snow load on roofs - Page 3 - Fiberglass RV
Closed Thread
Old 02-13-2014, 05:54 PM   #29
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
You certainly can't increase the total weight of a given volume of snow by melting it. Carol may have and Francesca may have but God bless the child who knows this ain't so (you know who you are). Of course the residue of a month or two of snowfalls and freezing rain may present as a depth on the roof not much greater and in some cases less than the first powpow of the season.
jack
rabbit is offline
Old 02-13-2014, 07:54 PM   #30
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
jack
Say what??????
Please take a moment to review my posts on the subject, quoted below...no skimming this time, please...
First I said:
The only way for snow to get "heavier" as it melts is for more snow or rain to fall on it, thus adding more water.
There may be an added danger to roofs as snow melts if it causes pooling somewhere on the roof, though.
Next, my response to Carol's assertion below:
.. snip... my comment was in response to your general comment...that although snow does increase in density its "total load" doesn't increase, which isn't correct.
Yes, it is.
Density is a unit of measure and load is a unit of weight- if speaking of "totals", neither has any effect on the other.
...Well?
Francesca Knowles is offline
Old 02-13-2014, 08:25 PM   #31
rabbit's Avatar
Delaware
I'll make this easy. You win. "Load" is not a unit of weight so maybe it's offsetting penalties. Who cares?
jack
rabbit is offline
Old 02-13-2014, 08:49 PM   #32
jack
With all due respect Jack I am going to suggest that you re read my post 10 which was the point I was attempting to make - the snows water content can increase and the weight goes up - doesn't need to melt or an increase in snow volume to happen.
Carol H is offline
Old 02-13-2014, 09:31 PM   #33
cpaharley2008's Avatar
anyone got any popcorn?……...
Jim
Never in doubt, often wrong
cpaharley2008 is offline
Old 02-14-2014, 06:12 AM   #34
Raz
Raz's Avatar
Vermont
F=mA
If 12" of snow compacts to 8", no melting, no evaporation, despite the change in density there is no change in mass. Unless the acceleration due to gravity changes , the force (weight) is constant. If you could weigh the snow then melt it and weigh the water, you'll get the same value. Raz
Raz is offline
Old 02-14-2014, 06:22 AM   #35
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
NO! NO! NO! NO!
Spanke
Trilliums Rock!
Spanke is offline
Old 02-14-2014, 08:37 AM   #36
LOL I give up!
Carol H is offline
Old 02-14-2014, 08:54 AM   #37
jgraps1958's Avatar
Trailer: 2013 Scamp 16' 2012 Jeep Wrangler JK 4 Door
Lancaster County Pa
WOW !!!!! That Reagan pic is great !! I will remove the snow as soon as I can get to it. If it caves in that will be a tragedy but I do have insurance, paid a year in advance.
jgraps1958 is offline
Old 02-14-2014, 09:03 AM   #38
Nate R's Avatar
Trailer: 1981 Casita 13. TV: 2011 Honda CR-V
Wisconsin
I went and read it. The DENSITY goes up. THere is NO new weight. You conveniently omitted the portion that talks about WHY the density changes.
From your link:
Once the snow is on the ground, it will settle under its own weight (largely due to differential evaporation) until its density is approximately 30% of water. Increases in density above this initial compression occur primarily by melting and refreezing, caused by temperatures above freezing or by direct solar radiation. In colder climates, snow lies on the ground all winter. By late spring, snow densities typically reach a maximum of 50% of water.[39
So, again, the total weight does NOT go up, just the density increases
Nate R is offline
Old 02-14-2014, 10:04 AM   #39
LOL - clearly I haven't done well at making what was my original intent of commenting on the topic of snow loads on roofs of fiberglass trailers.
My last attempt - promise! The weight and density of any square foot of snow is not consistent in weight! Its weight, density & ultimately the total load on the roof of a trailer depends on the % of water content of the snow, wether that be at the time it falls or through other environmental factors resulting in it compacting down. The weight and density of a foot of high water content snow on a square foot area of a roof will have a higher density & can and will outweigh a foot and a half of the light fluffy lower water content snow on the same square foot of roof.
Bottom line being no one can say oh there is only a foot of snow on my trailer and it was fine with that last year and believe it will be the same this year as the weight of a foot of snow and thus the total load on the roof can vary greatly. Simple as that.
Carol H is offline
Old 02-14-2014, 10:45 AM   #40
David Tilston's Avatar
Yup, this has been entertaining. Who's on first?
David Tilston is offline
Old 02-14-2014, 11:07 AM   #41
Raz
Raz's Avatar
Vermont
Originally Posted by Craig Broughton View Post
Just trying to save a owner form some springtime grief, his trailer had full sunlight from the south and as the snow melts the load gets heavier.
Snow usually does become much heavier as it melts. As it melts the moisture content can/will increase thus making it much heavier even though it may look like less volume.
There is no increase in moisture as the snow compacts. While the amount of moisture per unit volume changes (increased density), the mass does not. The number of molecules is the same, they simply get closer together. Again F= mA. If the mass doesn't change and the acceleration due to gravity doesn't change, then the weight doesn't change.
If you have a kitchen or postal scale, weigh a container of snow. Let it melt and weigh it again. The puddle will weigh the same. Raz
Raz is offline
Old 02-14-2014, 11:43 AM   #42
rabbit's Avatar
Delaware
I reread the writes and I read the rewrites. This has led me to believe that we're all on the same roof, something that wasn't clear to me initially. I found Carol's #39 a prize winner for clarity. I apologize to Francesca and Carol for mistaking the content of their argument for that of whichever yahoo (you know who you are) introduced us to the amazing alchemical snow. Can I send you a nice bottle of Cupcake to say I'm sorry?
jack
rabbit is offline
Closed Thread
Snow build-up on fiberglass roofs General Chat 5 02-14-2014 05:43 PM
Snow. Really. SNOW. S-N-O-W fusedlight General Chat 42 05-03-2013 06:47 PM
load capacity Bigfoot Jody Petersen Problem Solving | Owners Helping Owners 1 06-16-2009 04:08 PM
Load helpers/ Air Bags/ Timbrens Taylor Kissinger Towing, Hitching, Axles and Running Gear 2 03-15-2009 04:11 PM
Prep for snow load on roof? Donna R Problem Solving | Owners Helping Owners 14 10-21-2008 09:35 AM
