Shower? - Fiberglass RV
Old 04-17-2018, 08:45 AM   #1
BOBSMITH's Avatar
Trailer: 2002 Casita Freedom Deluxe / 2007 Nissan Frontier King Cab
Shower?
The pipe leading from the shower to the trap has gotten brittle and I need to replace it. How should I go about putting in a new one? 2002 Casita FD.
BOBSMITH is offline   Reply With Quote
Old 04-17-2018, 05:03 PM   #2
My suggestion would be to talk to Larry Gamble at Little House Customs. He has a lot of experience with these issues and I'm sure he can hook you up with whatever you need to get you fixed up and running again.
Store | Little House Customs
Old 04-17-2018, 06:45 PM   #3
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
Are you talking about the flexible p-trap? Usually grey or black in color? If so you can usually find a replacement at Home Depot or Lowe’s. But you should consider changing to a Hepvo valve. Parts and instructions available at Little House Customs.
brian
2003 Casita SD 17'
https://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
Old 04-17-2018, 08:16 PM   #4
BOBSMITH's Avatar
Pipe.
Nope. Not the flexible trap, but the plastic pipe to which it's attached that leads to the shower. It has gotten brittle and is cracking. The trap is fine.
Old 04-18-2018, 02:34 AM   #5
Trailer: Boler 13 ft
Sounds like a basic plumbing problem that can be fixed with parts from any supply store or big box store. It will a be tight space to work in but pipe and a couple of repair coupling that go on with hose clamp should fix you right up.
Old 04-22-2018, 11:52 PM   #6
BOBSMITH's Avatar
Thanks!
Yeah, I finally got it fixed up. It was pretty simple once I got to work on it.
The portable shower Ken James Modifications, Alterations and Updates 19 01-06-2017 08:43 PM
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
No shower> Add a shower Ken C Modifications, Alterations and Updates 9 09-01-2013 12:25 AM
