"Stealability" - Page 3 - Fiberglass RV
Old 10-12-2007, 08:54 AM   #29
james kent's Avatar
Trailer: Boler 1984
Best deterrant...large black and tan doddie or rotter.
Old 10-12-2007, 08:55 AM   #30
james kent's Avatar
Trailer: Boler 1984
Opps! he scared me already. Make that a dobbie.
Old 10-12-2007, 10:19 AM   #31
Trailer: Scamp 16 ft
I do a lot of disperse camping and am away from my rig for hours at a time, hiking or mountain biking. I run two heavy motorcycle-type cable locks through my trailer rims and around the axle. It might help. It will at least slow them down.
Sebastian
I think my wheel lock/bar would makie it reather hard to tow without using a cutting tool of some sort to remove it first. Yes if they really want it they will find a way to get it.
Dan B is offline   Reply With Quote
Old 10-12-2007, 10:23 AM   #32
Brian B-P's Avatar
The original idea was that we might think that our trailers would be difficult to steal, because they might require special towing preparation. In the case of brakes, the thief might need to have a brake controller. Of course, my point is that they would just tow it without using the brakes.
It occurs to me that a trailer with electric brakes could be made very hard to steal. An on/off switch connected to a car alarm motion sensor connected to the brakes would lock the brakes anytime the trailer was moved.
This takes the brakes idea one step further, using them as an active theft prevention system. I think that this could be a minor annoyance to a thief, who would just clip the wires off to deactivate it. An interesting idea, anyway.
Old 10-12-2007, 10:44 AM   #33
John Perry's Avatar
Trailer: 1996 13 ft Scamp
Send a message via AIM to John Perry
Hmmm. It occurs to me that a trailer with electric brakes could be made very hard to steal. An on/off switch connected to a car alarm motion sensor connected to the brakes would lock the brakes anytime the trailer was moved.
--Peter
Great Idea!
Some where in my shop I have a motion sensor car alarm that I bought several years ago and never used.
Theives are not as smart as some give them credit for. This should be and effective theft deterrent and easy to install.
Thanks Peter.
John
John Perry is offline   Reply With Quote
Old 10-14-2007, 07:25 PM   #34
peterh's Avatar
Perhaps, but think of how it would go down. Thief hooks up, gets moving, and the brakes lock. There's no obvious reason why the wheels locked up . . . a thief would probably decide the axle is bad and the trailer not worth stealing before considering the possibility of a sneak circuit that hit the brakes.
--Peter
Old 10-14-2007, 09:47 PM   #35
Greg A's Avatar
Trailer: 2015 Escape 19
Sounds like a great idea Peter.
I was wondering if maybe it could be rigged up somehow simply using the "breakaway" brake system.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 10-15-2007, 12:35 AM   #36
Roy in TO's Avatar
I've been thinking of getting the parking brake option when I change my axle to include e brakes. Any thoughts?
As for stealability, my trailer has detachable wiring harness and safety chains. Sure to attract attention by the police. Plus a hitch lock, but I like Fredericks better. Whenever possible I leave it on the stabilizers, one more step to make it difficult to hook up quickly.
BTW has anyone noticed that there are only 2 exposed nuts to loosen to remove a locked door on many trailers? It was not till I worked on my door that I realized why the previous owner had a lock bar running across the door. I thought it was to keep the door from popping open on the road. Now I know different and am keeping his mod. This picture is from the original ebay listing for our trailer.
Old 10-15-2007, 07:34 AM   #37
Brian B-P's Avatar
Good point. As long as the scheme remains rare - and I'm sure it would - the easy override probably wouldn't occur to the average thief.
...I was wondering if maybe it could be rigged up somehow simply using the "breakaway" brake system.
Since the breakaway setup is just a battery connection and switch in parallel with the normal circuit from the brake controller, I think that this would be more like an additional parallel system than a modification or extension of the breakaway system.
And as long as we're inventing this thing... I think a timer or low-voltage cutoff would be good idea, to save the battery. When it runs out of juice the game's up anyway... might as well avoid destroying it.
Old 10-15-2007, 07:37 AM   #38
Brian B-P's Avatar
I think it's a great idea. The parking brake hardware is trivially simple, although I have heard that it is priced excessively high. There would be some work to mount the cables and lever, but it would save chocking (and be more effective) every time the trailer is stopped.
It would also render the trailer more difficult to tow - and thus less "stealable" - by someone who is looking for an easy target and not wanting to take the time to figure out why the wheels don't want to turn... especially with a padlock through the parking brake lever.
One caution: the parking brake would be great for camping setup, and handy when hitching and unhitching anytime, but probably shouldn't be left set in storage. I've had brake shoes rust themselves onto the drums in a car parked for an extended period, so now I tend to just leave a long-term parked car with the transmission in gear (or in Park, if an automatic) and not set the brake.
I regret not taking the time to look at options and get the parking brake when I expectedly had all of the brake hardware replaced on my axle. Live and learn...
Old 10-15-2007, 07:46 AM   #39
Brian B-P's Avatar
An interesting idea, but I'm not at all sure that a trailer without lights - especially in daytime - would ensure a stop by the police. I've seen vehicles on the road with broken lights, missing lights, white lights where there should be amber or red, amber brake lights (must be red), blue lights, and just about any other illegal equipment configuration imaginable... and I doubt they all (or any more than a tiny fraction of them) were stopped by any law enforcement agency before they got where they were going.
So this feature fits in a category of not difficult to tow, but undesirable to be seen towing, and thus maybe less likely to get stolen.
Old 10-15-2007, 07:55 AM   #40
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
Not to pop this bubble, but a trailer as light as these will tow with the brakes locked. AND, the magnets will burn out in about five minutes of being applied full on, with diminishing ability to hold as the time they're on gets longer. You might have a couple of minutes of full-on braking... but by the time the thief is a block down the road, it'll be rolling nicely, albeit with burned-out brake magnets.
A tongue jack will just bend up out of the way as soon as you take off. Merely pushing the trailer forward will potentially bend the jack back far enough for it to fall onto a ball mount. Just ask anyone who's ever tried to leave a campsite with the jack down!
And remember, folks, you're only going to slow down a casual thief, and there aren't many spur-of-the-moment "casual" thefts of trailers. Someone has to want your trailer and come equipped to take it. If that's the case, they're going to. Frankly, there aren't many trailer thefts at all anyway... there are many, MANY more thefts FROM trailers.
Roger
Old 10-15-2007, 07:08 PM   #41
John Perry's Avatar
Roger
You are correct! I have never had an RV stolen in 40 years and I have never had anything stolen while camping. I have had 3 damaged by thieves breaking in to steal something while my RVs were parked in my yard. I never lock any of my RVs when they are parked at home now.
John
Old 10-15-2007, 11:20 PM   #42
Trailer: 1972 Boler 13 ft
John
I think the issue would be time...left long enough alone and they have time to disable most safe gaurds,location is key.
Brad Judd is offline   Reply With Quote
2010 Custom Fiberglass teardrop"Real Kool" Dave Baston Referrals: Molded Fiberglass Trailers 1 06-07-2010 05:14 PM
1980 12' Contempo "Condo" Rare and IMACULATE **MINT** Joe Balla Classified Archives 11 04-13-2010 09:02 AM
SOLD - 1970 Boler on "Ebay" 10 hours/ 20 Minutes left Dave Baston Classified Archives 5 04-12-2009 10:45 AM
