Tongue Jack Grease - Fiberglass RV
Old 08-19-2014, 12:27 PM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Tongue Jack Grease
Anybody know what name/type that forest green grease is in the Atwood tongue jack?
Called Scamp and Micah said they come in from Atwood already greased and he didn't know what they used.
Maybe synthetic? Mine needs greasing and I don't want to mix.
Thanks a bunch for your help.
Cheers,
Wendy
Old 08-19-2014, 12:42 PM   #2
When I looked into this a few years ago all the Atwood docs I could find indicated that just extending the jack and spraying with a light coating of silicone spray lubricant will do the trick. E-trailer also suggest the silicone spray lubricant. They didn't seem concerned with mixing the grease used.
Old 08-19-2014, 12:45 PM   #3
Green Grease/14 oz. (396.893 g.) multipurpose synthetic grease (101) | Lubricant/Grease | AutoZone.com
I myself use motorcycle spray chain lube since I have it and it goes on thin and then gels so it works in and stays put.
Old 08-19-2014, 12:48 PM   #4
Trailer: Bigfoot B-17 CB
It's not a critical application. I would use the same grease I use on my wheel bearings.
Old 08-19-2014, 03:52 PM   #5
The Minimalist's Avatar
Louisiana
That's it! 30W with a tack additive. Bet you don't have to do that often.
Clif
Old 08-19-2014, 05:52 PM   #6
CampyTime's Avatar
Oh my. After posting this I realized that what I meant was the gears above the tongue jack. There is a green grease now, but not enough. Thanks for all your help!
Old 08-19-2014, 05:56 PM   #7
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
This is most likely the same type of grease used originally, and what I would use too.
Colour does not matter, you could mix red with green. You also only need enough grease to coat the gears, not have the whole compartment filled.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 08-20-2014, 07:53 PM   #8
CampyTime's Avatar
I do have a 14 oz cartridge of that green grease. Don't know how I have it but I do. Maintenance for me when I get home. And my son has a dirt bike so I have motorcycle chain lube if I desire as well as silicone spray.
Tongue Jack Stand fits 2" jack FTTRV Commercial Posts and Products 7 06-20-2014 08:53 AM
Grease for Scamp Tongue Jack CampyTime Care and Feeding of Molded Fiberglass Trailers 6 11-02-2013 03:12 PM
Dielectric Grease vs Electrical Contact Grease Roy in TO Problem Solving | Owners Helping Owners 28 09-16-2012 07:23 PM
To grease or not to grease? Keith Williams Care and Feeding of Molded Fiberglass Trailers 49 06-27-2009 04:52 PM
Trailer tongue power jack The Hobo General Chat 9 02-24-2009 02:52 AM
