Scamp with shower question? - Page 2 - Fiberglass RV
Old 03-24-2013, 11:22 AM   #15
Trailer: Casita 17 ft DLX SD
Same problem Same solution
Originally Posted by Ron in BC View Post
Thanks for posting the question. I went out to my trailer to check something before answering your question and discovered the screw holding the strap that holds the pump had pulled out. No biggie but I'd rather have the pump supported by the strap than the hoses.
Scamp wiring ,how can I say it politely, sucks. They use twist connectors with abandon. I just undid the ones on my water pump and could see some corrosion.
So: all connectors and connections are suspect. The first thing that I do in this situation and yes, I am serious, is, with the switch on, give the pump a couple of good thunks (technical term). On my 13 the back of the switch and the terminals are accessible from the locker. I'd check for voltage at the switch. I'd also check the wires under the trailer by the pump as there's probably some connections there. If so, undo each one and scrape the corrosion from the wires.
Electrical items sitting unused often don't function after a period of time.
Try the above items and it's likely you'll find the problem
Good luck
The pump on my 16 ft SD did not work so I thunked the motor and replaced Scamps less than professional wiring. I soldered the wires and covered the splices with shrink tube designed for wet locations oh yah I had to remount the pump motor too.
Shower Question Tezha Plumbing | Systems and Fixtures 12 09-14-2010 10:28 PM
Trailer shower drain question? Randya Problem Solving | Owners Helping Owners 13 10-09-2008 05:07 AM
want Scamp with shower Craig,B Wanted: Molded Fiberglass Travel Trailers 4 07-21-2008 02:12 PM
Shower in 13 Scamp LeBoutillier Modifications, Alterations and Updates 6 03-10-2006 02:42 PM
want Scamp with shower Craig,B Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
» Trailer Showcase
Home Built
OhTom
Burro
CraigS
