Trillium Flooring and Window Treatments? - Fiberglass RV
Old 06-28-2016, 02:09 PM   #1
Anne-Marie L's Avatar
Trailer: 1977 Trillium 1300
While I work away at much more important things on my 77 Trillium 1300, like new tires, propane tank and water and gas lines, my mind has also turned to a few more decorative things I'd like to change.
The Trillium currently has a flat weave carpet in it...while it is reasonably clean and serviceable for the short term, it is blah brown and will be hard to keep clean. I'd like to take it out (it's cut to fit the whole floor but not attached in any way) and replace it with a sheet vinyl flooring. Or perhaps stick on squares? What are others using? And how do you install it? I'm loathe to stick anything down that I wouldn't be able to easily take out again.
I'd also like to take out the faded curtains. I've seen a couple of photos where others have installed roller blinds but again, not sure how they have installed them. My Trillium has shelves over all the windows that leaves only a very small space between the window frame and the bottom of the shelf. I think people must have screwed the brackets for the blinds up, to the bottom of the shelf. Is this correct? I think you would need to back those screws up with something like a small block of wood since the shelves are not very thick. Would the shelf bear the weight of roller blinds?
Anne-Marie L is offline   Reply With Quote
Old 06-29-2016, 11:02 AM   #2
Trailer: 1978 Trillium 4500
Hi Anne-Marie, someone previous to us put in a parkay floor. Looks good, but a pain to refinish.
As for the windows, yes my blinds are anchored to the shelves above the window. We started with screws as that is what previous did, but after stabbing myself a few times we switched to bolts with lock-washers.
I put roman shades in mine using old mini blinds for the framework - Pintrest.
If you are looking to connect more with just Trillium owners, and are on Facebook, try Trillium Trailer Owners. Lots of them are from Ontario.
Island Bolers and Friends on Facebook
Island Claire is offline   Reply With Quote
Old 06-29-2016, 11:32 AM   #3
Trillium floor
Hello Anne-Marie,
I just put a new floor in my Trillium 4500. I took out the old vinyl and used it for a template to cut-out the new flooring. I bought a more expensive type of lino that just lays on the floor. It looks great and was easy to install.Click image for larger version
I also am in the middle of making some new curtains for my unit. I just attached the curtain rods on the sides of the window. In my trailer there is a wooden frame around each window under the ensolite.
In the picture the fabric on the seat is one of the curtains.
Good Luck....It is so much fun making the trailer your own by adding what you like and what fits for you.
Lyndee in the Port is offline   Reply With Quote
Old 06-30-2016, 11:15 AM   #4
Thanks Claire! I joined the Trillium FB page and have already seen lots of great ideas and renos!
"The true adventurer goes forth aimless and uncalculating to meet and greet unknown fate...O. Henry"
Old 06-30-2016, 11:17 AM   #5
Thanks Lynda! Your new floor looks terrific!
Originally Posted by Lyndee in the Port View Post
Hello Anne-Marie,
I just put a new floor in my Trillium 4500. I took out the old vinyl and used it for a template to cut-out the new flooring. I bought a more expensive type of lino that just lays on the floor. It looks great and was easy to install.Attachment 96854
Old 07-02-2016, 07:24 AM   #6
stefman's Avatar
Trailer: 76 Trillium 1300
Waterloo, Ontario
[QUOTE=Anne-Marie L;595420]
QUOTE]
All I did was get a couple of packages of interlocking foam flooring and cut it just a little smaller than the floor area (it expands in the heat and bulges if you don't leave it slightly smaller). I never glued it down or taped it and it never moves. It's water resistant and sure feels nice and soft under your feet. I can sweep it off or wipe it down or just remove it in less that 2 minutes. This photo is not the best to see the floor, and naturally my color is the color you don't want, but you get the idea.
stefman is offline   Reply With Quote
Old 07-02-2016, 07:40 AM   #7
Raz
Raz's Avatar
Vermont
My 2010 Trillium came with pleated shades that pull down. They are attached at the top to the shelf and run on strings attached to the bottom of the window. They work well.
On the floor we have carpet. While harder to keep clean that vinyl, I prefer carpet because it' feels warmer to my feet . Raz
trillium
Wanted: WANTED - Trillium 1300 - Shelves, door window, kitchen window and frame David Tilston Parts: Buy | Sell | Trade 6 10-20-2012 09:13 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
New here with a question on Fiberglass treatments mountain Hi, I am.... 14 02-03-2011 08:48 PM
Flooring trim solution.. cheap and easy! Gina D. Modifications, Alterations and Updates 15 08-24-2009 11:54 PM
trailer flooring and insulation General Chat 0 12-31-1969 07:00 PM
