Scamp - Touching Up Chips on Fiberglass Interior Peices
Hi,
I have an older Scamp that has small and medium (nickle sized) chips out of the fiberglass pieces in the interior, mainly on the sink cabinet and closet pieces.
Has anyone had any luck finding a touch up paint to fill in chips in the interior fiberglass pieces? I'd like to touch them up versus painting the entire pieces if possible.
That makes sense. They're only as deep as the paint chipped off, so maybe a millimeter or two. After filling with a bondo, do you have a recommendation for what type of paint to use to touch up where you applied bondo?
Marine-Tex is a two part white epoxy which is a pretty close match to the Scamp gelcoat. Others use a white epoxy found at Home Depot, sorry I don't know the name of that product. But both products are good for filling voids and screw holes in Scamps.
"Use to fill gouges, chips, scrapes and deep scratches in the fiberglass gel coat. One Step Finish Gel Coat is a non-run, non-sag formulation of flexible polyester resins to produce resiliency and toughness. Evercoat Coloring Agents may be used to tint the material to desired color."
(What I use to fix the oopsies on my boat hull...)
