Taking the Scamp out for the first time. - Page 2 - Fiberglass RV
Old 12-06-2012, 02:51 PM   #15
Roger C H's Avatar
Smile First time camping and Water
Your first campsite should be outside your house on your driveway. That way if you forgot anything, it is close at hand!
We decided to not use the on board water tank to eliminate the maintenance associated with it. We carry two gallon jugs of drinking water from home. Then if we need more for the Porta-Potty or to wash dishes, we get some at the campsite. I used the tank when we first got Homelet, but then reconsidered and use the above method now. I placed two gallons of the pink stuff in the tank and then drained what I could. I plan on disconnecting the water pump.
Our grey water tank is a 5 gallon bucket outside the rig.
Old 12-06-2012, 03:10 PM   #16
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Additional clarification on the water heater operation. ALWAYS hooked to city water and lines bled or water heater tank filled by pump from fresh water tank and lines bled PRIOR to lighting water heater. The water heater tank is insulated. Once the water is hot, the flame will reduce to pilot only so not a huge waste of propane. It would be unusual for us to need hot water more than once morning and nite so we usually turn off immediately BEFORE using the hot water to avoid heating the cold water that rushes in. Depends whether you need a gallon or less to wash and rinse dishes or you need more or less consecutive showers.
jack
Old 12-10-2012, 04:40 PM   #17
Trailer: 2010 SCAMP
Do you have any "after" pictures?
pageleigh is offline   Reply With Quote
Taking my Scamp to BC? dylanear Money Matters 25 06-21-2012 12:07 AM
Taking on the Back Window.... trilliumdon Problem Solving | Owners Helping Owners 2 05-11-2011 08:51 PM
Thinking of taking the plunge with a Scamp... Legacy Posts Care and Feeding of Molded Fiberglass Trailers 0 08-04-2003 03:55 PM
