Ultralube on 2010 Scamp - Fiberglass RV
Old 04-19-2011, 03:53 PM   #1
skephart's Avatar
I have a question regarding my new 2010 Scamp. I picked it up at the factory in October and winterized in after our Thanksgiving trip to Califronia and managed to put just under 5,000 miles on it. It has the Ultralube on the axle for greasing the wheel bearings. The axle manual says to lube every 6,000 miles or 6 months and the says the hubs and components should be disassembled yearly and inspected. Does anyone have a minimum of miles before it should be disassembled.
skephart is offline   Reply With Quote
Old 04-20-2011, 11:12 AM   #2
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
We have Easy Lube axles, is that the same? Our unit is the older 05 model. After finding the correct grease we shoot 3 pumps on the grease gun into each side. The old grease starts to come out, so you know you have enough in there. We generally travel 5,000 miles a year (one long and one very short), and do the grease thing once a year before traveling.
Oops. We have never disassembled for yearly inspection. Looking forward to reading others posts, and learning about Ultralube.
Nancy
Nancy is offline   Reply With Quote
Old 04-20-2011, 12:47 PM   #3
Trailer: 21' Escape - former owner of 17' "other brand."
I never did understand the E-Z Lube service procedures. In one place they advertise it as a "complete bearing repack" with "no disassembly required." But in another place they say that you should still inspect the bearings yearly for wear and damage. If you need to inspect them yearly you also need to clean and repack them - so where's the savings? Except, I doubt if you really need to inspect them yearly as long as you keep them lubed with the correct grease and change it out every year or two using the zerk fittings.
Old 04-20-2011, 01:39 PM   #4
IllAnnoy
It's called CYA, I use my E-Z Lube for maintenance and hand inspect them when the brakes need serviced.
I checked and repacked them when new at home after 600 miles, serviced the brakes and hand repacked the bearings at 30,000 miles, otherwise I have used the EZ Lube, I LOVE EM! [50,000 miles of towing over 7 years]
BTW; I repacked the front wheel bearings on my truck for the first time at 100,000miles when replacing the brakes. I plan to do it again on about the same schedule.
Old 04-20-2011, 02:09 PM   #5
skephart's Avatar
Thanks to everyone. It looks like I don't need to worry about an annual inspection. I will be putting on about 10,000 miles a year on the Scamp so I was not sure how often I should inspect the bearings. Maybe every other year.
Old 04-20-2011, 10:21 PM   #6
Steve, Besides topping off the grease every season we also check for heat at gas stops. We bought one of those infra red thermometers. When we can't find that (we can seldom find that), we just touch the axle to see if it is hot. We sort of got in the habit of visually checking tires all around often too, and probably check tire pressure more often than most people.
Have fun with your rig this season. We just had snow again today. Enough.
Nancy
Old 04-21-2011, 09:40 AM   #7
grease wheel bearings
I have always, always had my wheel bearings cleaned, inspected and greased between 3000-4000 miles. It is hard to keep track of mileage, but a log book stuck inside a cupboard with the registration is a fairly easy way to keep track of mileage. I also, take my trailer for a short excursion about three times each winter, when there is no snow on the ground. I don't like the idea of it sitting around all winter with the wheel bearings not used. It may be just a silly idea of mine, but I have seen many trailers, of all sorts, parked along the highway during the years with one wheel off because that bearing got hot. I think, for the money I pay to get the bearings taken care of is good insurance for me. Marg
Marg is offline   Reply With Quote
Old 04-21-2011, 09:43 AM   #8
Trailer: 1971 Amerigo
I asked Redneck about it when I bought the 3.500# Dexter axle for the Amerigo. They basically said - you can get it but it only lubes the rear bearing - you still have to disassemble to service the front and check both.
So with that I passed on EZ Lube
Peter_Crowl is offline   Reply With Quote
Old 04-21-2011, 09:55 AM   #9
IllAnnoy
They were basically wrong
Old 04-21-2011, 11:11 AM   #10
Greg H's Avatar
Trailer: 72 Boler American
Indiana
But Floyd that would be the new American way, Pay more for something that only does half of the job.
Old 04-21-2011, 11:56 AM   #11
Look here:
RV.Net Open Roads Forum: Verdict on EZ Lube / Ultra Lube Axles from Dexter and AL-KO?
My worry is having grease to come out the back and getting on the brakes. I just do a couple of squirts on each hub each trip.
Old 04-21-2011, 01:01 PM   #12
Yeah, whoever "Redneck" is he/they were totally wrong about it only greasing the back bearing. Look at the Dexter information to see how it really works. When you pump it in the excess grease comes out the front, past both bearings.
The inspection part is still valid as we've discussed, but many people go more than a year between these with no problem.
I too am a bit concerned about grease getting past the grease seal and onto the brakes. I'm very careful when I replace the hub that I don't bang the seal and put a dent in it where the grease could get past.
Old 04-21-2011, 01:17 PM   #13
Redneck Trailer Supplies
Old 04-21-2011, 01:32 PM   #14
I have a son in law who calls the parts desk to ask and debate which brake pads to install on his car. What he should really do is to talk with a master mechanic not a parts guy that may be minimum age or older and may or may not know jack #$%@ about brake pads other than their stock number and location.
The same may apply to the Redneck answer. Did U discuss it with a master mechanic or a skol bandit between the lower lip and his tooth kind of guy.
2010 scamp D Tharp General Chat 3 03-26-2011 05:32 PM
Scamp 5'er and 2010 Tundra Jerry71 Towing, Hitching, Axles and Running Gear 7 01-27-2011 06:01 PM
2010 EGGFEST / SCAMP CAMP - Sept 15-19, 2010 Jim Hovind Rallies, Get-togethers, Molded Meets (Archive) 37 09-20-2010 04:20 PM
New 19' Scamp coming out 2010 Kevin K General Chat 19 04-05-2009 04:24 PM
