16-2016, 01:40 PM   #12
Ramsey's Avatar
Trailer: 16' Scamp
Wisconsin
Recap: Surburban furnace servicing
As mentioned in a previous post ...In order to start my furnace, i turned on the gas on the propane tank. I then lit the individual stove top burners to make sure propane was flowing. I then turned the thermostat on and adjusted the temperature until the blower kicked in. Heat was never generated while the blower was running for a considerable amount of time. I'm guessing it's a switch issue. Also, i did install a new Camco 2 stage regulator. This had been mentioned in serveral YouTube videos as a potential problem with the firing up of RV furnaces. Regulators have a tendency to begin to fail after 10-12 years. Still no heat.
Thanks for all the suggestions offered. Not sure I’ll tackle just yet. I did find a Servicing manual (pdf link below) It provides some useful info regarding many Surban furnace models. Included are the steps for removing furnace for various models
http://www.bdub.net/manuals/Suburban_Service_Manual.pdf
thanks, Ramsey
Old 08-17-2016, 12:14 PM   #13
Ramsey's Avatar
Trailer: 16' Scamp
Wisconsin
Bill,
thanks for your response. I located the sail switch it just as you described. The sail switch moved freely. It activated when the fan came on....just no heat. May have to pull the unit and have it serviced. thanks again for your thoughts.
Ramsey
Old 08-17-2016, 12:53 PM   #14
Ohio
Have you checked the sail switch yet?
No sail switch operation = no gas valve operation
Joe
furnace, scamp
Wanted: Scamp suburban furnace Rickl238 Parts: Buy | Sell | Trade 8 04-10-2014 07:17 PM
2005 Scamp 13' suburban furnace Jeff Larsen Problem Solving | Owners Helping Owners 2 08-17-2009 09:27 PM
Servicing Boler "Berdick" jalousie windows Raya Care and Feeding of Molded Fiberglass Trailers 12 05-14-2009 10:56 AM
Trailer servicing options, San Francisco Bay area egraham Care and Feeding of Molded Fiberglass Trailers 5 05-21-2008 04:36 PM
For Sale: Furnace"Suburban" 1976 Boler petramarc Classified Archives 0 04-22-2006 10:52 AM
