screen door on Burro - Fiberglass RV
Old 08-11-2009, 01:47 PM   #1
Hi, This is a question about my recently acquired Burro 17' screen door, but other maker's doors may be the same.
On my Burro's screen door, there's a lever that you press down to open. There also appears to be a way the screen door can latch to the main door, so that the two can open as a single unit. However, at the main door, there's something missing that the screen door is suppose to latch onto. I can tell it's missing because there's 2 holes in the door where something use to be. Does anyone have a picture as so what this missing part is that the screen door latches onto.
Both doors work fine, but the issue is I have to open the main door then open the screen door. Having to open 2 doors gets old and there does seem a way to connect them together so I can open both doors in one shot. Don't know if my description is clear, I can try to get a picture later at home.
ThomasE is offline   Reply With Quote
Old 08-11-2009, 02:27 PM   #2
pjanits's Avatar
Trailer: 17 ft 1986 Burro
I believe the 2001 and maybe the 2000 Buro used a common flat door/screen combo. You probably can look at any newer RV out there to see how it's set up. Parts I'm sure available from any rv parts place.
Us older model year trailer folks have a more custom door setup usually without screens.
burro
bug off screen door Karalyn Modifications, Alterations and Updates 17 04-09-2015 09:35 PM
Screen door for Burro Legacy Posts Modifications, Alterations and Updates 28 06-18-2012 04:40 PM
new screen door! Bud Kennedy Care and Feeding of Molded Fiberglass Trailers 5 07-12-2010 09:01 AM
New screen door! April Wilcox Modifications, Alterations and Updates 10 09-09-2009 11:51 AM
screen door james kent Modifications, Alterations and Updates 15 04-06-2006 08:42 PM
» Trailer Showcase
Nadine
srndpte
Scamp
Gilda
