Snap caps and fridge control access - Fiberglass RV
Old 10-14-2006, 10:09 AM   #1
I can handle simple tools, but will never be mistaken for a mechanic.
1. Doing my annual Casita wash and wax, I noticed several of the plastic rivet snap caps have broken off. I know they can be replaced, but meanwhile… Is this purely cosmetic, or am I likely to get rain leaks if I don’t replace them promptly?
2. The control knob (AC – DC – GAS – OFF) on my Dometic Americana 4 cf fridge broke off. It looks like part of it is still attached, so I can’t just replace it, I need to get access to remove what’s left of the old one. I use a small nosed vise grip for now. I believe the control panel cover is supposed to swing out and up – there are locking tab releases underneath – but the Casita (2003 17 SD) installation prevents that with two rivets and a caulk seal to the fiberglass enclosure. How do I get it open without damaging anything, or should I just take it to an RV repair shop?
Thanks much for any help!
Bob Smucker is offline   Reply With Quote
Old 10-14-2006, 11:11 AM   #2
Suz
Suz's Avatar
I suppose it's possible to get leaks if they weren't sealed, but my main concern would be the quick demise of the snap rings if they are still on there. A little dab of clear RTV sealant and pop a new cap back on and you are good to go. If you wait too long and the snap rings go, you are talking a lot more work.
Sorry, I have an old 16', so I can't help with the fridge thingy.
Good to see you.
Suz is offline   Reply With Quote
Old 10-17-2006, 01:54 PM   #3
Bob, there may be something in the Document Center to help with the refer problem:
Document Center - Manuals - Refrigerators
Old 10-17-2006, 03:17 PM   #4
Bob,
The part you're talking about does not swing out and up. To remove it, drill out the two 1/8" rivets and cut through the silicone. To replace it, re-rivet and caulk.
You should not have to remove it to get that knob off. Just pull (it's very tight) straight out and press the new one back on. Order a new knob from Casita.
I sugest you edit your profile to add your trailer manufacturer and type: model, year and length. Click on My Controls at the top of this page.
Morgan is offline   Reply With Quote
fridge
Snap Caps: to cover rivets bbuehler Care and Feeding of Molded Fiberglass Trailers 4 12-04-2009 07:10 PM
Replacing snap caps on Scamp karen lm Care and Feeding of Molded Fiberglass Trailers 7 09-28-2009 12:08 PM
FREE snap caps Christine P Classified Archives 2 06-16-2009 08:43 AM
snap caps info needed Ricky 4 Problem Solving | Owners Helping Owners 5 02-07-2009 10:11 AM
How to replace snap caps? Scott Bacon Problem Solving | Owners Helping Owners 17 06-05-2006 08:23 AM
