Old 05-09-2012, 06:17 AM   #1
Trailer: Trillium 13ft
Trillium - how to shine??
Hi.. searching for your advice We just purchased 1975 Trillium. It is dull looking. What methods we need to do to make it shine again?
Thank you Roger - Marilyn
Beernink is offline   Reply With Quote
Old 05-09-2012, 08:21 AM   #2
Thomas G.'s Avatar
Trailer: UHaul CT13 TV: Escape Hybrid
SE Michigan
Check out this thread:
Check this out NOT Poliglow...Time will tell..
Just call me Tom.
Thomas G. is online now   Reply With Quote
Old 05-09-2012, 10:03 AM   #3
Hi Marilyn
I have a 75 trillium (green) & have been advised by a friend to use "VIM" bathroom cleaner (not the one with bleach). I have tried a couple of test spots and lookd good.
I plan to wash the trailer first with a mild soap and water then use Vim with a car polisher. I have all the plastic strips from windows removed and will seal after polish and then replace the strips. I may also look into a final finish with a clear marine coating or I've also heard a clear hard floor coating does a good job.
Will make postings as I proceed.
Ron
RRJR is offline   Reply With Quote
Old 05-09-2012, 02:30 PM   #4
Trailer: Trillium Outback
Nova Scotia
I read somewhere to try "Gel-Gloss" as our Trillium had mold and tree sap spots over a large area of the roof and upper half when we purchased it last fall. This requires a little elbow grease if you do not use a polisher however the results speak for themself. Less than $10 for a 16 oz can at Cdn Tire and WalMart. It cleans and polishes.
Jan F.N is offline   Reply With Quote
Old 05-10-2012, 03:23 PM   #5
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Smile
I agree, check out this thread: Check this out NOT Poliglow...Time will tell.. I just did this a couple of weeks ago on our Trillium (see post 337 on the thread) and it looks great.
Rick G
Rick G is offline   Reply With Quote
Old 05-21-2012, 11:05 AM   #6
Dezzh's Avatar
Trailer: 75 Trillium 1300
I have a 75 Trillium.. and it too was very dull/hazy and almost rough to the touch. I went to a marine store, purchased a 3M product. One bottle was just a polishing compound and the other was a Restorer & Wax. It took me 4 full days by hand, and I'll tell you that it looks like brand new. The feel of the trailer to the touch is like GLASS.
If you can afford the time... it is well worth it.
cheers...
Dezzh is offline   Reply With Quote
Old 05-21-2012, 02:34 PM   #7
Trailer: 77 Scamp 13
3M rubbing, polish or scratch polish is fine to super fine abrasive which rubs off the chalking that old paint or gel coat does. I apply using a soft wet rag. Removes those black run down streaks well BUT... you are removing some surface so don't over rub and there is a limit to how many times one can do it. Your not removing the "pits" that make it rough and dull but rubbing off the high points to make it smooth and removing the chalky paint to let the good paint show. The chalked surface is the top of the paint degrading but it provides a layer that protects the "good" finish underneath from UV.
Bar keepers friend is a special type of bleach and super duper fine abrasive that can be a good cleaning choice, comes as a powder in a shaker can. Apply with a wet rag or small auto detail brush, does trailer finish and aluminum both rather well.
The not Pliglow link provided by Rick is about putting a protective coat on using inexpensive but heavy duty floor wax. Wax (from Rick or the one mentioned by Dezz) fills pits and provides a smooth shiny surface over the color underneath. With the added advantage of being easy to clean and preventing chalking until it wears off.
So you wash to get the grit off then if needed polish with a non-wax very mild abrasive, then apply wax to seal the whole thing. Wax needs a clean, well rinsed, dry, and wax free surface to stick to.
I would avoid wax and polish in one. I like to control the polish stage to get it right, then apply wax when it looks as good as I think it will get. Plan on using the Red Max #3 as described in the link by RickG.
Get before and after pictures :-)
Old 05-22-2012, 01:32 PM   #8
Normand Choiniere's Avatar
Trailer: Trillium 5500 1980
Don't loose your time with car wax, Polyglow, 3M, Vertgalss etc... I've tried all of them. Go for Red max Pro3 (now Zep Wet Look (identical at Home depot)). Nothing beats that floor finish and nothing is easier to do.
Normand Choiniere is offline   Reply With Quote
Old 05-25-2012, 05:13 AM   #9
Normad...What steps do we need to do to apply Red Max Pro 3? When I look at Red Max Pro website.. there are several types, stripper, high gloss finish and floor finish?? Which ones did you use?
thank you Marilyn
Old 05-25-2012, 08:47 AM   #10
Thomas G.'s Avatar
SE Michigan
thank you Marilyn
It is all laid out here in detail. Check this out NOT Poliglow...Time will tell..
Just call me Tom.
Old 05-25-2012, 10:42 AM   #11
cheers...
I also had excelling results using 3M Restore and wax to get all the marks and caulking off mine when I first got it - but I used a power buffer and it took less than a day. Have since only used the 3M cleaner for tough stains and give it a good wash & wax at the start of each year.
Old 06-21-2012, 11:40 PM   #12
Rodre's Avatar
Trailer: 1978 Trillium 1300
I took mine to a boat place and they cut polished it and it looks brand new. It was expensive but worth it to me. The difference was night and day. Now all I do is give it a good dousing of Areospace Protectant once a year and that protects it from UV rays and the water just beads off of it. I also store mine inside now as it is the UV rays and rain then drying again that makes them get oxidized, not to mention the things that like to grow in the pores in the gel coat. Avoid parking/storing your Trillium under the trees around your house, especially if you live in a moist climate.
~Rodre
I am a Trilliumaire - I can go camping anytime, any place, anywhere.
Rodre is offline   Reply With Quote
Old 06-22-2012, 10:50 AM   #13
On all surfaces there is a limit to how many times they can be power buffed, rubbed out or cut polished with rubbing compound. These all smooth the surface by removing some of the gel coat or paint to get rid of both the chalking on the surface and pitting.
An old trailer may have had this been done in the past or the pits may be deep enough that getting surface to smooth means removing a lot of gel coat, leaving it pretty thin.
That is one big advantage to using Red Max #3, or Zep wet look. They are a very thin liquid that as you wipe on each coat fills in the pits until your polish coat is smooth. typically 4 or 5 coats. But the coats go on fast. Your just wiping it on, by the time you finish first coat were you started is probably dry enough to start over.
Key is just to totally clean it first, that is where the time is invested. Bar keepers friend is just enough to get the chalky surface off as well as stains. TSP, bucket and brush to clean it some more, rinse really really well.
Let dry and start wiping on the floor wax. Couple hours later stand back and say "WOW"
I would add one caveat, if your thinking you will paint in the future avoid any wax or polish, it will all have to be 100% stripped to get a decent paint job. Even a small amount of wax residue can mess up a paint job (fish eye) and paint generally won't stick well to polish (peeling in the nooks and crannies where you did not get polish removed)
That said I see no reason to paint when my 35 year old camper that used to have all the shine of a real egg now looks pretty much like new from the Red Max treatment. This picture is a copy, of a reduced size copy, copied again to remove license plate. In person you could ID the trees by looking at the reflection of the leaves that you can still see around the left top corner.
http://www.fiberglassrv.com/forums/m...icture2024.jpg
Old 06-23-2012, 12:12 AM   #14
Rodre's Avatar
"On all surfaces there is a limit to how many times they can be power buffed, rubbed out or cut polished with rubbing compound."
This is very true, but I figured the first .01mm of gel coat lasted 30 years so now that I have it back to new it should last my life time with the proper care, this is why I store it inside now.
If you store it outside it is probably better to use the treatments, otherwise you will have to cut polish it every so often, if you want to keep it looking new, and you can probably only do this 2-3 times.
~Rodre
trillium
Chasing the elusive shine Colin Care and Feeding of Molded Fiberglass Trailers 30 08-02-2012 05:37 AM
Getting the shine back (my experiment) Mark G. Care and Feeding of Molded Fiberglass Trailers 2 02-01-2010 06:28 PM
Want the shine Gerry Problem Solving -- Owners Helping Owners 20 10-13-2006 06:30 PM
My shine is back Legacy Posts Care and Feeding of Molded Fiberglass Trailers 13 06-21-2003 07:54 AM
How do I get the shine back.. Legacy Posts Care and Feeding of Molded Fiberglass Trailers 35 05-05-2003 12:12 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
