Source for replacement trillium table lock downs - Fiberglass RV
Old 06-30-2014, 09:49 AM   #1
Trailer: '84 Bigfoot b17
Our table unit has seen a bit of abuse over the years it seems. The wooden receiver mounted against the back wall is pretty rough where the wood dowel pins fit into. How does this receiver piece come off? I was thinking of trying to replace the one piece by making a replacement out of 3/4 plywood. See pic
Then, there is the table clamps that help to lock it unit down (to prevent damage as I have explained) ours are pretty much toast being all bent and broken....beyond repair anyways. They are little aluminum things with a wire that goes around a "catch". Can anyone please pass along a source for buying some new ones?
Thanks!
John
Tyhee is offline   Reply With Quote
Old 06-30-2014, 11:40 AM   #2
John you could try contacting the folks in Calgary at Trilliumtrailers.com they should be able to help you or advise where you might find one.
Note that their phone system was apparently down last week but would hope its fixed by now.
Old 06-30-2014, 11:28 PM   #3
Ok will do Carol thanks. I was wondering if they are a generic fastener common in many rvs told are they are trillium thing? I'll post a pic of them as I know we love pics....
trillium
Source: Replacement center caps for wheels Derek Johnson Modifications, Alterations and Updates 0 05-20-2013 08:19 PM
trillium dinette table replacement saltcreek Modifications, Alterations and Updates 8 09-16-2012 12:47 PM
Trillium 4500: Need replacement door lock/latch Laurie Problem Solving | Owners Helping Owners 13 06-29-2011 07:19 PM
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 06:11 AM
Tie Downs james kent Care and Feeding of Molded Fiberglass Trailers 7 06-09-2006 09:59 AM
