Steam cleaning casita - Fiberglass RV
Old 07-25-2015, 04:28 PM   #1
jenbooks's Avatar
Trailer: Casita Spirit Deluxe 2003
Hi all. I was thinking of buying a carpet steam cleaner (the Bissell is on sale for $89) to steam clean my new to me casita. The previous owner said he had it professionally cleaned when he got it and they injected these little plastic beads? He had no better explanation than that and I wonder if anybody knows what it was?
My casita carpet has a slight odor, not of mildew or mold or perfume, but perhaps from whatever coating those plastic cleaning beads deposited? It's a 2003 so it shouldn't otherwise have an odor. I would like to remove it and just do a good steam clean, I will probably use Branch Basics, it's a nontoxic all purpose enzyme based gentle cleaner that I use on my truck and even clothes sometimes.
Any advice and anybody have a guess as to what the plastic beads were? thanks
jenbooks is offline   Reply With Quote
Old 07-25-2015, 04:29 PM   #2
jenbooks's Avatar
PS I mean my walls and ceiling carpet, not the floor.
Old 07-25-2015, 05:10 PM   #3
Actually, unless it's visibly dirty. I'd just use a good hand spray carpet cleaner with a brush, and vacuum it afterwards. Using anything hot or that soaks the pile may lead to failure of the adhesive.
I use a product called "OdoBan" when cleaning out my rental units and it cleans everything and kills every possible odor, even the ultimate odor. I know you may have never heard of it, but it's available most places including WalMart and it really works.
Juist my take
Old 07-25-2015, 05:27 PM   #4
jenbooks's Avatar
Thanks Bob, but odoban contains isopropanol and benzyl ammonium chloride so I definitely do not want that all over my trailer interior.
I like Branch Basics which is nontoxic and works well for me.
Just wondering if anybody knows what type of professional cleaning would have used beads of some kind?
Old 07-25-2015, 05:49 PM   #5
Probably have micro beads in your hair shampoo at home. They are being phased out. Used in all sorts of cosmetics too. Accumulates in marine animals.
Google "micro beads" and you'll find they are everywhere.
Old 07-25-2015, 05:52 PM   #6
jenbooks's Avatar
Ah, thanks Glenn, I know about microbeads. They're not in my shampoo but I use a natural product.
Old 07-25-2015, 07:24 PM   #7
Administrator
Mary F's Avatar
I would be concerned about adhesive failure during a steam clean, too. I wonder if there's anyone at Casita Enterprises who would/could advise on this? In their service department, perhaps?
I'm assuming you've already vacuumed the walls...
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 07-25-2015, 07:29 PM   #8
jenbooks's Avatar
Good idea, Mary.
I get the sense the odor-- which is not so bad but could annoy me 24/7-- is from some kind of coating or scotch guarding type thing.
Old 07-25-2015, 07:30 PM   #9
jenbooks's Avatar
By the way, I did have a gray water odor in the bathroom too and it was totally solved by the hepvo valve mod.
Old 07-25-2015, 07:31 PM   #10
jenbooks's Avatar
I should add to clarify I have a very sensitive nose...I am sure most folks wouldn't care.
Old 07-26-2015, 11:31 AM   #11
ArtWrangler's Avatar
The hand tool on a rental carpet cleaner is your best best bet. Use a just a small amount of cleaning solution first, than go over it with clear water. Your adhesive with be fine. Stay away from 'odor removers' as they will leave an perfume. Although, Fabreeze is a good product in a pinch.
ArtWrangler is offline   Reply With Quote
Old 07-26-2015, 07:02 PM   #12
jenbooks's Avatar
Thanks, Art! I will look into that.
Old 07-27-2015, 01:08 PM   #13
Trailer: 1992 Casita Spirit Deluxe
Virginia
I used ammonia-water in a spray bottle first to get 20 years of cooking grease off, and vacuumed it up with a shop vac using mostly the upholstery tool off of our house vacuum.
The next night I switched to a diluted biological odor destroyer product used for pets and crime scenes. That took care of the dog and mouse nest smells. Shop vac removal again.
The third night I went after it with a very dilute bleach/water solution to kill the odor of the many, many artificial air fresheners that we found in the camper when we bought it. Vacuumed that off with the shop vac as well.
Now it smells of almost nothing, which was the goal. It's vastly whiter inside, too.
I did get some white fuzz in the shop vac, but given the amount of carpet in the interior, it was a miniscule amount. The carpet stuck resolutely to the shell regardless of what I did to it. I would think that a beater head or shampooer would probably shake loose more carpet fuzz than just vacuuming did.
The pile's not really very thick and is imbedded in a foam rubber insulation layer. The foam is what's glued to the shell. The stuff isn't all that willing to come loose.
steelypip is offline   Reply With Quote
Old 07-27-2015, 09:10 PM   #14
jenbooks's Avatar
Thanks, steely pip. Very helpful.
casita
Considering a Fiber Steam xocy General Chat 16 04-17-2015 09:34 PM
Steam thresher reuniions Gene Masse General Chat 1 06-21-2012 05:44 PM
Steam cleaning Casita? BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-01-2006 07:49 PM
Cleaning yellowed plastic (Casita) Legacy Posts Care and Feeding of Molded Fiberglass Trailers 5 08-15-2003 10:17 AM
