The Blues and Chemically Challenged - Page 2 - Fiberglass RV
Old 02-20-2011, 09:56 AM   #15
Raz
Raz's Avatar
Vermont
I would try Oxalic acid. I've used it to remove (bleach out) the stains from an old bath tub (rust, etc.) and the black marks water will make on old wood furniture usually around nail holes. It is only available from a pharmacist as it is a poison. Comes in a small plastic bottle. White crystals. I dissolve a small amount in water. Say 1/2 tsp to 1 tbs water. Brush it on and let it sit awhile. Occurs naturally in rhubarb leaves. I believe it is also an ingredient in Bar Keepers Friend. Good luck, Raz
Old 02-21-2011, 09:40 AM   #16
Roger C H's Avatar
You could change your attitude. Look at it as a decorative swoosh like on those big motor homes. From the picture, I think it looks sort of cool!
OTOH, you could stain the rest of the surface and have a blue shower stall.
If you must get it up, I would try Bon Ami. It is a cleanser that doesn't scratch.
Old 03-12-2011, 12:42 PM   #17
Roger C H's Avatar
Wink Blues Stay Away From My Floor
I emailed Thetford since they make "The Blue Stuff" and here is the answer I received:
Per our chemist:
"They can use a powder bleach (Clorox 2) and water paste on the fiberglass shower stall. Use a small brush to get the paste into the groves and let it set a few minutes and rinse away. It may take a few applications if the stain has spread deep into the fibers. Please be sure that the stall is clean and no ammonia has been used for at least the last 24 hours."
Thanks,
Darlene
Consumer Service
Thetford Corp/Norcold Inc
There you go from the horse's mouth so to speak.
Note on title: I remembered a song, "Blues Stay Away From My Door." It turns out it is an album:
http://www.answers.com/topic/blues-s...y-from-my-door
Old 03-17-2011, 04:11 PM   #18
2yax2go's Avatar
Trailer: Escape 21
South Carolina
Thanks, Roger...that was very kind of you to go to the trouble.
I'll pick up some Clorox 2 next trip to the grocer's and we'll give it a try. If it takes a few applications that will be fine.
Who knows I may get used to it over time, eh? Maybe to a tie-dye effect on the whole thing reliving my hippie days. (smirk)
We're also thinking about getting some of that Dry Deck stuff to put in there so I don't slip and fall climbing on to the jon if that floor happens to be wet (I'm barely over 5')
J of J & C
"Not all those who wander are lost." (J.R.R. Tolkein from Lord of the Rings..."Strider's Poem")
2yax2go is offline   Reply With Quote
Old 03-17-2011, 07:51 PM   #19
You're the MAN Roger
For the aged-challenged in the group Mike Price Jokes, Stories & Tall Tales 13 08-10-2012 02:22 PM
Christmas Carols for the Psychologically Challenged Roy Bakehorn Jokes, Stories & Tall Tales 2 12-24-2010 11:26 AM
Help for the Depth Perception Challenged Lisa H. Towing, Hitching, Axles and Running Gear 10 05-05-2008 08:58 PM
Solar Challenged Tamid Electrical | Charging, Systems, Solar and Generators 5 06-27-2007 07:32 PM
Help for the Depth Perception Challenged Lisa H. Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
