03-10-2008, 07:10 PM
Trailer: Scamp 16 ft Side Dinette, Front Bath
Las Cruces, New Mexico
 We have been wanting to do something to the shower side door of the bathroom in our Scamp. The brown finish from the factory is a flat, dull, lifeless, drab color and seems as if it would not be very good of shedding water if splashed, nor be very good at keeping the damp from the shower from soaking into the material. It seems like it would be good at absorbing mosture like a sponge.
My wife was thinking we should cover it with a marine varnish, I was thinking maybe a good enamel paint would work? Has anyone out there painted their bathroom door, did you use varnish or enamel paint? What should work better at keeping the moisture out of the door material?
03-10-2008, 08:40 PM
I don't know anything about painting the bathroom door, but I can tell you the door does absorb water. It absorbs water to the extent that it changes shape and has difficulty latching in humid weather.
Has anyone else painted / varnished the bathroom door?
-- Dan Meyer
03-10-2008, 09:34 PM
Trailer: 1981 Trillium 5500
Interesting discussion... my Trillium has a vinyl-covered door and I think it'd be just fine with a bit of water if we wiped it off. What's really nice is the curved metal rack just inside three walls, including the door that allows me to put up a cheap plastic shower liner that prevents water from hitting the door. If you paint your door a spiffy color, you might consider this kind of option to keep it looking nice. Helen
03-11-2008, 12:00 AM
I second Helen's motion! Our Casita came with a shower curtain to completely cover the entire door area including the bath towel on it's rack on the inside of the door.
Since your door is apparently already painted, I don't see any advantage to using varnish. Make it any color that suites your fancy!
Have fun and enjoy your creativity!
Ann & Kurt K.
03-11-2008, 05:17 AM
I've seen a side-bath Scamp with a piece of Formica glued to the door. And, the shower curtain should completely cover the door. Then no problems with water!
Double Yolk
1988 16' Scamp Deluxe
03-11-2008, 07:26 AM
Trailer: Burro 17 ft Widebody
My 1999 Burro 17 has a glass shower door-no problems.
Gail T.
03-11-2008, 09:04 AM
i would also suggest putting formica on the door... I personally dont like a shower curtain .. only because it cant be dryed off to well and will mildew.. i use a squeegy on my walls after i get done with my shower... and wipe it dry and must as i can....
03-11-2008, 07:27 PM
Ann & Kurt K.
No, it is not already painted, it has what seems to be a stain on the wood. They came with a curtain which keeps the shower from splashing the door and we use it to do so. However, often times after using the shower it is damp and humid in the bathroom for some time. We are wanting to keep the wood from absorbing moisture. We have added a second shower curtain to keep the "head" (toilet), the floor and walls behind it dry. I agree with Christi V. about not liking a shower curtain(s), but can not see how not using them would work for us.
Some on another Forum suggested Thompson Water Seal. I still not sure between a good coat of enamel paint of a marine varnish or a water seal.  I am still thinking of painting. The "a piece of Formica glued to the door" should also work, but perhaps with more work involved and tweeking of the door to compensate for the thickness of the formica to keep it latching after closing. I am not a good tweeker.
03-11-2008, 07:49 PM
Trailer: 1994 19 ft Scamp 19 ft 5th Wheel / 2001 4wd 6cyl Silverado
Hi I bought a 94 fifth wheel about 6 years ago and the previous owner had painted the inside of the shower door with imron by dupont, paint , I believe it is a single stage paint with activator. he did a great job Paul
03-11-2008, 09:52 PM
I'm planning on replacing the shower door with something completely different, something that allows ventilation into the bathroom so our towels, which will hang inside the door, can dry out and the bathroom say warm with the rest of the trailer on colder nights. The new door will resemble a panel-style door, with punched aluminum panels, a center spoke made from a curvy Ikea mirror cut to the correct height by a local glass shop, and wood stained to match the cabinets I made for the loft.
(Not to proportion)
--Peter
03-12-2008, 08:31 AM
Trailer: TrailManor (Gone to the Darkside)
My first instinct would be to use polyurethane - a minimum of 4 coats or so. The first one only seals pores in the wood - you don't really start getting coverage till the second coat. I've had very good luck using polyurethane to repel water at home (coffee tables and such).
Second line of defense would be similar to the formica suggestion - but I'd lean toward using a piece of FRP (sold in 4x8 panels at big box hardware stores). It's made for commercial bathroom walls and the interior walls of walk-in fridges and freezers. I wouldn't cover the WHOLE door, but only the part that's inside the jam - so you don't have to rehang the door. Trimmed out (again - hardware store) it looks pretty nice. It's the same stuff I used to essentially rebuild the side closet of the Boler we had. It came with a HUGE hole bashed into the side of it so I sheathed it in FRP. Looked great.
Mike
Watters
03-12-2008, 09:26 AM
My husband builds wooden boats so we are familiar with wet wood. Do you have access to a marine supply store? Get something called "West System" epoxy. Very easy to use and will waterproof your door. If you warm up the door with a hair dryer or hear gun before using the epoxy, it will penetrate the wood to a deeper degree. It goes on with a brush or foam roller. You can then paint over the epoxy to your color choice and add an extra barrier to the water. Personally varnish looks nice, but fails faster than paint in the long run. You can get paints with mildewcide in them now which will help in the bathroom. Get some latex gloves because epoxy can be a bit messy and not good for the skin. Ventilate well too. Our boats don't leak with epoxy coatings on them.
03-13-2008, 09:42 AM
West Coast
From another Burro owner... have you considered installing a frosted glass door?
When I got my 17, I didn't think much about it other than. "Oh, a glass door. That's nice." (yawn) but I have learned that it is a tremendous asset, not only for what you intend, but in letting more light into the rig during the day!
With a side bath, the only light that gets into the center area of the rig is limited.. the small kitchen window and the roof vent, but the light that hits the glass door from the bathroom roof vent really brightens it up! The frost acts as an amplifier. At nite, leaving the bathroom light on (When there are hook ups, of course) casts a nice ambient glow and it is very pleasant.
I am sure a bathroom supply place has a skinny one that might fit, and with glass, you would never have to worry about rot again.
I DO use a shower curtain, just so I don't have to clean the glass after every shower. It is easy to install and consumes only seconds of time to pull over. It gets pushed aside like any other curtain and lives behind the toilet when not in use. Doesn't get in the way at all.
03-13-2008, 09:47 AM
Any good custom glass shop can make a shower door to any size you want.....
| Thread Tools |
| Display Modes |
No events scheduled in the next 365 days.
