Silicone caulk problem - Fiberglass RV
Old 06-16-2018, 04:57 PM   #1
Trailer: Scamp 5th wheel
I would like to refinish my Scamp, paint or gelcoat. My problem is that someone smeared silicone around every bolt and rivit on it. Anybody suggest a solution.
patsublett is offline   Reply With Quote
Old 06-16-2018, 05:39 PM   #2
Take a very sharp raiser blade and very carefully try to remove it.
Old 06-16-2018, 06:00 PM   #3
I believe that there is a chemical remover for silicone. Might be in a spray can.
Old 06-16-2018, 06:41 PM   #4
Trailer: 1977 17' Boler
Saskatchewan
Hi patsublett, I had the same problem around my windows. A razor may scratch you finish but be helpful in lifting off big glops of silicone. Mineral spirits on a cloth worked the best for me. Try applying on a few rivits on the roof where it won't be noticed and see how it goes. It worked fine for me, but each case maybe different
Boler77 is offline   Reply With Quote
Old 06-16-2018, 07:01 PM   #5
Originally Posted by Boler77 View Post
... A razor may scratch you finish but be helpful in lifting off big glops of silicone. Mineral spirits on a cloth worked the best for me. ...
Yes a razor blade will scratch the gel-coat if you are not careful, but it can work to safely get off the majority of the silly cone caulk off, but only if you are careful. Then, various solvents will soften the silicone, mineral spirits and pro-strength "Goof-Off" being two good choices. Soaking a rag with them and leaving them on the caulk for a few minutes is sometimes suggested. Then use soft tools such as plastic knives to scrape away the rest (without gouging the finish). It will take some time and effort. Last, I would use acetone on the gel-coat (but nowhere else).
It is mostly mechanical removal of the caulk (elbow grease) along with softening the most stubborn bit that never seems to want to come off.
Old 06-17-2018, 06:55 AM   #6
Thanks to all
Old 06-17-2018, 07:49 AM   #7
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Go to the paint department of your local hardware store. They should have plastic razor blades. They look just like an old fashioned single edge blade. They usually come with a handle and are used for scraping.
Old 06-17-2018, 02:12 PM   #8
Trailer: Sprinter 'til I buy
Denver, CO
Wear rubber gloves using solvent, or you could end up like me.
Tom 72 is offline   Reply With Quote
Caulk silicone on top of butyl tape ? Yes or no JRC Problem Solving | Owners Helping Owners 12 10-11-2017 10:56 PM
Caulk, Window & Door Question V'sGlassSleeper Problem Solving | Owners Helping Owners 5 07-25-2007 10:45 AM
which caulk to use Isaac Problem Solving | Owners Helping Owners 1 06-06-2007 11:31 PM
The old seam tape-vs-caulk question Legacy Posts Problem Solving | Owners Helping Owners 3 06-01-2003 08:28 PM
Police your caulk lines Legacy Posts Care and Feeding of Molded Fiberglass Trailers 13 11-06-2002 08:58 AM
» Trailer Showcase
Atlas
Phano
Ventura
redwine
