Scamp Wall-Carpeting in Bathroom? - Fiberglass RV
Old 02-13-2012, 05:57 AM   #1
Trailer: In the Market
Kansas
I was looking at the photos of the Scamp shower and found that they have the carpeting part way on the wall and the ceiling in the bathroom. Knowing what an enemy moisture can be, how does this area keep from molding over time? I am guessing the carpeting is treated but overtime wouldn't the chemicals break down and disappear? I am learning that comparing one egg brand to another is like comparing apples to oranges. Thank you.
Cathy P. is offline   Reply With Quote
Old 02-13-2012, 08:47 AM   #2
cpaharley2008's Avatar
I could be wrong, but some Scamps are toilets only and others have the toilet and shower combo. Perhaps you were seeing the toilet only set up?
Old 02-13-2012, 08:54 AM   #3
Kansas
Well, I saw 2 that were used and on the market but did have the shower and I had wondered if the shower had been added by the owners. I'll keep looking and maybe call Scamp and ask.
Old 02-13-2012, 09:05 AM   #4
The scamp 16' does have a shower and toilet combo - pretty common.
The (rat fur) material on the walls is marine grade so it dries fast and does not mold up. My 20 years old trailer has no mold issues. You will find that the material starts high enough up in the shower area that it rarely if ever gets wet when showering. I use the shower on mine often and its not an issue. After showering I do though leave the bathroom door open for awhile after to help the bathroom dry out faster though.
Old 02-13-2012, 11:04 AM   #5
honda03842's Avatar
Name: Norm and Ginny
Bathroom Mold
We've had a Casita and a Scamp. I'ver never seen any mold in the Scamp's bathroom and have seen plenty in our Casita's even though we never took a shower in the Casita. Moisture condenses on the Casita's walls causing mold. I think because there's no insulation between the inner and outer walls.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-13-2012, 11:06 AM   #6
Kansas
Thank you both for your responses.
I have an allergy to black mold and we had a big problem with stick-builts and the black mold despite all my efforts to keep it under control. This was in the southern states but I know it can crop up just about anywhere.
Old 02-13-2012, 03:40 PM   #7
Trailer: none
I personally dont know what Scamps "rat fur" is made of, but I do know with a extra piece I had it doesnt absorb moisture, and when torched it curls up like poly rope does, plastic? polyethylene? no old issues in my 96 either opps!!!! a lot of old issues with my Scamp....... meant to say no MOLD issues
Hambone is offline   Reply With Quote
Old 02-13-2012, 05:57 PM   #8
Trailer: Fiber Stream
A friend has an early 17' Casita Freedom Deluxe that did not have the bathroom roof exhaust vent installed at the factory. He ordered it to install himself, and found the wall carpeting that is in the rest of the trailer is between the inner shower wall and the outer trailer hull. He kept the 6" diameter plug that he cut out for the fan installation to show people the layers. He said that little circular vent exhaust fan made a world of difference.
Old 02-13-2012, 06:05 PM   #9
honda03842's Avatar
Thanks for the info Frederick.
With insulation between the two walls I'm surprised how moisture would build up on the inner walls and how black mold would develop.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-13-2012, 06:20 PM   #10
Question One possibility
I theorize that to prevent mold, ventilation is more effective than insulation.
The Casita's window alone is not enough, and the opening half is probably too low on the wall. The Scamp's window is higher. This might help create a chimney-like draw that a Casita without a bathroom roof vent lacks.
Old 02-13-2012, 06:31 PM   #11
Mike Magee's Avatar
Trailer: Li'l Hauley
I have my current trailer rigged up with a vent cover over the front roof vent and a cover with built-in fan over the rear bathroom roof vent. Both stay open all the time while the trailer sits in the yard. I am thinking that a trailer with such free-flowing ventilation would be hard pressed to grow mold. Maybe you can rig up something similar with whatever trailer you get.
How to prepare Tofu
Step 2: grill some meat
Old 02-14-2012, 03:34 AM   #12
Ed Harris's Avatar
To the point of the original question....The Scamp bath does have the Rat Fur exposed near the ceiling in the models with a shower.
It is a Marine Headliner material and thus nit supposed to mold but it seems like a stupid idea to me anyway?
Why expose the inside of the wall to possible water entry that you could not get too if needed?
In the Casita I have not experienced mold but if I did at least it will be easily seen and abated.
This is one of those things I have called Scamp about and asked and was told it is just the way they do it with no explanation at all. Seems like bad design to me though.
I also am amazed AGAIN that anyone who admits he has no idea makes a comment anyway about a question here?
I just can not see how this helps?
Ed
Old 02-14-2012, 09:16 AM   #13
Ed your right that when one looks at it you are left wondering why they did it but as suggested by those with older scamps it does work and mold does not seem to be attracted to it. I dont have an extra vent in the bathroom on mine - only the standard window. Due to the size of the bathroom and the shower head not getting the fir lining wet is not a problem so I suspect Scamp just figures if it works why change it.
Old 02-14-2012, 10:13 AM   #14
honda03842's Avatar
One of the most interesting thing I've learned is that much of what people do does work without anyone knowing the underlying reason why it works - take magnets or gravity as examples.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Cleaning interior wall fabric scamp. NW Scamp Problem Solving | Owners Helping Owners 4 08-07-2011 08:14 PM
Replace Carpeting keekers Modifications, Alterations and Updates 5 06-16-2011 07:23 AM
Scamp 13 wall covering Greg G. Care and Feeding of Molded Fiberglass Trailers 11 10-16-2010 02:36 PM
Carpeting On The Wall & Ceiling? Cathy P. General Chat 9 02-18-2007 07:47 PM
carpeting issue... Rarebird Problem Solving | Owners Helping Owners 2 12-04-2006 05:34 PM
