Trailer Dimensions - Fiberglass RV
Old 09-03-2007, 09:12 AM   #1
Administrator
Mary F's Avatar
A la the Bed dimensions topic, let's compile a list of dimensions of the various molded fiberglass travel trailers.
It's been suggested that we want:
Exterior Length (from tip of the tongue to back of the bumper)
Exterior Width
Exterior Height (mention if rooftop Air Conditioner or vent cover is included)
Interior Height (floor to ceiling)
And, also, possibly, distance from the door (threshold) to the ground...
Please be clear about which model of which brand you are reporting, and also if you have made modifications (such as larger wheels or high lift axle) that would affect the comparisons.
If there's interest, we could list bathroom dimensions in a separate topic.
Anybody got a measuring tape? Thanks!!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 09-03-2007, 09:31 AM   #2
Brian B-P's Avatar
I think that this is a good idea, but it would be nice to do it efficiently. There was an earlier comparison table attempt, which seemed to go off the rails when it attempted to include too much information; that list (which was presented as a PDF file) should have lots of these basic dimensions already gathered.
There are a few bathroom dimensions in topic about the Biggar and Trillium 5500.
Old 09-03-2007, 09:46 AM   #3
Administrator
Mary F's Avatar
Where is it, Brian? I'm not actually talking about comparing (reaching any conclusions); I'm talking about just listing the afore-mentioned measurements, like Mike Watters did with the bed sizes.
Old 09-03-2007, 11:00 AM   #4
Mike Watters's Avatar
Trailer: Amerigo & Trailmanor (popupish)
Indiana
Are you thinking of assembling it all into one big spreadsheet of specs?
A few humble suggestions:
Some measurements are likely more critical than others. For most, exact total length isn't a serious issue and a rough measure may be sufficient - but total height is more critical (garage-ability). Interior height is very critical for some (at 6' you'd think it would matter more to me than it does).
The height of the step into the trailer would be VERY good information for people who are mobility impaired. I sure as heck noticed the difference when we went from the Boler to the Esterel.
Listing the unloaded weight would be a nice addition as well - but harder to collect. I wouldn't trust the advertised numbers - so you'd have to take an empty trailer into a set of scales.
I -do- think Brian makes a good point about data overload. If the chart has too much, it becomes awkward to use and then isn't. Besides - you don't want to answer every comparative question someone might have. They're good conversation starters.
In short: The K.I.S.S. principle applies. Perhaps an extensive list could be compiled of every measurement that MIGHT be included in such a table and then ask people to vote on their 5 - 10 most important when buying. Then just include the top vote getters.
Mike
Mike Watters is offline   Reply With Quote
Old 09-03-2007, 04:01 PM   #5
Administrator
Mary F's Avatar
No! That's way too much work, and like you say, the published weights of the different trailers are too unreliable.
I am just thinking of making a table, in this topic, like the one you put together for the beds. The only dimensions on it are going to be length, width, and height -- with height divided into exterior, interior, and from ground to door threshold.
If nobody wants to do it, that is completely and totally fine with me, too.
Old 09-03-2007, 04:18 PM   #6
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
Mary,
Here are the measurements on our 1982 13' Scamp:
exterior length: 13' 6"
interior lenght: 10'
interior width: 6' 6"
interior height: 5' 11" (it's supposed to be 6' but I didn't find that anywhere!)
threshold height: 8 1/2"
I wasn't able to measure the exterior height or width but based on the above info, a good estimate of the exterior height would be 6' 8" (without roof vent.) The exterior width would be about 6' 9" (including belly band.) No modifications have been made that would affect any of these measurements.
Hope this helps!
Sandra
Sandra Lair is offline   Reply With Quote
Old 09-03-2007, 06:10 PM   #7
Administrator
Mary F's Avatar
Thanks, Sandra!
Old 09-03-2007, 10:34 PM   #8
Trailer: Fiber Stream
Talking
My 1978 Fiber Stream 16'
exterior length: 16' 0" from hitch ball to back wall. 16' 4" if you include my bumper modification.
interior length: 13'4"
interior width: 80" (6' 8") measured at floor; 78" (6' 6") measured at the roof.
interior height: 75" (6' 3")
threshold height: 18" (due to "Flipped" or spring over axle mounts)
exterior height: 8' 4" to the top of the Fantastic Fan vent cover.
Old 09-04-2007, 08:27 AM   #9
Alf S.'s Avatar
Hi: I got two measuring tapes Can't find either of them
Old 09-04-2007, 12:16 PM   #10
peterh's Avatar
I understand that problem, 'cept mine is a two step one. First, my several measuring tapes often don't make it home after I use them, so I have to hunt them down so I can pull their little gradient things out.
This, of course, requires that I be able to see well. I have several pairs of reading glasses, but I often put them down somewhere . . .
--P
Old 09-05-2007, 05:51 AM   #11
Trailer: Bigfoot 20 ft 5th Wheel
I have no problem locating either of my tape measures...I phone my oldest son and..."Voila!" they are both at his house. This is handy since my trailer is still over there too.....
scott fraser is offline   Reply With Quote
Old 09-15-2007, 11:33 AM   #12
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
1973 Compact Jr. measurements
interior height 73" (with top up) & 65" (with top down)
interior width 71"
interior length 10'
exterior length 13'
exterior width 6'
exterior height 81"
threshold height 15"
Old 09-20-2007, 12:00 PM   #13
james kent's Avatar
Trailer: Boler 1984
Hey Alf!
All my outdoor, camping, and canoe related books have shown up over at my sons place. Not to mention tools and gardening equipment. Is this a genetic thing?
Old 09-04-2015, 04:23 AM   #14
Oma
Trailer: Scamp 16' named Alan
Massachusetts
We will be picking up our Scamp 16 foot layout 4 soon. I would like to know the width of the front door and the actual floor space from door to bathroom and bunks down to the start of the bed/table. Could anyone help me with this? I am trying to figure out if I can keep my dog in a soft crate and still get to the bathroom door if need be during the night
Thanks, Renee
Oma is offline   Reply With Quote
Bathroom Dimensions artspe General Chat 5 03-25-2009 04:35 PM
Underbed dimensions DoreenH Care and Feeding of Molded Fiberglass Trailers 0 11-17-2007 10:15 PM
Bed Dimensions David Smith Problem Solving | Owners Helping Owners 7 07-22-2007 02:12 AM
Window Dimensions Dennis Kelderman Care and Feeding of Molded Fiberglass Trailers 1 06-09-2007 06:38 PM
Need the dimensions of Compact 2 Gigi Problem Solving | Owners Helping Owners 12 05-26-2006 04:31 PM
Copyright ©2000 - 2018, vBulletin Solutions Inc.
