Trillium 1300 - front upper shelf placement - Fiberglass RV
Old 09-14-2019, 06:45 PM   #1
Trailer: Trillium 1300
I have a Trillium 1300 that came without the front upper shelf.
I was able to get my hands on one and am hoping to install it soon. I've actually had it for a bit but never took the time to install it.
I know it gets screwed above the wood window frame at the front but where exactly does it screwed on the upper cabinet and close to the door. How far down from the ceiling does it gets fastened?
If anyone with that same shelf could tell me those measurements I'd greatly appreciate it.
Newfie is offline   Reply With Quote
Old 09-15-2019, 09:53 AM   #2
Raz
Raz's Avatar
Vermont
I have a newer Trillium supposedly made from the same molds. On mine the shelf is attached to the wood spacer above the window with drywall screws. On older Trilliums those wood spacers have a tendency to rot so make sure yours is solid. With your finger you should be able to identify the upper edge. Make sure your screws are not too long or you'll drill right through the trailer wall. One end of the shelf attaches to the cabinet. On the door side there is a fiberglass pillar to help support the roof. You should be able to feel it under the wall covering. The shelf screws into that. The self will not carry a lot of weight.
Old 09-15-2019, 11:05 AM   #3
+10 goes into the upper wood frame on the front window. I have no doubts there is going to be variation between trailers. Make sure the wood is solid first, the front can be the first to see rot. I'd aim for the middle of the wood frame. Then level to the upper kitchen cabinet and the fiberglass pillar by the door.
trillium
1974 Trillium 1300 - mounting front upper shelf Newfie Problem Solving | Owners Helping Owners 4 05-02-2019 01:45 PM
Upper Shelf Storage Solution ChrisDunbar Care and Feeding of Molded Fiberglass Trailers 6 09-23-2017 08:11 PM
UHaul Upper Shelf / Loft Project Thomas G. Modifications, Alterations and Updates 15 01-12-2013 09:02 AM
Trillium 1300 Interior Battery Placement Booker B. Problem Solving | Owners Helping Owners 12 06-22-2008 10:31 PM
Rear Upper Shelf with LED lights. evan Modifications, Alterations and Updates 2 11-20-2005 09:04 PM
