spiderweb like cracks on fiberglass surface - Fiberglass RV
Old 11-11-2013, 05:49 PM   #1
hi folks,
i recently bought my scamp and i see these hairline cracks in several areas. what is the best corrective action?
if there is a thread covering this (i'm sure it has come up many times) i'd appreciate being directed there.
thanks,
jondsw
jondsw is offline   Reply With Quote
Old 11-11-2013, 06:10 PM   #2
Trailer: 77 Scamp 13
Pictures would help. Go to user CP link top left corner of the page, albums and pictures link in the CP (Control Panel) upload the picture, copy the link from under the picture after it uploads and paste link in your post.
Don't know the age of your camper but the outer white gel coat gets stiffer than the fiberglass with age and can get tiny surface cracks due to the fiberglass underneth flexing more than the gel coat surface can. These are cosmetic. If the cracks go down into the structure of the FG or clear through that is more of an issue.
You might find page 5 of this pdf of use, has drawings of the different types of cracks and what typically causes the pattern of cracking diagramed.
http://www.westsystem.com/ss/assets/HowTo-Publications/Fiberglass-Boat-Repair-and-Maintenance.pdf
Even cosmetic surface cracks it's a good idea to at least coat with a wax or polish and try to seal to keep water out of the crack, don't know if you have to deal with freezing temps but water in the tiny crack that freezes makes the crack get bigger over time.
Old 11-12-2013, 07:11 AM   #3
Manitoba
I have not used this product, but am considering it:Capt. Tolley's Creeping Crack Cure
Old 11-12-2013, 07:51 AM   #4
I have not tried the creeping crack cure but several people on the forum have. Worth checking out and investigation on that basis alone.
What is needed really depends on how deep the crack goes, gel coat surface is cosmetic, all the way through or into the fiberglass sub strata is of greater concern.
It also might make a some difference what caused it. E.G cracks around hinge bolts vs where something hit fiberglass. Those hinge bolt cracks are going to get worse until the fiberglass breaks. Impact damage not so much.
Old 11-12-2013, 09:26 AM   #5
melissab's Avatar
Trailer: 2012 Scamp 13 DLX
I dont know how old your trailer is but I picked up my brand new Scamp 13 from the factory last yr. By the time I got it back home to Florida it had Spider cracks on both front corners from the belly band all the way to the bottom. Kent (owner of Scamp) had never seen that happen to a new Scamp before. He offered to pay to have it fixed locally but since it was a brand spankin new trailer I wanted to be confident in the repair so I returned to the factory this past summer. Plus it's such a beautiful area to vacation in I didnt mind one bit. The cracks were not just in the gelcoat and they never did decide what was the cause. They re-fiberglassed over the area, sanded it, polished it etc and it looks good as new. If you run your hand down the trailer you can feel where they had to build it up but if you dont know it's there you'd probably never be able to pick it out. I'm not sure how they determined the cracks were not just surface but wanted to let you know if may not be just cosmetic no matter how new your trailer is.
Melissa in Florida
2016 Honda Odyssey
melissab is offline   Reply With Quote
spiderweb and hairline cracks (in gel coat only?) BarterBoler Problem Solving | Owners Helping Owners 7 07-28-2013 01:32 AM
Small cracks and bubbling in fiberglass ostojo Care and Feeding of Molded Fiberglass Trailers 7 11-08-2012 07:34 PM
Repairing cracks in green fiberglass MadgeW Care and Feeding of Molded Fiberglass Trailers 15 03-06-2012 06:23 AM
Fiberglass cracks Janne Potter Problem Solving | Owners Helping Owners 3 04-25-2011 02:53 PM
How do you fix Fiberglass cracks SharonNDean Problem Solving | Owners Helping Owners 12 02-12-2008 08:46 PM
