UHaul Refrigerator Gasket - Fiberglass RV
Old 12-04-2011, 12:14 PM   #1
Thomas G.'s Avatar
Newbie here with lots of questions. My new CT13 has a very stiff icebox gasket. I'm wondering if a replacement is readily available or if anyone has found other workarounds. I know that BMW sells a liquid softener that works on rubber parts on cars to keep them soft, but this gasket seems to be a soft plastic.
Thanks in advance.
Old 12-04-2011, 05:59 PM   #2
Trailer: Bigfoot Silver Cloud -1988
Sorry I can't help you with the original gasket, but my guess is that it is dried out beyond all help. You will probably need to search around websites that carry gaskets for other trailer fridges or small dorm fridges. One of those gaskets may be able to be cut to fit. You might check out an old style hardware store, too. They often carry strange old things that might work. Or, as we did, replace your ice box with a small dorm fridge. We had to cut the hole slightly larger, but it is great having cold food and pop! Ours is electric (110) only, but I know Dometic has 3-way fridges for gas/12v/110v. We got ours at WalMart.
Old 12-04-2011, 06:18 PM   #3
Thomas G.'s Avatar
Thanks for the reply. We plan to mostly dry camp, so that means ice or an LP 'fridge. And I know how much an LP fridge is - half the cost I have in this camper.
I researched it a bit and one recommendation was to wipe the seal down with mineral oil. So I tried that and will check it in the AM to see if it helped. If nothing else, I'll find something close and modify it to fit.
Old 12-09-2011, 10:41 AM   #4
Did the mineral oil work?
Old 12-09-2011, 11:22 AM   #5
Thomas G.'s Avatar
The gasket is a little softer, but it is hard to tell quantitatively, as it has also gotten colder here. I plan to continue wiping it with mineral oil to see if it continues to soften. Somewhere else I saw a recommendation of using Vaseline, which may have the same basic ingredient.
BMW also sells a gasket softener - Amazon.com: einszett 914806 'Gummi Pflege Stift' Rubber Care Stick - 3.4 fl. oz: Automotive
I think that either method is definitely worth doing.
Old 12-09-2011, 11:58 AM   #6
Trailer: U-Haul CT13 ('Pearl')
I decided to remove the icebox. Very inefficent. I will turn the forward seat well into a cooler. Using the fiberglass insert, I will put in a drain and insulate it. From the floor and wall I will use a combination of foil insulation and expanding foam, making sure I can remove it if needed. I did a front dinette mod on my U-haul, so the bench nearest the door is the one I will use. All I need to do is make a good lid. The major drawback is the small size, and no midnight snacks if we have a third camper.
Pat B Ohio is offline   Reply With Quote
Old 12-09-2011, 01:12 PM   #7
Thomas G.'s Avatar
Interesting concept. I hope you will post a few pictures when you are done.
I'm thinking of keeping the present icebox, but adding 1.5" of foam with foil surface to 5 sides and maybe doubling up on the gasket..
Old 12-09-2011, 04:02 PM   #8
I thought about adding insulation, but it still allows cold air to flow out when you open the door. Also, I could not come up with an idea to fix the door. The cold box will double as storage when not needed.
Old 12-14-2011, 12:01 AM   #9
Roger C H's Avatar
Under the seat next to the door
Isn't that the location most use for the Porta Potti?
Eeew!
Old 12-19-2011, 03:16 PM   #10
Trailer: 1976 Boler 13 ft
Iceboxes so 1990's......
David Konduc is offline   Reply With Quote
Old 12-19-2011, 04:17 PM   #11
Thomas G.'s Avatar
I guess I am missing your point.
Old 12-19-2011, 08:56 PM   #12
IF I needed to replace the gasket on my refrigerator (and don't) and couldn't find a direct replacement.... I might try a closed-cell foam like this: Shop Frost King 10'L x 1/2"W Black Rubber Foam Tape Weather Strip at Lowes.com=
and put it on the refrigerator itself... rather than the door.
Old 12-20-2011, 06:53 AM   #13
Thomas G.'s Avatar
Good suggestion. Why do you prefer the attachment to the fridge vs the door?
Old 12-20-2011, 08:21 AM   #14
I guess because I prefer to put gasket materials on fixed surfaces. The closed-foam tape I have on the trailer to seal the door is also on the body... not the door. YMMV
Old 12-20-2011, 01:07 PM   #15
I think the attachment of the foam may just be a personal preference. I've done it both ways and haven't had any better or worse luck. Experiment!
Old 12-20-2011, 02:21 PM   #16
Thomas G.'s Avatar
I'm toying with adding a second gasket inboard of the original, which is stiff, but mostly serviceable. Any thoughts about a bulb type seal as opposed to a closed foam of constant cross section?
Old 03-27-2012, 02:44 PM   #17
Thee Jimbo's Avatar
What finally happened on this thread. The door gasket seems ok on my 1971 Hadco Fridge, but the ice cube box gasket on it is dry and cracked. Sounds similar to yours.
You used to be able to buy misc gaskets by the foot, but that doesnt happen anymore. Finally I talked to a repair guy and asked if an adhesive foam weatherstripping would work. He told me yes, and added that he restored a 1920's fridge about 15 years ago, couldnt find a gasket, used a black foam (thanks donna) and fifteen years later its still working great.
Thee Jimbo is offline   Reply With Quote
Old 03-27-2012, 02:46 PM   #18
Thomas G.'s Avatar
Originally Posted by Thee Jimbo View Post
What finally happened on this thread. .........
I ended up buying a refrigerator to replace the ice box. I do think the baby oil (mineral oil) helped a little, but not night and day better.
refrigerator, uhaul
New Window Gasket Gordon Kinslow Modifications, Alterations and Updates 14 10-03-2012 11:44 PM
Looking for new gasket... J.S.Lahm Problem Solving | Owners Helping Owners 1 10-12-2011 08:24 PM
Gasket for lights Borden Problem Solving | Owners Helping Owners 4 02-13-2011 08:10 PM
window gasket Rarebird Problem Solving | Owners Helping Owners 6 04-23-2009 05:10 AM
Window gasket Legacy Posts Problem Solving | Owners Helping Owners 9 05-25-2003 07:40 PM
