Small rotted section of floor in scamp - Fiberglass RV
Old 10-29-2015, 07:59 PM   #1
Trailer: 1979 Scamp 13'
I have a 1979 13' Scamp, with what appears to be a great floor with no water damage...except I found a tiny bit when poking beind the fridge. It is less than 6"x6" in size, right in the corner next to the wheel well behind he fridge.
I'm thinking a plumbing leak is the most likely cause? It could the fridge have caused it?
Anyway, how should I best remedy this? Can/should I use wood hardener (I've used it on many an old house part in restoration), cut out and patch, or what?
Zennifer is offline   Reply With Quote
Old 10-30-2015, 04:08 PM   #2
Ohio
rot under water tank
I have some ideas on repairing this but would love some input from someone with experience.
Thanks in advance
cmartin748 is offline   Reply With Quote
Old 10-30-2015, 07:54 PM   #3
Borrego Dave's Avatar
Trailer: Casita SD17 2006
If it was me I would use the hardener as this is a very small area, is not structural and doesn't get walked on.
Old 11-03-2015, 07:42 PM   #4
That's what I'm thinking, too.
Now, any ideas on how to track down the exact source of the leak causing the issue? Could be the venting for the fridge needs revealed, too, right?
Old 11-12-2015, 09:02 AM   #5
Iowa
Had similar problem and used a rotted wood repair kit from home depot. First scraped out all rotted wood which made hole much larger, then treated it with liquid hardener from kit. I also screwed a larger than hole size patch from underneath trailer then applied the putty like epoxy patch to fill hole and smoothed it even with surface. After it dried painted area with a primer and no new problems after 2 years, can't even tell there was a repair from above. One more step to consider is treating whole area that was wet with bleach or better yet something meant to kill all mold before you start.
jjohn is offline   Reply With Quote
Cross section of Bigfoot Floor? Gary S. Modifications, Alterations and Updates 6 07-05-2012 03:57 PM
No wonder the Burro floor is rotted Andy B Care and Feeding of Molded Fiberglass Trailers 93 06-30-2012 09:32 PM
Removing the rotten section of floor BigMike Problem Solving | Owners Helping Owners 2 05-10-2011 03:52 AM
ripping out rotted floor..... LaurieK Problem Solving | Owners Helping Owners 6 06-06-2008 06:39 AM
replacing rotted floor section Isaac Problem Solving | Owners Helping Owners 9 12-10-2007 06:59 AM
