To lube or not to lube, THAT is the question... - Fiberglass RV
Old 08-14-2011, 10:05 AM   #1
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
We are considering oiling/lubricating our trailers tongue jack as it is becoming hard to operate.
WHAT if any lubricants work well for these things? It's a swing down hand crank device...
Old 08-14-2011, 10:14 AM   #2
Looks like the knuckle buster on my Scamp. On mine, there's a small hole in the top. I give it a shot of WD40 every once in a while. Seems to work just fine... doesn't help my knuckles tho
Old 08-14-2011, 10:35 AM   #3
honda03842's Avatar
Name: Norm and Ginny
I give it a shot of silicon spray every now and then, Same thing with the door lock.
Norm
Old 08-14-2011, 11:16 AM   #4
Doug Mager's Avatar
Originally Posted by Donna D. View Post
Looks like the knuckle buster on my Scamp. On mine, there's a small hole in the top. I give it a shot of WD20 every once in a while. Seems to work just fine... doesn't help my knuckles tho
....thanks for that quickie (response, I mean) but I am at a loss as to just what produce WD20 is... Is this product a new n improved version of the old WD40??? Doesn't this stuff (and the delicon spray) act like a dust magnet??? We have about 5 outings for the trailer coming up in the near future and I'm starting to get concerned about this OLD CRANK, LOL!!!
(NO, not the TRAILER GODDESS ....)
Old 08-14-2011, 11:22 AM   #5
Coffee, coffee... I need more coffee!
Old 08-14-2011, 12:29 PM   #6
Trailer: 2005 13 ft Trillium Outback
If you can take it apart or get some access to the gearing, I recommend some white lithium spray lubricant. I got what I use from NAPA. It's a heavy duty metal to metal lubricant. Will not wash off, melt or freeze. Also, OK for use in all States.
I have an 8,000 pound portable 55 foot tower trailer that has 7 seven screw type jacks and the white lithium grease works great.
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 08-14-2011, 12:43 PM   #7
honda03842's Avatar
The (d)Silicon doesn't seem to collect dust, it's a very light coating. I simply spray it down the shaft from the top. For the door lock I spray it into the end. I use it because it's really slippery, does the job and I don't know how to take the jack apart.
I will say if you don't lub it it can feel stiff.
It's definitely not as permanent as the white grease solution.
Norm
Old 08-14-2011, 01:22 PM   #8
Doug Mager's Avatar
While Donna goes n refills her coffee urn, ....we sprayed a little of that 'WD20'(??) into the oil hole and worked the crank a few times to help spread it around inside the tube. It seems to help. Its was all I have on hand that I thought might work... I doubt I could take the tube apart without some serious w, wo, wor, wor_! Yuch I hate that word!
Old 08-14-2011, 02:32 PM   #9
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Doug Mager... What wa... wa... w irks one doesn't always the other. I use Dura Lube...but it only comes in a non aerosol squirt bottle. Great to lube the old crank stabilizers!!!
Alf S. North shore of Lake Erie p.s. WD20 seems 1/2 cut to me...LoL
Old 08-14-2011, 03:08 PM   #10
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
With all due respect, lube with a lubricant. WD 39 (well it would have been 39 if the 39th concoction had worked) is deodorized kero, a water displacer and half-effective penetrating oil and little else. Don't see why the ancient squirt can of 30 wgt. or even a little can of 3-in-1 wouldn't work.
jack
Old 08-14-2011, 04:36 PM   #11
Greg H's Avatar
Trailer: 72 Boler American
Indiana
can you still get Graphite? That's good stuff.
Old 08-15-2011, 10:53 AM   #12
Trailer: 13 ft Ventura
Limits of WD40
WD40 works best to loosen things up or displace water from electrical things, but is too thin and solventy to perform well as a long lasting lubricant.
I think white grease would be ideal if you were taking the jack apart and reassembling it; otherwise, I'm pleased with the results of Duralube in most oiling applications. I've Duralubed some deadbolt locks and they worked so smoothly after it felt like they had broken mechanisms.
Darrell O is offline   Reply With Quote
Old 08-15-2011, 09:30 PM   #13
Night Sailor's Avatar
Connecticut
WD40 is a very successful product but really a poor quality product.
For freeing stubborn rusty nuts use PB Blaster.
For lubricating things like this or door hinges, use spray lithium grease.
Old 08-16-2011, 06:14 AM   #14
honda03842's Avatar
I'd never heard of PB Blaster or Duralube but both appear to be available every where including Walmart and Canadian Tire. Thanks for the tips.
Norm
Hi, and a question. bendan Hi, I am.... 16 04-21-2011 11:33 AM
Hello... I have a question! Dale AZ Jokes, Stories & Tall Tales 4 04-05-2011 11:57 PM
Oil Bath Bearing Lube Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 13 04-10-2009 02:09 PM
Bearing Lube Systems Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 3 05-22-2008 07:57 PM
Answer a Question then Ask a Question CarolnJim General Chat 77 06-03-2006 11:39 AM
