Tire Pressure - Fiberglass RV
Old 07-08-2007, 06:39 PM   #1
Pete Dumbleton's Avatar
Learned a good trick from another RV group. If you are using tires that can have their pressures adjusted to suit a load or load range (actually any tire can do this, but typically only ST and LT tires have load tables with more than one pressure) and if you are using tires that may be rated higher than you need (typically this would happen when you replace your original tires with a higher Load Range, such as LR B's replaced with LR C's), how do you know you have the right pressure for your load without a lot of fussing at the scales? (Umm, the presumption here is that you have indeed already done some fussing at the scales to get your load and balances right...).
Simple suggestion -- Take the trailer, or truck for that matter, to a piece of nice, flat, pavement and mark a chalk line across the tires in question. Rotate the tires a couple of times and then look at the lines. If they are erased in the middle but still there on the outsides, the pressure is high. If erased on the outsides but still there in the middle, the pressure is too low. If evenly erased, the pressure is just right.
Be sure to actually measure the final pressure and compare it to your tire manufacturer's Load/Inflation Charts to ensure that it is in the right ballpark.
Old 07-08-2007, 07:22 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
...and you'd be doing this test with K L tires, not after driving around the block a coupla times....
Old 07-11-2007, 05:45 PM   #3
Joe Z's Avatar
New River AZ
What a great test......... never heard this one but it sounds very logical. I have a set of new tires coming any day and will definately try this trick.
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 07-11-2007, 07:55 PM   #4
Ian-Vicki's Avatar
Name: Ian or Vicki
Trailer: 17 ft Burro Widebody / 2007 Explorer Sport Trac
excuse me, but if these are eggs, shouldn't we be using Yolk=ohama tires? Just thought I'd ask.
Ian-Vicki is offline   Reply With Quote
Old 07-12-2007, 05:44 AM   #5
Alf S.'s Avatar
Hi: This test sounds to be "over easy" but might certainly keep your "Egg side up"
Old 07-13-2007, 04:37 PM   #6
Doug Mager's Avatar
...well thats 'eggsactly' what we had in mind, LOL!!!
Old 07-13-2007, 05:37 PM   #7
Greg A's Avatar
Trailer: 2015 Escape 19
I just couldn't be more 'eggscited' about this.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Tire Pressure Pat C Towing, Hitching, Axles and Running Gear 9 07-01-2010 01:38 PM
13' Scamp tire pressure Jeff Larsen Towing, Hitching, Axles and Running Gear 4 08-02-2009 02:58 PM
Need Help with the Right Tire Pressure for a New-to-Me Burro DENNIS GOULD Problem Solving | Owners Helping Owners 4 02-28-2008 02:24 PM
Tire Pressure Ron and Alma Care and Feeding of Molded Fiberglass Trailers 7 04-22-2006 04:01 PM
Gas mileage vs. tire pressure General Chat 0 12-31-1969 07:00 PM
