Suburban heater burner clogged? - Fiberglass RV
Old 07-24-2012, 11:08 AM   #1
AKSCAMP's Avatar
Trailer: 1975 Scamp- Super Cozy Ambulatory Mega Party, 1980 Boler B1500 15'
Alaska
Hi,
Tried firing up the old first model Suburban heater in my 75 Scamp for the first time and the pilot lit right up and stayed going, but the unit would not kick on the burner. Pulled it apart, everything looked in order until I got to the burner on top. I couldn't blow through it. It seems clogged. I tried to seperate it from the plate but it's really on there and I didn't want to risk breaking it. So, does anyone know if I should be able to blow air through from below, or how I might be able to loosen the gunk? Thanks a million.
AKSCAMP is offline   Reply With Quote
Old 07-24-2012, 12:04 PM   #2
There are a number of Suburban manuals in the Documents center located here many of them include cleaning instructions. If you cant find what you need in the manual do a google on suburban furnaces and you will find a number of cleaning tips/suggestions.
Old 07-31-2012, 09:46 AM   #3
Trailer: 1977 Scamp 13'
My Suburban was just like yours.
The Pilot ran fine and when I turned the gas valve to "ON" the flames came out the big holes at the base of the main burner, not out of the slots in the top.
It turns out that the burner is a two-part assembly screwed together.
You can CAREFULLY use some pliers or vice-grips to unscrew off the part with the slots from the lower part that is bolted to the base tin sheet.
I found a spider nest in there as well as in the main burner orifice.
When I cleaned that all out (along with the wasp nests in the intake and exhaust) the furnace started running fine.
AlanKilian is offline   Reply With Quote
Old 07-31-2012, 10:46 AM   #4
A very fine wire brush and/or navel jelly to remove the rust. Once the slots are clean and no webs inside the unit it should work.
Old 07-31-2012, 11:10 AM   #5
AKSCAMP's Avatar
Alaska
Thanks guys! I should have followed up when I fixed it. Yep, took the top burner piece off and sure enough it was clogged with debris. A needle cleaned it right up and it's back in the camper and roaring away. That thing is cool! Never used one before, but it had the Scamp toasty warm in no time. I don't mind if it rains this weekend now
Old 07-31-2012, 11:43 AM   #6
I do still have trouble if the wind is blowing HARD outside.
It blows both the main flame AND the pilot out and then the thing quits as it should.
If I don't turn the gas valve completely to ON, the flame burns lower and is less prone to blowing out, so maybe I've got a little too high a Propane pressure. (I'm using a pressure regulator from a gas grill.)
I'll have to look at it before Fall in MN.
Old 07-31-2012, 11:51 AM   #7
cpaharley2008's Avatar
Boy, it is going to be a cold one this year if he is using heat in Alaska in august!!
Old 07-31-2012, 12:03 PM   #8
AKSCAMP's Avatar
Alaska
haha, it's a cold one EVERY year. It's ok, it makes you feel alive!
Old 07-31-2012, 04:37 PM   #9
[I]
Actually Jim if he *wasnt* needing it you would need to be *very* worried about global warming
Old 07-31-2012, 05:59 PM   #10
I hear it is the warming that is causing the real cold winters. Who knows...
Old 07-31-2012, 06:50 PM   #11
AKSCAMP's Avatar
Alaska
^ It's true. We had the all-time highest snow fall ever recorded last winter! Also this July was the coldest on record in Anchorage. So the cold places are getting colder, and others are getting warmer? :
"June broke or tied 3,215 high-temperature records across the United States. That followed the warmest May on record for the Northern Hemisphere the 327th consecutive month in which the temperature of the entire globe exceeded the 20th-century average."
Read more: Global Warming's Terrifying New Math | Politics News | Rolling Stone
Suburban heater - Gas valve question Todd Russ Problem Solving | Owners Helping Owners 1 02-17-2010 08:10 AM
Suburban hot water heater anode difficult to install Steve M. Problem Solving | Owners Helping Owners 7 05-25-2009 07:22 PM
Suburban Heater...What am I missing??? Steve B Problem Solving | Owners Helping Owners 8 01-01-2009 08:51 AM
SUBURBAN sw6p WATER HEATER gary g Classified Archives 0 07-06-2008 08:08 PM
Water heater trouble shooting (Suburban 6 gallon) Legacy Posts Problem Solving | Owners Helping Owners 12 02-14-2003 10:06 AM
