Trillium trailer 12V wiring - Page 4 - Fiberglass RV
Old 05-05-2011, 05:19 PM   #43
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Francesca remember the other day, I said to just sit back and watch.
Old 05-05-2011, 07:02 PM   #44
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Old 05-05-2011, 08:41 PM   #45
Greg H's Avatar
Indiana
That's cool.
Old 05-05-2011, 08:48 PM   #46
All quiet so far....
I'm afraid to look at the other thread...
Francesca
Old 05-05-2011, 11:15 PM   #47
Roger C H's Avatar
I would be very careful replacing 15 amp equipment with 20 amp. The main concern is the wiring. Here is a link that tells you what each gauge of wire will carry or conversly, if you want to carry X amperage, what wire size you need:
Ampacity Charts
Old 05-06-2011, 10:55 AM   #48
Rodre's Avatar
Trailer: 1978 Trillium 1300
Ampacity Charts
Thanks Roger, that is going to be a huge help when I get the battery setup.
I took a good look at the wiring last night. It looks like the fuse was added, possibly as a replacement, after the factory. The fuse is on the black power wire from the vehicle. I am not sure if the light blue wires that are connected to the darker blue wire under the black caps (see picture) that is part of the red fuse carrier were part of the original fuse or not, as they appear to be terminated under the white caps which appear to be factory. I think the fuse is getting hot because the wires that are part of the fuse setup are a smaller guage than the black wires on either side of it. In any case I am going to replace the fuse with an auto resetting one and will probably stick with a 15amp fuse, as all I have inside that uses the 12v power in my trailer is the fridge, which I believe uses 8amps (I have the manual so I will double check this), and 3 dome lights. Does anyone know the amp draw of the dome lights?
My next question is: Whould I run the charge wire out to the dedicated trailer battery from before the fuse or after the fuse? Does any one have a factory battery setup they can explain out to me?
~Rod
Rodre is offline   Reply With Quote
Old 05-06-2011, 11:05 AM   #49
Trailer: 2008 Casita 17 SD
"Really cool diagram and great-looking plan but AAARGH !!!
I see you have two separate and distinct ground connections.
We just got very thoroughly taught that this is BAD BAD BAD.
Plus, it's BAD."
It's ok Francesca,
Don't be afraid of it, it's only a "line diagram" way of showing what's hooked up to what. It does show two different grounds, one is for the 120 vac side, and one is for the 12 vdc side. Although they appear to be at opposite ends of the drawing, they should both be, in the actual installation, made at the same point on the frame. It's all still good!
Greg
Old 05-06-2011, 11:17 AM   #50
Rodre's Avatar
I just referenced the Trillium wireing diagram and it appears that the lead out to the dedicated trailer battery would be needed to be placed before the fuse. Can anyone confirm this for me? Also looking back at Francesca's wiring photo it would appear that the light blue wire may have been factory, as I can see similar coloured wire in her photo, now I just wonder what was here before?
Also, the yellow wire is indeed connected to the tow vehicles backup lights (center pin on 7 way plug). I tested this with a multi-meter and it is confirmed. I picked up a wireless backup camera and monitor at Pep boys for $60 so I think I will install it here. I was thinking to install it so it had power all the time so I could use it as a rear view mirror while towing, but I am not sure if this would cause the camera to burn out pre-maturely. Does anyone have any thoughts on this?
~Rod
Old 05-06-2011, 11:29 AM   #51
"I just referenced the Trillium wiring diagram, and it appears that the lead out to the dedicated trailer battery would be needed to be placed before the fuse. Can anyone confirm this for me?"
I'm not sure where exactly your battery is mounted in relation to the other end of the power lead, but as a general rule, the closer a fuse or breaker can be installed to the power source, the better (and safer) the circuit protection would be.
As an example, let's say, for some reason, that your power supply lead managed to become abraded and the insulation was no longer intact. If that spot came into contact with a grounded spot on the trailer, or with another grounded component, you would most probably melt all the insulation off the wire from the battery to the point of the short, perhaps even melt the wire itself, and possibly burn up your whole trailer, because the fuse or breaker, located further downstream, wouldn't even be seeing any of the excess current flow occurring before it.
Old 05-06-2011, 11:39 AM   #52
~Rod
The blue wire you see in my photo is the electric brakes.
Unless that's true of the blue wire in yours, someone has done the old "use whatever wire is lying around" trick.
I'm a total fanatic when it comes to using correct wire color and guage. I'm confused enough as it is!
You'd be doing yourself (and the next owner!) a big favor if you made sure that your wires follow the color coding on the Trillium diagram...
Francesca
Old 05-06-2011, 11:42 AM   #53
I agree totally with you on that one. Trailer wiring is a pain in the A** as it is, but to have "non-compliant" and non standard color coded wiring only adds to the misery of trying to figure out where and what some lead goes to.
Old 05-06-2011, 11:48 AM   #54
Rodre's Avatar
Hi Greg,
I am thinking to mount the battery around the hitch area, probably in the place of one of my propane tanks. I would need to run positive and negative leads from inside the trailer back out to this area (and possible back in?). I really wish I could see how a factory job was wired so I could just replcate it.
I think it would have to look something like this:
power from 7 way connected to vehicle -> wired out to battery -> wired back into trailer to 15amp fuse -> trailer wiring harness
and the negative would be the same minus the inline fuse.
Does this sound about right?
~Rod
~Rod
Old 05-06-2011, 12:02 PM   #55
Power to charge the trailer battery from the tow vehicle's alternator can be tapped out of the wiring harness from your 7-pin connector, as you had planned, and brought right in to your battery (+) terminal on the trailer tongue. This is fine, but I would also suggest (if you don't already have one) that the alternator charging output lead to the 7-pin connector is equipped with either a fuse or resetting circuit breaker right at the alternator's output terminal. Again, for the same reason as in the example I used above, if a short were to occur in this power feed line under your tow rig, it could create a fire if there is no circuit protection device installed to break the current flow should a direct short happen.
Other than that, I see no problem with what you propose to do. Have fun with your project.
Greg
Old 05-06-2011, 12:09 PM   #56
Rodre's Avatar
Hi Greg,
Yes, there is a fuse on the vehicle side of the alternator output of the charge wire, although it is 30amp and part of the fusebox but right at the post. One [hopefully] last questions, what guage and type of wire should I have running out to the battery and back in? Should I just use the same guage that comes of the 7 way connector on the trailer? Also, if I kept the seond propane bottle and added a battery box would this be too heavy for the trailer frame in the hitch area? I am not worried about the tongue weight because I know the tow vehicle can handle it.
~Rod
trillium
HELP- - Re-wiring a 74 Trillium 13' Barry Konkin Electrical | Charging, Systems, Solar and Generators 20 10-05-2015 08:35 AM
1974 Trillium 12v Barry Konkin Electrical | Charging, Systems, Solar and Generators 17 07-26-2012 07:40 PM
Need guidance wiring 12v Distribution panel francene Problem Solving | Owners Helping Owners 13 11-01-2009 11:16 PM
Vehicle wiring to tow Trillium 13 francene Towing, Hitching, Axles and Running Gear 9 03-19-2009 09:14 PM
Wanted:Trillium wiring diagram Mikey Problem Solving | Owners Helping Owners 1 09-01-2007 05:07 PM
