Old 07-17-2012, 06:14 AM   #1
Trailer: uhaul, 84, 13CT
Massachusetts
solar panel
I have a U Haul CT 13, it has the original solar panel but not hooked up. Does any one know the wattage? I've looked at the two manuals on doc center but can't find anything. The original converter is shot, so I'm trying to plan a new system and would like to include solar, except for a proper regulator of some sort-its free. thanks Mike
h.mike is offline   Reply With Quote
Old 07-17-2012, 06:25 AM   #2
Thomas G.'s Avatar
Trailer: UHaul CT13 TV: Escape Hybrid
SE Michigan
Mike, when new it was about 10 watts. You can measure the output by shorting the leads across a $5 ammeter (disconnect from controller). I checked mine and its output had degraded to next to nothing. For $120 I installed a 60 watt panel that works very well.
Digital Multimeter - 7 Function, w/ Backlight
Just call me Tom.
Thomas G. is online now   Reply With Quote
Old 07-17-2012, 08:40 AM   #3
Massachusetts
solar panel
Hi Tom, and anyone else reading: Thanks for the quick response. Since I posted earlier today I've found a dangling wire from the panel, its producing juice. I assume the controller was part of the original converter that is shot. Do you know if a regulator and or controller is necessary for this little output? I'm trying to avoid a converter and just use a good charger. thanks Mike
Old 07-17-2012, 08:44 AM   #4
Thomas G.'s Avatar
SE Michigan
You do not need a controller for the original panel. You may find it interesting (or disappointing, as I did) to see the actual output. The original controller is mounted on the side of the battery case. It is totally independent of the converter.
Just call me Tom.
Old 07-17-2012, 09:01 AM   #5
Massachusetts
solar
Thanks again. My original wiring looked like a plate of spaghetti, so I did'nt really attempt to figure it out. A fresh set of eyes makes a big difference. Mike
solar, solar panel
Wanted: Solar panel Roger Kimble Parts: Buy | Sell | Trade 4 11-05-2011 02:01 PM
solar panel on Uhaul 13 CT Marty D Problem Solving -- Owners Helping Owners 1 06-16-2010 04:49 AM
solar panel Judith Kennedy Problem Solving -- Owners Helping Owners 2 10-29-2009 11:30 AM
Want to purchase a Solar Panel Joe Loiacono Modifications, Alterations and Updates 7 02-14-2009 09:01 AM
solar panel help Maggie Problem Solving -- Owners Helping Owners 9 07-18-2006 04:38 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
