Tongue weights - Fiberglass RV
Old 03-08-2016, 10:49 PM   #1
Trailer: Shopping
Tongue weights
I'm hoping to find a 13' Scamp to pull with my 2002 Suby Forester. It's limited to towing 2,000# and tongue weight of 200#.
I believe the basic 13' Scamp meets this, but not the longer Scamps, nor the 13' DeLuxe. Are any of the other brands (Burro, Casita?) suitable?
Howard MP is offline   Reply With Quote
Old 03-09-2016, 04:33 AM   #2
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Have you looked at Fred's Trailer Weights in the Real World (near top of General Chat)? Has tongue weights of actual trailers for pretty much all fiberglass brands.
I haven't massaged his latest spreadsheet but the last time I did I found this:
Scamp 13 ave tongue weight: 223 lb
Boler 13: 213 lb
Casita 13: 260 lb
etc.
Quando omni flunkus, moritati
Old 03-09-2016, 06:14 AM   #3
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
We have a 2014 13' Scamp w/o bath. Tongue weight when the propane tank is full is about 201 lbs. This includes very basic travel items that "live" in the scamp, but not items like food, clothing, and other travel items that get loaded for each trip. Our normal travel tongue weight is closer to 220 lbs. You could theoretically keep the tongue weight below 200 lbs but in practical terms it would be difficult and even then you are skating on the edge - not a good place to be.
WDavidG is offline   Reply With Quote
Old 03-09-2016, 08:04 AM   #4
The last time I weighed my Scamp 13 tongue it was around 170 to 175lbs. The configuration is No A/C, no Water heater, no Awning, no Bath/toilet, Manual water pump. That was loaded for camping.
Old 03-09-2016, 12:16 PM   #5
Trailer: Shopping
Thanks, everyone. I figured I'd have to go with a minimum cargo in the trailer and load with ice, water, etc. upon arrival at or near my camp site. BTW, how does one weigh the "weigh weight?"
Old 03-09-2016, 01:08 PM   #6
IllAnnoy
If you find a Scamp13D, don't despair, it is well under 2000 pounds.
which means it can easily tow safely with less than 200pounds tongue weight.
Old 03-09-2016, 02:41 PM   #7
Trailer: Shopping
That was a dumb error! How does one weigh the "TONGUE weight!"
Old 03-09-2016, 03:19 PM   #8
Name: Frederick / Janis
Trailer: Previously Scamp 13 2002,2016. Scamp 16 on order
tongue weight
I set the tongue of this 2016 layout 1, on a simple bathroom scale.
Single propane bottle. No air, no bath, no awning. Packed as light as possible, but packing is always variable X isn't it.
182 pounds without the battery. 198 with the battery.
Hope that helps the decision making.
bpfick is offline   Reply With Quote
Old 03-09-2016, 03:21 PM   #9
Borrego Dave's Avatar
Trailer: Casita SD17 2006
A bathroom scale, but as all of us guys have been told "it's not the same as the Drs"
Borrego Dave is online now   Reply With Quote
Old 03-09-2016, 03:24 PM   #10
Sometimes the one at home is indeed off a bit, but sometimes its not the direction you might think. In any case, it is a whole lot better than guessing.
Of course, a scale certified for doing business (fruit/produce, scrap metal, etc) would be best.
Old 03-09-2016, 03:25 PM   #11
Since the tongue weight and trailer both change a bit, a bathroom scale and a large dowel work just fine. The weight you get is approximate at best.
Old 03-09-2016, 03:26 PM   #12
Trailer: Shopping
Thanks. Did not realize it was that simple!
Old 03-09-2016, 03:53 PM   #13
Or, if you have some spare change, you can buy a Sherline scale, designed for the purpose. As my tongue weight is 320-340 lbs I got one. Be sure to order with a 1,000 lb. gauge as that is more accurate and easier to read than a 2,000 lb gauge.
Old 03-09-2016, 05:32 PM   #14
CampyTime's Avatar
Trailer: Scamp 13' Standard
I used the sherline tongue weight scale on my 13er and got 185 pounds. Basic simple necessities inside. Although I do have cedar ply shelving installed with 3/4" PVC pipe inside the closet.
weight
Dead tounge lift. fusedlight Towing, Hitching, Axles and Running Gear 10 09-19-2013 09:46 AM
Trailer Weights...What are They Really? Pamela H Care and Feeding of Molded Fiberglass Trailers 55 12-01-2009 01:21 PM
Wheel Weights with Bathroom Scale Pete Dumbleton Towing, Hitching, Axles and Running Gear 6 05-20-2009 12:18 PM
Realistic Tow/Cargo Weights V'sGlassSleeper General Chat 25 07-18-2007 12:11 PM
Need 1977 Surfside 14' Weights Raunie Aasland Problem Solving | Owners Helping Owners 2 04-24-2006 07:12 AM
