Originally Posted by Rodre
"On all surfaces there is a limit to how many times they can be power buffed, rubbed out or cut polished with rubbing compound."
This is very true, but I figured the first .01mm of gel coat lasted 30 years so now that I have it back to new it should last my life time with the proper care, this is why I store it inside now.
If you store it outside it is probably better to use the treatments, otherwise you will have to cut polish it every so often, if you want to keep it looking new, and you can probably only do this 2-3 times.
Good point on the outside vs inside storage. That would make a big difference.
On mine the roof was the tell tale area, clearly had the deepest pits and appeared to have had the most wear possibly from prior attempts to rub it out, or just weathering. I know previous two owners stored it outside for years and figure roof took the worst weather related wear and tear.
