Spray on bed liner - Page 2 - Fiberglass RV
Old 07-27-2013, 09:17 AM   #15
Trailer: 2015 Escape
Back in 1996 we had our new truck bed done with Rhinoliner. Had to drive 200 miles to Adrian, MI which was the only place in MI that did it then. They told us that they had done swimming pools (inside) and both inside and outside of a dump truck dump bin. On three different trucks I had no complaints. On one I had the body behind the rear wheel openings done to prevent gravel, etc messing up the paint. No complaints there either.
Old 07-27-2013, 09:24 AM   #16
Green Frog's Avatar
Trailer: '83 Burro
Virginia
When the previous owner of my Burro replaced the rotten floor, he was determined to do it just one time, so he coated top bottom and edges of the plywood with berliner, making undercoat, edge seal, and a textured, non-slip floor surface that is easy to clean and can be "dressed up" with scatter rugs. If I start towing my egg more than currently, I may add a front "apron" of bedliner material. Line-X comes in the colors of your choice as well.
Froggie
Green Frog is offline   Reply With Quote
Old 07-28-2013, 09:04 PM   #17
Night Sailor's Avatar
Connecticut
You can do it yourself. U-Pol on Amazon.com
$114 for. Gallon which will so an 9' pickup bed. Can get clear and tin to match any paint. Use normal auto paint tints-comes out a bit darker than the paint would be.
Easy to install. Scuff up surface. Wish, dry, mask.
Use respirator and avoid breathing fumes, gloves, old clothes, etc.
It would probsy cost around $75 and take a few hours to do yourself.
Comes with a sprayer which is disposable.
Old 07-28-2013, 09:49 PM   #18
But what is it's RPG resistance co-efficient?????
Genuine Rhino liner will protect you, your loved ones and your somoza's from all but the largest IED you might encounter on the road of life.
("Somoza's" See Raj>>>The Big Bang Theory>>>The Dumpling Paradox)
Old 07-29-2013, 01:50 AM   #19
GMike A's Avatar
Pretty cool video. Bet my grandson could find a way to destroy it.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 09-27-2013, 12:57 PM   #20
Herman M Parker's Avatar
Name: Herman & Ann
Trailer: Scamp 5th Wheel
Pensacola Florida
I used Herculiner from the auto parts store for the roof on a 10ft teardrop I built. I put it directly on luan plywood no undercoat. Made the trip to Calif and back no leaks or problems. I feel if it works on the teardrop it would work on my scamp.
Herman M Parker is offline   Reply With Quote
Old 09-27-2013, 02:52 PM   #21
honda03842's Avatar
Name: Norm and Ginny
https://www.dipyourcar.com/PlastiDip-Spray/
Here's another alternative. I believe it can be peeled off when you don't want it any more. Comes in many colors.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 09-27-2013, 08:59 PM   #22
Name: Herman & Ann
Pensacola Florida
I don't about pealing off I have not been able to get it off my shop for over two years.
Old 09-28-2013, 08:15 AM   #23
Name: Herman & Ann
Pensacola Florida
I should have said my shop floor for the last two years
Old 09-30-2013, 06:42 PM   #24
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
I've been reading on that plasti dip...its not a permanet thing, some peoples have problem with long exposure to the sun. The plastidip dries, become hard, cracks and is then Very hard to remove.
tartosuc is offline   Reply With Quote
Old 09-30-2013, 07:12 PM   #25
honda03842's Avatar
I have never used it but it looks interesting to me.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-30-2013, 08:06 PM   #26
There are actually several different types of "bedliner" materials. One is extremely hard (brands?) and others are kinda rubbery and "soft" I would worry about the soft stuff applied on the front. If a rock or other projectile hit an area hard enough it MAY cause an internal crack to the fiberglass but the rubber "liner" MAY not show a problem as it bounces back. Is this a concern for YOU?
Old 09-30-2013, 10:07 PM   #27
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Mine is 30 years old, and that hasn't happened yet. I have the softer kind on my pickups, won't put the hard kind on them. I have two tears in the bed, both from pushing 3,000 pound pallets of stone to the front of the bed with a forklift.
Old 10-01-2013, 04:11 AM   #28
Green Frog's Avatar
Trailer: '83 Burro
Virginia
Donna,
The premium bed liner material available where I live in VA is very thick and semi-hard. It can be textured and comes in colors. They say that when they apply it (a hot, spray on process) the result is tough, durable, and about shock proof. I'm seriously considering having a section sprayed on the bottom of the front of my '83 Burro (after I work my way through the rest of the list!) When I get back from the overseas trip I'm on now, I'll post the name of the company (which is national) and more details about the product and the process.
Froggie
Spray-in bed liner rgrugg Modifications, Alterations and Updates 17 03-19-2013 10:34 AM
spray on truck bed liner felix2 Problem Solving | Owners Helping Owners 3 03-18-2013 09:58 PM
Water Spray Benita Problem Solving | Owners Helping Owners 2 10-09-2008 08:31 AM
Longing to spray a new gelcoat Gigi Modifications, Alterations and Updates 14 05-06-2006 08:17 AM
Use that WD-40 or Silicone Spray Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-26-2002 03:38 PM
