Trailer chocks and level blocks - Page 3 - Fiberglass RV
Old 04-20-2016, 02:42 AM   #29
Borrego Dave's Avatar
Trailer: Casita SD17 2006
I have a driveway that sloops down and sideways - wondered if one could just use the Anderson on top of a long layer of legos..... or would that be asking for trouble? slip?
Capitalize the word slip.....
Borrego Dave is online now   Reply With Quote
Old 04-20-2016, 07:11 AM   #30
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
Yeah I wouldn't do that.
The rapid jack even comes with a rubber "grip", to give extra traction for using on pavement.
I bought the rapid jack and two chocks. The Andersen leveler only gave 4" of leveling so I went with the rapid jack to get 8". Worked for me so far.
Old 04-20-2016, 07:23 AM   #31
Curious, Zach... when using the Anderson leveler without a spotter, can you feel when it's reaching the top? Have you ever run off the back?
Old 04-20-2016, 08:28 AM   #32
Thom Rowland's Avatar
Unless it is a really severe side slope, I don't think a layer of "Lego" blocks would be necessary. I sometimes park my Scamp in a driveway that slopes down and to one side and I do not need any blocks under the Anderson. It would depend on how severe the side slope is. Don't know if I would advise using the Anderson on top of Lego blocks but I have never tried it so I can't say if it would work well or not.
Thom Rowland is offline   Reply With Quote
Old 04-20-2016, 11:55 AM   #33
ZachO's Avatar
Montana
Actually I can see it, well enough. I can see just enough with my side-views that's it's fairly obvious. There's still a possibility of dropping off the back but I think with care it should be pretty easy to avoid.
I just go slow and get out and check the level pretty often.
Old 04-20-2016, 02:04 PM   #34
Its a 6" side to side drop and my understanding is the Anderson will only give a 4" lift. Its also has a 21" tongue to rear bumper drop....
Thanks all for confirming that my initial thought that using the Anderson on top of legos for extra height is not a good one, which is why I have not tried it.
Old 04-20-2016, 02:10 PM   #35
Yup thats what I though but now that I have dual axle trailer I am having to use A LOT of blocks to build the ramp up for it.... had though the use of a couple of Anderson's MIGHT help on that front but was to worried to try it.
Plan to pick up a couple of Anderson's for general camping though!
Old 04-20-2016, 02:21 PM   #36
ZachO's Avatar
Montana
This is why I went with the Andersen Rapid Jack. 7" of leveling.
Old 04-20-2016, 02:45 PM   #37
Unfortunately that does not work as a level for a dual axle trailer as it will not fit between the tires - well that is what I was told at the local trailer dealer and E-trailer seems to agree.
Old 04-20-2016, 03:00 PM   #38
Carol, your driveway sounds like one of the sites we saw at Lake Pleasant. It was a gorgeous, large site with perfect lake views, but sloped front-to-back and side-to-side. The day we left a large, dual axle sticky moved in and was sitting cock-eyed. Apparently they ran out of leveling blocks. The tongue was buried at ground level, wheels on blocks, and there was still a significant tilt on both axes. You sure wouldn't want anything to slip there, either- it was downhill into the lake!
At least once you figure out how to level it at home, you'll have 95% of campsites covered!
Old 04-20-2016, 03:02 PM   #39
I had some what the same problem at one house. I built a ramp out of 2x10 or 12s for the low side that I could back up on for home storage. Worked out fine and was cheap to build. I didn't need it at the next house......I'm pretty sure the ramp ended up in the fire drum .
Old 04-20-2016, 03:40 PM   #40
ZachO's Avatar
Montana
Ah, so it will work as a jack for tandem axle trailers, but not a level?
Oh well.
I will probably buy a couple lego blocks for stabilizer pads, but for leveling, the Andersen is really, really nice.
Old 04-20-2016, 03:44 PM   #41
Carol, your driveway sounds like one of the sites we saw at Lake Pleasant. It was a gorgeous, large site with perfect lake views, but sloped front-to-back and side-to-side. The day we left a large, dual axle sticky moved in and was sitting cock-eyed. Apparently they ran out of leveling blocks. The tongue was buried at ground level, wheels on blocks, and there was still a significant tilt on both axes. You sure wouldn't anything to slip there, either- it was downhill into the lake!
LOL Not far off in the description of it but an ocean rather than lake view. I did not mention that on the side the trailer needs to hug up against its a 10' drop with only a 3" brick lip stopping it from going over it.
The driveway wasn't really an issue for my Scamp as leads down into a nice flat large carport that the Scamp fits nicely under.... but not the case with the new trailer, so it has to stay out on the driveway.
Dave the original plan was to build a ramp from wood but right after I pulled the new trailer home the decision was made to sell my home of 20+ years. So needed to change my focus to that. Good news is due to the current crazy housing market here it went very fast.... bad news is I need to find a new home...so focus is on that now.... BUT I can tell you one thing the new house will have a NICE BIG flat spot for the trailer and in my perfect world it will be covered as well.
Leaving the big city life behind with all its building restrictions and going onto Island time, so hopefully my dream is not overly unrealistic.
Old 04-20-2016, 03:49 PM   #42
Yes, to use it as a jack on the front wheel of a dual axle you would need to put it ahead of the front wheel and pull forward onto it or put it behind the rear wheel & back onto it to lift it.
To level a dual axle you need two Anderson levellers so only the smaller ones will work - stick one behind the rear wheel and one between the rear and front wheel and back her up.
How level is level? Cam A Care and Feeding of Molded Fiberglass Trailers 29 05-27-2014 06:58 PM
Leveling blocks? Size & how many? Timber Wolf Care and Feeding of Molded Fiberglass Trailers 11 04-07-2014 01:38 PM
Blocks for 1979 17' Boler Eric-Lyne Modifications, Alterations and Updates 6 05-07-2012 05:23 PM
2 or 4 wheel chocks for a single axle trailer? JohnF Towing, Hitching, Axles and Running Gear 36 11-05-2011 12:12 PM
How level is level? DaveK Problem Solving | Owners Helping Owners 8 06-06-2007 11:03 AM
