The Blues and Chemically Challenged - Fiberglass RV
Old 02-12-2011, 09:12 AM   #1
2yax2go's Avatar
Trailer: Escape 21
South Carolina
Not me. The shower stall floor has a blue stain from a toilet bowl cleaner or what is in porta a johns. The liquid sat in the bottom of the shower under a platform and was concealed from sight. The other day after I removed the platform there was a puddle of dark blue chemical sitting there. I soaked up the fluid with some paper towels and dried it off. I first tried some all purpose cleaning fluid and nothing happened. I have since tried a c-l-r type product and also bleach with no results. So before we go and spend a lot of time and money tiring all sorts of products we come here to the experts for options and possible answers.
Thanks Josie’s other half.
"Not all those who wander are lost." (J.R.R. Tolkein from Lord of the Rings..."Strider's Poem")
2yax2go is offline   Reply With Quote
Old 02-12-2011, 10:53 AM   #2
Robin G's Avatar
Trailer: 2007 Casita
hmmmmm, Have you tried soft scrub? I would use SOFT SCRUB brand versus off brand. Don't scrub! Just put it on, let it sit and see if if bleaches it out.
The one and only time I bought an off brand toilet bowl cleaner it did the same thing to my toilet seat. When I squirted it out into the bowl I got some on the seat and I left it while letting the cleaner soak and clean the toilet bowl. I was shocked it stained stained the seat. Honestly I don't remember ever getting the stain off the seat. I think I finally broke down and bought a new toilet seat.
Old 02-12-2011, 12:55 PM   #3
Mike Morrison's Avatar
Trailer: Arctic Fox 22G
Couple of things I would consider trying: Mr. Clean Magic Eraser or a fiberglass cleaner/wax (although it could make your shower floor a bit slippery )
Mike Morrison is offline   Reply With Quote
Old 02-12-2011, 03:59 PM   #4
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2007 Toyota Tundra/2015 Tundra
Montana
The dreaded blue slop over. As I recall it goes away with each cleaning as it does when you get it on your hands. OOOh! I have learned it is better to have it in the black tank then in the bowl of the toilet while in motion.
Cyndi B. is offline   Reply With Quote
Old 02-12-2011, 04:11 PM   #5
Trailer: 21' Escape - former owner of 17' "other brand."
Put the platform back in.
Old 02-12-2011, 04:21 PM   #6
I just Googled for an answer and came up with these:
1) Bleach AND Magic Eraser together.
2) Soak rag(s) in bleach, lay on stain, cover with plastic to hold in fumes, etc. check in an hour
3) Hydrogen Peroxide.
I'd try: Bar Keeper's Friend or a cleaner/wax (like Gel Gloss) .... then REMOVE the wax so the floor isn't slippery.
Frankly, I like Ray's suggestion the best. This may be a stain that only time will lighten.
Let us know what works!
Old 02-12-2011, 05:22 PM   #7
2yax2go's Avatar
Trailer: Escape 21
South Carolina
We will keep trying the normal household remedies and continue our search for the answer if there is one. The other thought was to get some blue stain and do a tie-dye type look on the bottom. As you might imagine that went over very well with Josie (Not) even though she's a child of the sixties.
The platform is also another challenge but will keep for new thread/repair.
Old 02-14-2011, 12:40 PM   #8
My first try would be 3M restore and wax - works well at taking off all the stains I have challenged it with.
Old 02-15-2011, 06:09 PM   #9
cpaharley2008's Avatar
A piece of indoor/outdoor carpet cut to fit. Allows water to drain but keeps your feet off the floor bottom.
Old 02-16-2011, 11:22 PM   #10
Trailer: Casita 17 ft Liberty Deluxe
CAUTION!!!!
Frequently, people carelessly mix different cleaning chemicals and generate poison gases....chlorine gas, phosgene gas, ?.
Mike
Mike Price is offline   Reply With Quote
Old 02-17-2011, 05:35 AM   #11
2yax2go's Avatar
Trailer: Escape 21
South Carolina
Thanks, folks for the ideas. (as well as the caveat about mixing chems...fortunately the mister is savvy to that and nothing is done without opening the door and windows just in case...the area is also well washed down before the next application.)
Thus far the only reaction has been to turn a spot pink after letting liquid dishwasher soap soak on a portion of the floor.
I could end up with tie-died after all. (snort)
A call to a local shop specializing in commercial cleaning products netted nada.
It may just end up being one of those things we learn to live with. We've considered blocks of that dry-deck stuff just to keep the slip factor down.
The only real challenge to nothing in the floor is that I am barely over 5 feet tall...it's sorta like watching one of your kids on the john feet swinging in the breeze, yanno? Mister oth is nearly 6 feet...no worries there.
One thing fershure is that it will NOT be stopping us from taking Li'l Scamp on the road as soon as our schedule allows.
Old 02-17-2011, 10:11 AM   #12
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
Contact the maker of the original cleaning product and ask them what to use.
Old 02-17-2011, 02:41 PM   #13
Trailer: (fiberglass)
the blues
I had the same problem when a tank deodorizer pack was left in the shower and got wet. I am only saying what worked for me. The works toilet bowl cleaner i found at big lots. put on some rubber gloves and glasses and put it on a rag and wipe it on the stain,wipe with a dry rag then rinse with water and baking soda. I am only saying this worked for me on the same problem. Don't put the bowl cleaner on the stain wipe it with a rag. Don't get this stuff in your eyes and open the place up the fumes will get to you.
ScottG is offline   Reply With Quote
Old 02-17-2011, 04:55 PM   #14
Robin G's Avatar
That might work cause that is the only product that I believe could dissolve concrete!
It's wicked stuff, especially the fumes so as Scott suggested get air flow going before you even put it on the rag. Whew!
For the aged-challenged in the group Mike Price Jokes, Stories & Tall Tales 13 08-10-2012 02:22 PM
Christmas Carols for the Psychologically Challenged Roy Bakehorn Jokes, Stories & Tall Tales 2 12-24-2010 11:26 AM
Help for the Depth Perception Challenged Lisa H. Towing, Hitching, Axles and Running Gear 10 05-05-2008 08:58 PM
Solar Challenged Tamid Electrical | Charging, Systems, Solar and Generators 5 06-27-2007 07:32 PM
Help for the Depth Perception Challenged Lisa H. Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
