trill 1300 furnace - Fiberglass RV
Old 10-28-2015, 11:15 PM   #1
Trailer: 78 trillium 1300
trill 1300 furnace
Hi,
I have a 78 trillium. It has some hard miles on it but I'm working on bringing it bck to life.
Right now, I'm debating removing the furnace and using a catalytic heater (mr buddy?
The furnace seems to work fine but it takes up a lot of room and its almost 40 years old. I have read that they can become dangerous with age.
We also have a larger 2014 trailer and we seldom use the furnace. Its quite well insulated though and we generally try for electric sites so we use an electric heater.
However with the trill, I plan on being off the grid more if I go on outings without my wife.
I know there are condensation issues with catalytic heaters.
Has anyone any suggestions on size of catalytic heater etc?
Am I in the right forum for this question?
Thanks.
Mitch Drackett is offline   Reply With Quote
Old 10-29-2015, 08:53 AM   #2
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
Originally Posted by Mitch Drackett View Post
Hi,
Thanks.
You've heard of Propex?
It seems to be the best alternative to catalytic heater.
Propex North America • Propex Heatsource USA and Canada
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 10-29-2015, 09:23 AM   #3
Hi Gilles. Propex may be an alternative. For me the forced air part (and the cost) is an issue. I'm also considering a 12v fridge so dc power is a concern.
I won't rule them out though.
Old 10-29-2015, 09:25 AM   #4
most catalytic heaters are not rated for inside use .your better of with the one you have. with a thermal switch from a dryer and a small computer fan you can heat a lot faster and hotter on mine -5 no fan top heat +13 .-5 with fan +23 worked for me. Happy Trails.Mike
MAP 56 is offline   Reply With Quote
Old 10-29-2015, 09:38 AM   #5
David Tilston's Avatar
A Mr. Buddy heater is not a catalytic heater. It makes quite a bit of CO. I would not use one.
The furnace that is in your trailer is likely fine. Have a service tech check it out, but I have several of the same vintage. The fire box on each is solid. I have yet to find one that was in danger of rusting through. Who told you they were dangerous?
They are no longer allowed to be installed new. The surface temperature gets high enough that there is a theoretical danger of fire, but I have never heard of a fire starting this way.
While it looks like they take up a lot of space, they are installed in front of the wheel well. The vent goes over the wheel well. There is really not much space there. If your furnace works, I see no reason to replace it.
Old 10-29-2015, 09:50 AM   #6
Gilles's Avatar
Quebec
It could be a good alternative.
I did not find the English version of this document RCI, Radio-Canada International.
As against the video is in English ...
Un réfrigérateur * 30$, une invention canadienne lauréate d’un prix mondial
Gilles
Bigfoot 15B17G.
Old 10-29-2015, 10:31 AM   #7
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Have your furnace checked out , if it is good - keep it , it was designed for your unit so it is the best choice .
Bob in Mb is offline   Reply With Quote
Old 10-29-2015, 12:35 PM   #8
Trailer: G30 Elite Class C
12V fridge,
Hi,
Thanks.
Re if your going to go 12V on Fridge your going to use up that battery real fast, so make sure you install at least a 50W solar panel somewhere to pick up the sun or even on dull days it will stay charged to keep the Fridge going.
The solar panel will also help with the fan juice for the furnace.
stude is online now   Reply With Quote
Old 10-29-2015, 10:06 PM   #9
That's a great idea! If I get a 12v fridge, they apparently draw about 2 amps. Hopefully they cycle so its not a constant 2 amps/hour. I'm thinking a 70ah battery should yield about 24 hours of juice but.... so many variables.
My old fridge works but not well and I just know it will die the moment I set up camp somewherere. It took a day to frost up when it was in the 40's outside
That's the problem with a 40 yr old unit. Everything just kinda works!
Old 10-29-2015, 10:17 PM   #10
Lots of luck trying to run a 12V fridge on a 50 watt solar panel.
Old 10-30-2015, 12:04 AM   #11
Actually, I would probably use a larger solar panel for minimal extra cost. I think he had recommended "at least" a 50 watt.
Old 10-30-2015, 12:25 AM   #12
I think you need to do much more research on solar and on running a fridge on 12v.
I wouldn't place my confidence in one web post.
Old 11-13-2015, 01:48 AM   #13
Trailer: 1973 Love Bug '13
Mitch,
If you do decide to remove the existing furnace, please pm me. I am interested. Been looking for one.
Cathy
Cat futrell is offline   Reply With Quote
furnace
Reupholster Trill 1300 Val L Modifications, Alterations and Updates 1 08-21-2009 09:23 AM
77 Boler & 76 Trill 1300 Alistair Camelford Classified Archives 0 08-15-2009 08:51 AM
Reseal or Full Re-seat Roof Vent? Trill 4500 Fred G. Problem Solving | Owners Helping Owners 6 09-06-2006 09:10 PM
Mods of Dewey the Trill Brenda Novakovski Modifications, Alterations and Updates 4 12-11-2005 09:47 AM
Awning for 5500 Trill Legacy Posts Problem Solving | Owners Helping Owners 1 07-09-2003 11:42 PM
