Uhaul door hinges - Fiberglass RV
Old 01-04-2013, 05:45 PM   #1
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Uhaul door hinges
Was Paging through the UHaul Ebay store and found these: part number is the same as in UHaul manual should be good for 84&85 production. Price is good. I just spent about $40 each with a discount to get 2 new ones. granted they were SS. hope the link works if not just go to UHaul ebay store and search for part 21822003
Michael J
Door Hinge 21822003 | eBay
mmeyer is online now   Reply With Quote
Old 01-04-2013, 05:47 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Great find! I've noticed that prices are different between their eBay store and their regular on line sales, so it makes sense to check both.
Old 01-04-2013, 07:11 PM   #3
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
Thx for highlighting. went ahead and ordered a couple to have on hand.
--Sean
1984 Uhaul CT 13
TV: 2011 Kia Sorento V6, 2001 Mazda Tribute V6
My U-haul Camper Blog
knighth001 is offline   Reply With Quote
Old 01-05-2013, 10:14 AM   #4
Trailer: 1984 UHaul CT13
Mike,
The listing has ended. Good score. Let me know if you find them again.
Thanks,
Patti
keekers is offline   Reply With Quote
Old 01-05-2013, 10:28 AM   #5
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Wow they sold 9 real quick
Old 01-05-2013, 10:29 AM   #6
Thomas G.'s Avatar
Originally Posted by keekers View Post
Mike,
Thanks,
Patti
Yea, I'm amazed that they sold 19 of them. There must be more UHauls out there than we realize. I checked that part number at the UHaul on-line truck and trailer parts site and it doesn't come up, so this must have been a one off find. I believe that someone found another source for this hinge as I recall for ice boxes.
Kason 1070 Hinge Kason 1070 Surfacemount Hinge Specifications
Old 01-05-2013, 03:05 PM   #7
If you look in the Uhaul repair manual I believe it shows that at one time there were replacement hinges that had a slightly different mounting hole placement. I have a set of used hinges from a VT that have the holes locations different than my originals.
mary and bob is online now   Reply With Quote
Old 01-05-2013, 03:24 PM   #8
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
I've noticed that my attachment screws come loose every now and then on my VT hinges. I've tightened them up each time, but I'm finding that the wood core of the door seems to be deteriorating around the screws. Has anyone found a better way to attach the hinges to the door? Should I go with bolts and nuts rather than screws? Anyone done this?
Old 01-05-2013, 03:39 PM   #9
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
On my VT there are only 2 screws for each hinge rest are bolts. My top hinge had issues with the screws so I used SS 8-32 bolts (I believe) drilled through. Uses SS washer and loctite trimmed bolt to top of nut with dermal tool and cut off wheel. Other bolts were replaced with SS bolts washers and nylon lock nuts. Bottom screws were upgraded to #10 same length. May need to squirt some thin epoxy wood filler in holes to strengthen
Michael J
Old 01-05-2013, 09:30 PM   #10
WildBirder's Avatar
Seems to be a similar problem running in this thread simultaneously. http://www.fiberglassrv.com/forums/f...r-55916-2.html Francesca had good recommendations that I repeated a bit (was multi tasking/skimming rather than reading).
Mark
1969 Boler
(#183)
WildBirder is offline   Reply With Quote
Old 01-05-2013, 09:36 PM   #11
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Amazing!
' Expect the unexpected ' appears to be the rule regarding obselete UHaul
CT or VT parts. These hinges went fast but those yet to be revealed tail
light lenses are sure to go even faster!
don '85 CT-13 PEACE be with you!
"Sometimes the hunt is better than the catch"
djtriceflt is offline   Reply With Quote
Old 01-09-2013, 07:35 AM   #12
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Got my spare hinge yesterday it is a polar 402 exact same as I took off the VT
Michael J
Old 01-17-2013, 03:35 PM   #13
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
My burro had that problem. I opened it up from the inside and inserted thick aluminum plates - drilled through and bolted the body part of the hinge the door then drilled, threaded and screwed into the door aluminum insert. It seems to be holding up really well. The epoxy solution would be much simpler if you can make that work!
Sue and Henry is offline   Reply With Quote
Old 03-02-2015, 07:50 PM   #14
Trailer: Uhaul
Silver turtle
I found a black strap hinge at Harbor Freight that worked great on my U Haul 13 ft.
for $2.95. I bolted and screwed it on. Works great.
Andy Sigmund is offline   Reply With Quote
uhaul
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 11:39 AM
Door Hinges and Scamp Door sill Cat futrell Problem Solving | Owners Helping Owners 4 10-15-2012 07:46 PM
Wanted: Boler Hinges - Looking for a pair of Boler Entry Door Hinges idiotsniff Parts: Buy | Sell | Trade 6 01-13-2012 10:02 AM
Uhaul Door hinges Pat B Ohio Problem Solving | Owners Helping Owners 4 09-28-2009 02:24 PM
