Shore Power works and part of the 12v side does too - Fiberglass RV
Old 09-10-2015, 11:21 AM   #1
Got a dilemma... When I pick up my scamp, everything was working but the battery was on it's last legs. I put a new deep cycle battery in and now only the 12v lights on the lighter fuses (10a) work. The one fuse that is 25a keeps blowing every time I put power to it. tried various ways; put fuse in and then hook up battery, put the fuse in when battery already hooked up.... What I can tell is that the heavier fuse runs the water pump, furnace, (may run the fridge, not sure) and one 12v light. Any thoughts? BTW, I can hook the battery up either way and the other 12v lights work. When hooked up to shore power, everything works fine.
SteveZimmerman is offline   Reply With Quote
Old 09-10-2015, 12:03 PM   #2
John Linck's Avatar
Madison, Wisconsin
Nothing in your Scamp draws 25 amps, unless you have an aftermarket inverter (not converter). I think you have a short somewhere. You can trace it down with a continuity tester, about $10.00. This one should work great. Probably $5.00 at Harbor Freight. God bless those Asian factories.
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 09-10-2015, 02:14 PM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
Are you sure you have the battery cables on correctly?
Charlie Y
Old 09-10-2015, 02:17 PM   #4
Charlie, yep, I tried them both ways. The weird thing is, the lights work either way I hook up the battery.
Old 09-10-2015, 04:26 PM   #5
If you have the stock Scamp wiring for the battery the white wire should go to the negative pole on the Battery. The Black wire should go to the positive pole on the battery. The positive wire may have a fuse on it near the battery and there may be another one right inside the trailer where it enters the fiberglass shell. If you hook it up backwards as you admit you did in one of your alternate connections you may also blow a fuse in your AC to DC converter if you have one. Also check to see if you have a reset button or breaker that may need to be reset on your power converter. Also do not hook up to your car until you get your wiring working properly as a crossed connection could cause allot of damage in your car.
Old 09-10-2015, 04:32 PM   #6
This is what happens when somebody that doesn't know what they're doing and attempts to fix electrical problems. The cost of repair goes up and up. If not real heavy damage to the trailer.
Take the trailer to real electrician that understands RV trailer wiring. The more you mess with the more it's going to cost you.
Old 09-10-2015, 04:41 PM   #7
Trailer: Casita 17 ft DLX SD
Not very sympathetic. but honest an accurate.
Wires are color coded for a reason and flopping them after
the damage is done usually does nothing to solve the PROBLEM.
Old 09-11-2015, 07:22 AM   #8
Thanks for all the input. Turns out that it was a matter of pushing the 120v circuit breakers ALL THE WAY DOWN instead of just flipping off into the "popped" position. Everything is working fine. Note to self in Spring: Black to +, White to -.
Old 09-11-2015, 08:13 AM   #9
Trailer: 1999 Casita 17' SD
Ohio
Steve.
Casita puts a sticker inside the door of the battery compartment.
Better then a "note to self".
Joe
Old 09-11-2015, 08:16 AM   #10
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
good
MRClaus is offline   Reply With Quote
Old 09-11-2015, 08:52 AM   #11
John Linck's Avatar
Madison, Wisconsin
Wow! I'm confused. I don't understand how the position of a 120 volt breaker could cause a 12 volt, 25 amp fuse to blow. Any ideas?
Old 09-11-2015, 09:17 AM   #12
Ohio
John
The 12 volt 25 amp fuse may have blown if/when the battery was hooked up backwards and tripping the 120 VAC circuit breaker at the same time.
When these breakers trip it's not real apparent they are tripped.
Old 09-11-2015, 02:15 PM   #13
I took some 3M # 35 red phase marking tape and marked the positive battery lead red.
I took some 3M #88 and marked the negative battery lead black.
I taped the wires for about 8" starting at the crimped on lug that attaches to the battery.
Reversing the polarity causes too many issues that to me permanently marking the wires is better than a note to self
Recharging battery and shore power Ellpea in CA Care and Feeding of Molded Fiberglass Trailers 13 08-07-2015 02:43 PM
Does shore power charge my batteries? - '80 Fiber Stream KSM Electrical | Charging, Systems, Solar and Generators 15 07-24-2015 05:19 PM
I have a 12v fan I want to run on shore power Dietrich Modifications, Alterations and Updates 8 08-31-2014 07:57 PM
Short on 110V, but 12v works? Garyscamper Electrical | Charging, Systems, Solar and Generators 10 02-16-2014 02:49 PM
76' Surfside - Does the battey charge when shore power is plugged in? dannis Problem Solving | Owners Helping Owners 2 05-26-2012 07:36 AM
