Sticky, tacky interior walls - Fiberglass RV
Old 04-03-2014, 08:30 PM   #1
Trailer: 16' Scamp
Wyoming
We have a 1979 16' Scamp. The interior walls are deteriorating. They are sticky and tacky. Is there any product to cure this problem? I called a paint store and they suggested oil based bonding primer, then latex paint. I was hoping for something easier to work with. Any suggestions? Thanks, Lisa
Wyowill is offline   Reply With Quote
Old 04-03-2014, 09:02 PM   #2
KenjiFox's Avatar
Perhaps white Plastidip? You will want to try it out in a small section first.
Hopefully this will help. I only have the "Elephant skin" in the bathroom in my Scamp, and I have not tried putting anything on it. Mine has not deteriorated from what I can tell.
This is just a possible solution, someone may have a much better one!
KenjiFox is offline   Reply With Quote
Old 04-03-2014, 09:19 PM   #3
Gina D.'s Avatar
West Coast USA
LA's Totally Awesome Cleaner
I detail RV interiors. I never leave home without this. It gets rid of nicotine/smoke tackiness, which is one of the major cause of walls being sticky. And it takes very little effort. Spray it, let it sit for a minute, wipe it off with a soft and slightly damp cloth. You can also dilute it, but I don't think it works as well.
And did I mention.. every dollar store has it for..well, a dollar!
Old 04-04-2014, 08:04 AM   #4
Trailer: 16' Scamp
Wyoming
Two great suggestions. Thanks! I'm going to try the Awesome Cleaner today. I really like the idea of plasti dip. I'll investigate further. And thanks KenjiFox for describing my walls as "elephant skin". Now I know what to call them. Keep the suggestions coming! Thanks, Lisa
Old 04-04-2014, 09:01 AM   #5
Trailer: 77 Scamp 13
My 77 Scamp had very sticky walls when I got it. Used LA Totally Awesome, scrub brush, bucket of rinse water and towels.
Spray, scrub, let sit a minute wipe with one towel, rinse with another. Sticky gone, grunge gone, white again. I removed the yellowed seam tape before I cleaned walls. Then replace the tape with new tape after.
That elephant hide is pretty tough stuff and cleans well. Some safety glasses would be good when doing the ceiling and while not a toxic fume it can get a bit intense smelling if air is not moving through the trailer.
I found Barkeepers friend is a good scrub for tough stains on FG or elephant hide. I used this Starbrite Color Restore FG wax product on inside FG to good effect. Fiberglass Color Restorer With PTEF
Starbrite available online, Ace Hardware, Marine or Auto supply stores.
Old 04-04-2014, 09:25 AM   #6
In any event, before adding anything (sealer/plastidip ?) to the existing surfaces, clean it first with the Totally Awesome stuff. Also disposable Nitril gloves are a must. That stuff is nasty to the hands and other body parts.
And as mentioned earlier, use lots of fresh wet towels to wipe the cleaner off with, otherwise you will just spread a thin coat of everything all over.
Old 04-04-2014, 02:16 PM   #7
Trailer: 16' Scamp
Wyoming
Now I am really excited to try LA Totally Awesome. My husband is bringing some home with him and I can't wait to go at it. Thanks! I'll let you know how it goes.
Old 04-04-2014, 05:22 PM   #8
Trailer: 16' Scamp
Wyoming
Holy Cow!! LA's Totally awesome Cleaner is working GREAT!!! I just did a small section of one of the stickiest areas and it removed the sticky and made it white. I really can't beleive it. I am so happy.
Gina D., since you detail RV's, is this stuff safe for all surfaces?
I made sure to wear my rubber gloves, thanks Bob. I applied it just like RogerDat wrote.
THANK YOU!!!!!
Old 04-04-2014, 07:00 PM   #9
Gina D.'s Avatar
West Coast USA
I would be careful with it on some textile surfaces and newly finished surfaces. I haven't found any that it has damaged yet, but I use products specific for those types of surfaces. Read the label, it has some specifics.
It cleans wood, but I would dilute it and use sparingly. Again, it needs to be "rinsed" or it will temporarily leave a sticky surface. The smell isn't that pleasant at first either.
I generally always wear gloves because of other peoples germs, not the Awesome. When diluted, I have not had issue with skin when not using gloves. I recommend them anyway.
Old 04-04-2014, 09:26 PM   #10
Trailer: Chalet
Send a message via Yahoo to Lynn Musgrave
I have used the LA Totally Awesome cleaner for years in my everyday house cleaning it is awesome! I like to use it to keep my stove clean after I cook our meals,spray it on wipe it off with a wet sponge,done.....no scrubbing required! wood work is a breezes,I take my minnie blinds down once a year spray them down let them set about 5 minutes then hose off. They now make a laundry liquid....it is now all I use...no need for bleach in the whites or special color brighteners.
Try them both well worth the $2.00...oh and I have used the spray on my awning and my tents....haven't tried the laundry liquid on them yet cause we haven't been out camping yet this spring.
Happy Camping
Lynn Musgrave is offline   Reply With Quote
Old 04-04-2014, 09:33 PM   #11
Gina D.'s Avatar
West Coast USA
another thing it works miracles on is the stove vent/fan screens, as well as regular roof vent screens. same process..spray, set, rinse.
Lynn....SHHHHHH!!! You have exposed my mini blind cleaning secret! It even gets the strings clean!
Old 04-04-2014, 10:28 PM   #12
Pictures! We want pictures!
Judging by the age of your trailer you might want to look into this thread. If your outside fiberglass is sort of dull and chalky this solution can work really well.
Check this out NOT Poliglow...Time will tell..
It's a 47 page thread you might read the first page then skip to the last one and work backwards to get latest information. One of the products mentioned is no longer available. It's actually sold as a floor wax stuff is really tough and shines great after 4 or 5 coats.
To avoid pulling the debate of using this stuff from that thread to here I'll point out some caveats. It's a wax that is very thin and thus soaks into the pores of the chalky FG. This makes it hard to totally remove for paint prep or fiberglass repair prep. So if painting or FG work is in your future don't do this or any waxing. Just making more work for yourself.
If you plan to replace decal of scamp logo, stripes, tree etc. than do those first and wax over.
Buried in that thread are how to remove, how to apply and lots of other details on prep cleaning before application. Plus lots of pictures of really old trailers that shine like new. When we got ours first thing we did was clean inside as you are doing now, second thing was make the outside clean and shiny.
Love the "your kidding" when I tell people it's from the 70's Of course when they see the harvest gold color scheme inside they believe.
Old 04-05-2014, 08:50 AM   #13
KenjiFox's Avatar
Another item to try where even LA's totally awesome fails is Wesley's Bleach White. Beware, this stuff is a caustic and will strip your fingerprints right off if you don't use gloves. However, it will get any rubbery white surface spotless new clean.
I would rate LA's up there with Mean Green and Simple green. The price is also right!
Wesley's Bleach White can be found in the automotive isle of many stores as well as places like advance auto. It is made to put the "white" back in white wall tires!
Old 04-05-2014, 07:27 PM   #14
Trailer: 16' Scamp
Wyoming
Beautiful day here today. Finally! We decided to put our energy into the outside of the trailer. There were thousands of black speckles all over the top. My husband figured out it was tree sap. We scrubbed it with Barkeepers Friend Soft Cleanser and they came right off. Then scrubbed the rest.
I have read about Zep Wet Floor Finish like in the link above but decided to go with a Marine Restorer and Wax. Napa has a 3M product on sale now. We bought an electric buffer and my husband did a section and it looks great! I tried the buffer and even though it is a 5 1/2 lbs. buffer it fatigued my wrists quickly. I am now doing it by hand. A small section at a time.
We just bought the trailer last Monday and we are having a great time sprucing it up. My husband is ordering a new axle for it. But that is the only major repair. We can't believe the condition of it for a 1979.
We would put pictures up but can't figure out how.
Super sticky interior insulation!!! AuntHoodoo Problem Solving | Owners Helping Owners 14 09-30-2014 10:35 AM
Success with Int paint walls,countertops,Cabinets, Carpet for floors. Walls, too? Gigi Problem Solving | Owners Helping Owners 2 08-31-2012 11:13 AM
All Things Tacky Tour sugermc General Chat 25 11-02-2010 07:52 AM
Tacky lights shane n Modifications, Alterations and Updates 14 06-29-2009 10:16 AM
Tacky Tourist Day Doug Mager General Chat 6 04-18-2007 08:22 AM
