Originally Posted by Trudys Mom
Been checking out the lines, the shower was draining slowly...so cleaned trap, and replaced a kinked drain line below. Waiting on a new drain valve for the fresh water tank (project 1), so I got a bucket of water to put down the shower drain, DH watching below to see if there are leaks. He yells there is water coming from the BLACK water floor hole. (Water down the toilet does not leak) I am seeing a trip to the repair place.....or am I wrong?
1] Front bath or side bath?
2] If front bath, did you clean the screen?
3] If front bath, does the pump run all right?
4] If you spilled water on the floor at the toilet level then water coming out around the black water drain hole would be normal and nothing to be concerned about.
5] the line from the trap is small enough that it can get clogged with hair and debris. You may need to simply disconnect the line and manually clean it out. A wire coat hanger will work fine. insert it with the twisted end first and turn it like a screw to grab the hair.
6] No worries, it sounds like nothing a screwdriver, a coat hanger and a few minutes work won't solve. Give it a shot... you can do it!!
