I have begun the odyssey of researching 13 foot egg trailers. I like 'em. Escape says they don't put rivets through the shell. (Quality.... but probably drives cost up.) Other brands like scamp and ???? do use rivets. So, are rivets a negative? Yes, they don't look as clean from the outside. But do they ultimately usher in leaking problems or become starting points for cracks?
I have one of each. Love both. Rivets and snap caps are maintenance issues and all brands of all molded towables have maintenance that needs to be done.
Do I see a problem with rivets? No, they do exactly what they're supposed to. Not hard to replace either. Scamp uses a bunch more than they need too... but there's solutions for new buyers.
Whether they look bad, that's an individual call. Frankly, I've never been concerned. It's always been more about where I went with my Scamp and the memories I made. YMMV
If you have ever had to repair an infiltrated or broken mounting block, you would sing the praises of rivets.
Rivets are the longest standing construction method (by decades) used on fiberglass trailers. They have proven reliable and easily repairable when an occasional rivet does break. Only failed rivets are capable of seepage.
I have owned several 30+ year old fiberglass trailers which have shown no signs of rivet failure in spite of decades of use, neglect and abuse.
BTW "through the hull" fasteners are not limited to pop rivets alone...
The Scamp Deluxe trailers are use screws for the primary fasteners.
Mine is eleven years old with maybe 70,000 towed miles without a single failure.
Bottom Line.... This is a truly a non issue since all fiberglass trailers are superior to stickbuilts.
On the list of "matters of concern" this issue is easily at the bottom.
I thinking about this very issue just the other day. I need to do maybe 70% of the rivets on my 1988 Scamp. Not because the rivets went bad, but mostly because the washers they hold have crapped out, because previous owners did not replace the caps when they started to go. Even so, I have enjoyed the Scamp a year already without replacing a single rivet/washer/cap. A little caulk here and there and storing the Scamp out of the weather has gotten me by. I will say this, I would A LOT rather replace a bunch of rivets, one here and one there, than deal with a old falling apart stickie.
Yes fiberglassing in the fixtures does indeed result in a cost increase due to the extra labour and material needed to do it.
By not using rivets it will mean that there are far few places that a leak could develop over time - but keep in mind there are lots of 30 year old Bolers running around these parts that still have the majority of their original rivets & do not have leaking issues. Same with Scamp's and Casita's.
Replacing rivets is a DIY job that is pretty easy to learn. Regardless of whether or not your trailers main fixtures are fiberglassed in or not the reality is if you are wanting to maintain your trailer you will need to learn to rivet as there are many outside fixtures on both types of trailers that will break/fail over time I will need replacing and many/most are riveted to the trailers.
As has been suggested having to repair a fiberglassed in fixture should there be a failure is not so easy. I know if I had a fiberglass failure I would not even consider doing it myself, even though I have spent most of life around fiberglass boats and seen them repaired many times. The trailer would be heading off to the nearest boat yard or fiberglass trailer manufacture where I would pay a pro to repair it.
I own an older Scamp (24 years old) that I have had for 9 years, that I for the most part maintain & update myself. I set aside a few days each spring to do replacement/repairs on items that need fixing/replacing or due to their age should be replaced as part of preventive maintenance. I have no big complaints about the Scamp and have spent hundreds of days camping comfortable in it. I will admit though I would love an Escape & they are multiplying like rabbits so its getting harder and harder to keep my eyes turned away with each new one that appears on camping trips. But my main reasons for wanting one have nothing to do with the rivet or no rivet issue.
If two trailers you are considering are equal in regards to your needs, I suspect one could make the decision process easy as to whether or not to go with one that has fiberglassed in fixtures vs one that has rivets by asking yourself a simple question. Do you wish to pay now (higher purchase price) or pay later (with a bit of extra DIY maintenance)?
Well, it was FLOYD who sealed the deal. Thanks, I don't like to keep anything in my mind if it is unnecessary. I am now more apt to go Scamp or Casita because they are much easier to find.
Gesipa water proof rivet's are available in the US
and can be in stainless steel.
We have to get some for our boler, others exist that are blind pop rivet's
Be careful before trying anything other than aluminum rivets. Stainless Steel rivets will require substantially more compassion pressure before popping, possibly pulling through the fiberglass. I have encountered this when steel rivets were used in place of aluminum. At the very least I would use matching backing washers to keep the bulb from damaging the fiberglass.
Is there a more durable option for washers when using aluminum rivets? Like thin rubber or leather or??? I"ll be reinstalling the cupboards and seats in my Scamp and this very topic has been on my mind.
The backing washers should match the rivet used both in material and size. If you are wanting to use something like leather or rubber it will just squeeze out as the rivet pops or, certainly, not to much later. The plastic "Cups" used on the outside for holding caps in place, usually hold up, but have been known to split and certainly would if used with anything like a stainless steel pop-rivet as it will exert a lot higher pressure on it before popping.
Cathy
Early Scamps were built with conventional pop-rivets without caps, illustrating the fact that tight conventional pop-rivets do not leak.
About 35 years ago cosmetic caps and washers were added.
The way to preserve the washers and keep the rivets tight, is to replace the caps before the washers are exposed to the sun. The caps get grainy with sun exposure and turn gray before they start to crumble, so there is plenty of notice and all the caps can be replaced in about 30 minutes for about 20 dollars.
While an occasional rivet may break from stress or exposure to extremely rough terrain, preserving the washers by prudent and timely cap replacement will prevent 90 percent of rivet looseness or failure.
If you own a new trailer with rivets you're a potential victim to leaks. Just buy plenty of snap caps, rivets and silicone. You'll have them when you need them. I think Scamp sells the "kits" now....
Ironically, if I buy another fiberglass trailer, I'm going with the Escape to escape ALL the rivets. Scamp even uses them to install CURTAIN RODS. In my opinion, that is ludicrous and so unnecessary!!
You need to have all the opinions and not just the ones that havent had any trouble. Mine was bought new at the factory 2010 Standard model. And I lost what I consider 2 MAJOR rivets at my closet that seeped water in during a trip home. This was when it was 3 yo. I have photo proof at the bottom of this post. I replaced them with #10 bolts and nyloc nuts. I just had ANOTHER rivet loosen on my top galley cabinet and was leaking! My Scamp is used apx 3-4 times a year. The rest of the time it's stored under a carport out of the sun. We just had ANOTHER large discussion of these rivets on another topic. One of the problems of loosening is, they "sandwich" the insulation and ratfur in between the two pieces of fiberglass- cabinet/shell. You may not have a rivet to "fail" and break, but it can loosen. You'll hear "User induced". That's hogwash. No one will try and take better care of their trailer than I will. They're still fiberglass with rivets.
Keep in mind Floyd's trailer is the "Deluxe" with the wooden interior. The wooden interior cabinets are held in place by screws, not rivets. So he couldnt have a rivet failure on the cabinet mounts. Just saying... Aint bashing Floyd's trailer... I've seen it and we've argued "Ford/Chevy". He's a "master" of knowledge on the Scamp but we DO disagree on the rivets and will. Anyway, the wooden interior is also beautiful...but my wife didnt care for it...too dark she says.
As a fleet mechanic, I learned that absolutely everything breaks sooner or later.
Your trailer is beautiful and well made and I understand that you had a couple of rivet breaks on your bulkhead wall due to stress and did good repairs.
I fail to see how that experience could result in an indictment of a system which has 45 years of proven success.
True...My camper is a Deluxe, but I have also owned dozens of Fiberglass trailers of most types and seen every form of failure on them as well as on many many owned by others.
My conclusion remains the the same... This is a non-issue.
I look forward to your purchase of an Escape. I am sure you will provide the same objective critique for prospective Escape buyers as you now provide for Scamp owners.
Hummm you will soon discover once you taking possession of your new Escape the above is not true!
Like every other fiberglass trailer made the Escape does indeed use rivets. No not as many as a Scamp does but it does have rivets and you will also need to keep a supply of rivets of various lengths on hand and learn to use a rivet gun if you wish to maintain your future Escape or do any modification/upgrades to outside fixtures just as a Scamp owner will need to.
Don't get me wrong I think the Escape is indeed a very nice trailer but my top ten list of reasons for wanting one does not actually include the fact it has fewer rivets as my experience in owning an older Scamp for a number of years now suggest the extra rivets used in the build of them is not the big issue that some make them out to be.
As far as folks wanting a more robust rivet or replacing the rivet with some other mechanism for securing I would suggest that there is no need to reinvent the trailer! Years and years of use of the trailers have proven that aluminum rivets are the best product to use for the application. Anything stronger and you run a risk in cracking or breaking the fiberglass. Far better that a cheap rivet breaks & takes five minutes to replace than have the trailer do a big flex (and it will - even when just driving down the road) than have the fiberglass it is holding together crack or break due to the use of some stronger fasteners than aluminum.
If you want to test out just how much a fiberglass trailer will flex try parking it on a real uneven surface with trailer on a big side slant one wheel up much higher than the other and see how well the door opens or closes.
Have you tested or have proof that more secure fasteners will "crack or break" the fiberglass??? If you do, I want to see it.
[QUOTE=Carol H;520156]
