Spray on bed liner - Page 3 - Fiberglass RV
Old 10-16-2013, 07:36 AM   #29
Green Frog's Avatar
Trailer: '83 Burro
Virginia
PS to last: I see that I had posted much earlier about this topic, and it is indeed Line-X™ that is available here locally. It is apparently about on par with the "Rhino-type" product and definitely falls in the "have it done" rather than the DIY category. I have the attitude that "a man ought to know his limitations" (with proper tip or the hat to Dirty Harry) and feel like having this material applied by the pros is probably what I would want to do if it were needed at all. YMMV!
Green Frog is offline   Reply With Quote
Old 10-16-2013, 08:37 AM   #30
Does LineX = RhinoLiner ????
Don't know if that's true, but I just sold my 2003 GMC Sonoma that I had RhinoLiner sprayed into a week after I bought it new, and the buyer thought that it still looked like new..... Never a problem after 10 years. All I ever did was use the Rhinoliner cleaner product about 3 times in those 10 years.
Old 10-16-2013, 10:50 AM   #31
Green Frog's Avatar
Trailer: '83 Burro
Virginia
You will notice that I said "apparently about on par" in my post... I don't have access to the Rhino™ product here, but folks around here are getting results similar to those you describe from Line-X™ which is part of a national chain of dealers. I think the key is that these products are both put on in a much heavier coat than is possible with DIY products from a rattle can, with at least the Line-X™ being at high temperature. I'm going to guess that there won't be a lot of difference between the performance for our application of Line-X™ or the Rhino™ coatings professionally applied. JMHO, YMMV.
Froggie
Old 10-16-2013, 02:42 PM   #32
felix2's Avatar
Trailer: 82 burro 13 "PookaBurro"
I was going to use Monstaliner - Monstaliner do-it-yourself roll-on truck bed liner outperforms Herculiner Bed Liner, Duplicolor and Rustoleum Road Warrior - a do-it-yourself product. It doesn't use ground-up rubber in it, so the surface, while it is not smooth, appears to not have a 'tooth' to it that will catch a lot of dirt.
Kind spendy, noxious and tedious to apply, but I expect to do it soon. I want to make a whole front-end 'mask' to protect against rock chips, and do the rear wheel whells and lower side panels too.
Too many tasks!
felix2 is offline   Reply With Quote
Old 10-17-2013, 10:37 AM   #33
Night Sailor's Avatar
Connecticut
Originally Posted by Green Frog View Post
PS to last: I see that I had posted much earlier about this topic, and it is indeed Line-X that is available here locally. It is apparently about on par with the "Rhino-type" product and definitely falls in the "have it done" rather than the DIY category. I have the attitude that "a man ought to know his limitations" (with proper tip or the hat to Dirty Harry) and feel like having this material applied by the pros is probably what I would want to do if it were needed at all. YMMV!
I priced out getting my pickup bed done. It was $750 plus tax.
I did sprayed it myself in a few hours. Very easy job. Just lightly sand it to rough up the surface. I sanded it thoroughly, washed it, masked it off with cheap plastic sheeting, and sprayed it. Cost was $114 and included a spray gun.
Anyone could do this.
I plan to pull the carpet and seats in my Volvo and spray the interior for rust protection. I am thinking about spraying parts of the exterior of my excavator to pretty it up a bit. It is a fantastic product. It can be colored with any automotive tint. It works well on the interior or aluminum boats; there are many applications.
Spray-in bed liner rgrugg Modifications, Alterations and Updates 17 03-19-2013 10:34 AM
spray on truck bed liner felix2 Problem Solving | Owners Helping Owners 3 03-18-2013 09:58 PM
Water Spray Benita Problem Solving | Owners Helping Owners 2 10-09-2008 08:31 AM
Longing to spray a new gelcoat Gigi Modifications, Alterations and Updates 14 05-06-2006 08:17 AM
Use that WD-40 or Silicone Spray Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-26-2002 03:38 PM
