snow load on roofs - Fiberglass RV
Closed Thread
Old 02-10-2014, 04:17 PM   #1
Trailer: My 4th Trillium
Winnipeg
snow load on roofs
I stopped in on a local trailer in Winnipeg (River Heights) area and reminded the owner to clear the snow load off his vintage boler,he {Mike} said that it was his wifes and that he had not thought of the snow load and thanked me.
Just trying to save a owner form some springtime grief, his trailer had full sunlight from the south and as the snow melts the load gets heavier.
Craig Broughton is offline
Old 02-10-2014, 05:05 PM   #2
AND, all that snow on top may very well exceed the rating of the axle. Nice of you to stop and remind the owner!
Donna D. is offline
Old 02-10-2014, 05:14 PM   #3
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
My brother doing just that on my mom's Bigfoot.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Most folks are about as happy as they make up their minds to be. Abraham Lincoln
Jim Bennett is offline
Old 02-10-2014, 09:32 PM   #4
Marv Watson's Avatar
Trailer: 1978 Trillium 13 ft
Great Lakes area-US
Here in mid-Michigan, I've done 3 times now what you show your brother doing - just about that amount each time! Should've gone to souther AZ this winter.
Marv Watson is offline
Old 02-11-2014, 04:40 AM   #5
CampyTime's Avatar
Trailer: Scamp 13' Standard
Here in Western NY, I've been on the ladder like Craig's brother oh about 2 times per week since January. My neighbors probably think I'm a kook...can't recall this much snow since I was a kid! I guess I wasn't sure if the roof prep for the A/C would be enough support, so it's better to be safe than sorry! Do owners of stick trailers and rigs worry about this sort of thing? I can't ever recall seeing anybody with a stickie doing this in dead winter.
Such dedicated souls we are, FG RV owners!
CampyTime is offline
Old 02-11-2014, 07:42 AM   #6
Ice-breaker's Avatar
sorry, double post.
Ice-breaker is offline
Old 02-11-2014, 07:44 AM   #7
I bought one of these this year for clearing snow from the edge of the roofline on my house, as we have had problems with leaks due to ice dams in the past. The handle is an extension handle and can reach up to about 15-16 ft. It also worked great to clear the snow from my Escape's roof. If you have access to the four sides of your trailer, you would not even have to use a ladder.
Old 02-11-2014, 08:40 AM   #8
Nate R's Avatar
Trailer: 1981 Casita 13. TV: 2011 Honda CR-V
Wisconsin
Huh? The density goes up, but the total load should stay the same or less, right? Or am I missing something?
Nate R is offline
Old 02-11-2014, 10:19 AM   #9
Nate - The essential measurement that is required for calculating loads is the water equivalent . How much moisture the snow is holding will change the total load drastically. For example i work at ski races and I can tell you that a shovel full of snow in coastal Whistler BC weighs far more than the same shovel full of snow in the Rocky mountains .... reason is the Whistler snow normally contains far more moisture due to warmer temps. In the Rocky mountains it is normally colder resulting in far less water content to volume.
Carol H is offline
Old 02-11-2014, 10:28 AM   #10
I think that what Nate was pointing out is that once the snow is on the roof of the trailer, the total weight of the snow on the trailer roof does not increase just because the snow is becoming denser as it melts.
Old 02-11-2014, 11:39 AM   #11
Snow usually does become much heavier as it melts. As it melts the moisture content can/will increase thus making it much heavier even though it may look like less volume. It the reason you will see people who live in snow country leave 3 feet of more snow on the roof of their homes or cottages for weeks without worrying about it but once it starts to warm up and melt you will see people up shovelling off the roof as fast as they can.
The water content of snow may range from 3% if very dry snow to 33% if wet, heavy snow, to nearly 100% for ice. An inch of water weighs 5.2 lbs. per square foot. As dry snow melts it becomes wet snow.
There is a good explanation of it located here.
Carol H is offline
Old 02-11-2014, 12:51 PM   #12
cpaharley2008's Avatar
Hhmm,reminds of a childhood question, what weighs more a ton of gold or a ton of feathers??
Jim
Never in doubt, often wrong
cpaharley2008 is offline
Old 02-11-2014, 01:00 PM   #13
we as adults hopefully all know a ton is a ton whether it be gold, feathers or snow..... what some of us have difficulties with is the concept that 3" of dry fluffy snow may not weigh as much as 1" of denser melting snow.
Carol H is offline
Old 02-11-2014, 01:59 PM   #14
David Tilston's Avatar
But where does the additional weight come from? Is the snow absorbing moisture from the air?
David Tilston is offline
Closed Thread
Snow build-up on fiberglass roofs General Chat 5 02-14-2014 05:43 PM
Snow. Really. SNOW. S-N-O-W fusedlight General Chat 42 05-03-2013 06:47 PM
load capacity Bigfoot Jody Petersen Problem Solving | Owners Helping Owners 1 06-16-2009 04:08 PM
Load helpers/ Air Bags/ Timbrens Taylor Kissinger Towing, Hitching, Axles and Running Gear 2 03-15-2009 04:11 PM
Prep for snow load on roof? Donna R Problem Solving | Owners Helping Owners 14 10-21-2008 09:35 AM
