06-23-2008, 04:08 PM
Trailer: Scamp 16 ft 1996
Has anybody found a good touchup paint to match the Scamp white?
06-23-2008, 06:35 PM
Depends. New trailer or old trailer? White doesn't stay white forever, it has a tendency to age.. like fine wine! Anyone that's taken the decals off has found they "ghost." Remember too, the trailer wasn't painted, but that's gel coat.
So, what's the problem? Maybe we have better solutions than paint.
06-23-2008, 09:09 PM
It is an 82 Scamp. There are some minor dings that need filling, such as a deep scratch
caused by the door opening with the windows out. Also there are some small patches that look like repair patches that are now gray and need to be covered with gel coat or paint.
Thanks for any advice.
06-23-2008, 09:28 PM
Ron,
I have the same repairs I'm making on my 81 13 Scamp.
Somewhere I was referred to Krylon Gloss Ivory Color Creations, which I found an 8 oz can at Wally. Not
perfect, but it matches the sun bleached areas really well.
Using a Marine fiberglass patch I got at Lowes to fill holes and dings and
touching up with the Krylon. The paint looked too glossy at first, but now that I'm doing
the two step Meguiars restoration on the shell it is matching up much better.
06-24-2008, 07:51 AM
I just had a place fixed near the top of my trailer where someone thought they were doing a job of 'fixing' NOT! the guy sanded and repainted and its just like nothing was even there that had been wrong... I will try to get the name of the paint they used....
07-03-2008, 03:34 PM
Trailer: 13 ft Scamp
Any updates to this? I have two little divot holes near the door of my 2003 scamp. They allmost look like someone shot it with a BB gun. I filled them with a bondo type filler and sanded, but still need to find a good paint to match up.
Thanks.
07-03-2008, 07:29 PM
Trailer: 1983 Scamp 13 ft Standard
For what it's worth, I've used a White Fiberglass Repair kit made by Elmers Glue that did a great job as filler, it didn't need painting unless I sanded too deep and removed the original gelcoat.
The kit comes with a tub of white cake frosting thick fiberglass resin, a tub of white cake frosting thick oxidizer, some fiberglass cloth, and some flat plastic squeegee applicators. You blend the two creams together and butter it on where you need it. Sets up in a hour and cures in 24. It's white, white, white. Buff sand it and you're done.
Elmer's, Fiberglass Repair Kit
I found it at Lowes.
ConwayBob
07-03-2008, 08:34 PM
Trailer: 1974 Trillium 13 ft
Marine-Tex putty found in marine supply stores is also already white and is super easy to work with.
07-04-2008, 12:13 AM
Trailer: 84 Burro 13 ft
at Home Depot I found an appliance touch-up paint. It is an epoxy and comes in white and beige. The container is small but has a brush attached to the lid, kind of like fingernail polish. I used it on very small dings and to paint over old screw holed that I had filled with marine epoxy. I am happy with the results but it is for small touchups.
07-06-2008, 09:34 AM
I second the Marine-Tex epoxy putty or similar products. They're easy to use, match gel coat perfectly and fair down to exactly the same texture as the gelcoat. I'd never use paint over gel-coat unless you're doing it for accents or to repaint the whole trailer.
Roger
07-30-2008, 12:03 PM
Thanks to all of you for your suggestions. I went to our local Lowe's to find the Elmer's fiberglass kit, but they did not have that. They had the fiberglass resin with hardener in about a quart can and they had Elmer's All-purpose putty repair kit for fiberglass , concrete, and other misc. I took that. It is an epoxy that you slice off a small amount and knead together. It worked okay but dried to a light gray color rather than white. I took a color swatch of various white colors and found a close match. At a paint store that sells to body shops they found a spray can on the shelf that matched pretty close. I tried it and it looks okay. I also polished our Scamp (82 13') with Starbrite fberglass
color restorer and then waxed it with car wax. I probably should eventually use a wax made for fiberglass such as Meguiars or 3M. Ron W
