So...we bought a 95' 13 ft Scamp today!! - Fiberglass RV
Old 06-24-2012, 08:36 PM   #1
AbitWhitty's Avatar
Trailer: 1995 Scamp!
It is great condition, but would like to remove the "fuzzy" insulation on the walls. Any suggestions?
AbitWhitty is offline   Reply With Quote
Old 06-24-2012, 09:24 PM   #2
Deb & Chuck's Avatar
Name: Deb & Chuck
Trailer: Bigfoot (8), Boler, Trillium, ECO, U-Haul, Burro, Escape (3), Trailswest, Compact Jr., Casita, Scamp
You should keep the rat fur and clean it. The rat fur wicks moisture out of the trailer.
chuck
Deb & Chuck is offline   Reply With Quote
Old 06-24-2012, 09:48 PM   #3
AbitWhitty's Avatar
Thanks! I'm just so not a huge fan of it!
Old 06-24-2012, 10:21 PM   #4
Trailer: 77 Scamp 13
The inner covering acts as insulation and helps prevent condensation. Plus as mentioned in prev. post acts as an absorbent/wick to deal with the condensation that does take place.
Old 06-24-2012, 10:25 PM   #5
The "rat fur" does several things. It deadens sounds, so the inside of the trailer is much quieter than outside. It provides insulation.
Under the "rat fur" is a layer of Mylar bubble. It's foil, Mylar,foil that is glued to the fiberglass shell. If you try to remove the "rat fur" you'll end up removing some of the Mylar insulation, creating one heck of big mess. Also everyplace you remove the Mylar lots of light will come through the thin fiberglass shell.
I would suggest you keep it for a while. Then if you really really feel the need to get rid of it, sell the Scamp and get something that has solid walls, Trillium, Burro, UHaul, and others.
Old 06-24-2012, 10:44 PM   #6
AbitWhitty's Avatar
Thanks for all the helpful information. I think since everything else needs updated, that rat fur is just standing out more than normal. Once I remove the carpet and update the cabinets and hardware, I hope to not even notice it.
Old 06-25-2012, 09:21 AM   #7
I'm not a big fan of the rat fur either but I agree that as others have said you will be sorry you removed it as it does serve a number of very positive purposes. Dont think I would be nearly as comfortable camping in mine if it was not on the walls. Its actually a marine grade covering still used a lot inside boats as well. You will notice that older Scamps dont have it (they had a different product) so it was something that Scamp added after recognizing the short comings of what they used previously.
Old 06-25-2012, 09:45 AM   #8
honda03842's Avatar
Name: Norm and Ginny
Whitney,
The worse thing about the marine fabric used in the Scamp is that people call it 'rat fur'. The fabric along with the insulation work very well.
Our wall covering is now 21 years old and still looks great.
We have had three trailers. The first had a thin layer of 'wood' with 'mylar'. Definetely looked worn and dated after 20 years. We followed it with a Casita 16. The walls were covered with grey carpet, no insulation backing. Though we liked the look of the Casita's walls I believe the Scamp is better insulated and warmer.
The Scamp fabric really stands up well. Seems to not absorb water, probably because it's plastic based. I like it, my only reservation is that it has a few seams.
There are many things one can do to improve the usefulness of fiberglass trailers, in my mind replacing the wall covering is way down the list.
Safe Travels
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 06-25-2012, 12:38 PM   #9
AbitWhitty's Avatar
Thank you for all of your feedback! I too think that of all the things I could do, that should be further down the list. It's in really good shape, but want to class it up a bit and bring it to 2012. Pictures to come!
Old 06-25-2012, 01:54 PM   #10
IllAnnoy
I think that the "Ratfur"/reflextix is the best lining offered on any fiberglass trailer.
Old 06-25-2012, 04:27 PM   #11
2012 Scamp trailers have "rat fur".
Old 07-29-2012, 08:57 PM   #12
Trailer: 1996 scamp 13
our 1996 scamp's rat fur has an area where it seems to be separating from the shell. i would love to hear any ideas on how to fix.
Ray and Amy Coapman is offline   Reply With Quote
Old 07-29-2012, 10:15 PM   #13
IllAnnoy
You don't say whether the reflextix is separating or just the fabric. but either way 3M makes a spray glue to handle it. You can make a needle point puncture in the middle of the sag and with the use of a straw nozzle, inject the spray glue.Move the nozzle around to spread the glue,then push it back in place. If it sags again right away, then wait 10-15 seconds then press it back into place.
Old 07-30-2012, 05:57 AM   #14
Roy in TO's Avatar
Are you sure that was the situation Carol? Or was it that the Ensolite used in earlier Scamps and many other trailers was no longer being produced.
I agree with the rest, if you don't like the "rat fur", sell the trailer and buy and earlier model or something else. Taking it out is a big job. Replacing it is expensive and labour intensive. Something similar to what was used in earlier generations is now available at Trillium RV.
just bought a 15' beachcomber today jamest Hi, I am.... 10 08-18-2013 05:03 AM
Bought my first Scamp! 841K9 Hi, I am.... 11 06-25-2012 08:44 AM
Just bought a Boler today karinw Modifications, Alterations and Updates 5 04-16-2012 07:49 PM
Bought a Burro today kyle minor General Chat 13 07-17-2010 02:22 PM
I bought a 1984 13' U-Haul today Steven Tonnesen General Chat 11 06-30-2009 08:09 PM
